Home » Modeling » EMF » [CDO] Explicit locking / Changes to EPackages
[CDO] Explicit locking / Changes to EPackages [message #422813] |
Tue, 16 September 2008 05:55  |
Just for discussion, there are two features that I believe CDO does not
have that I'd like to put out here, to get some feedback.
1. Explicit locking: Something like a method #lock()/#unlock() in the
CDOObject interface, allowing the caller to flag an object as not
editable by any users other than him/her. Whenever another user
committed a tx affecting the object, s/he would receive a
CdoObjectLockedException and his tx would roll back.
2. Support for changes to EPackages, especially dynamic ones: say I add
an EAttribute to an EClass, would be great if CDO picked up on that,
added a column to the table, and could keep going without a database
re-write. In the simple case of an addition of a feature or a class, it
seems doable to me: if there is a difference between the Ecore xml in
the database and that in the EPackage being registered, the new features
can be found and added.
Btw, currently plain EClass names are used as table names. Wouldn't it
be better to prepend the package name? Currently two EClasses with the
same name, but with different features, can't coexist.
Jasper.
Re: [CDO] Explicit locking / Changes to EPackages [message #422815 is a reply to message #422813] |
Tue, 16 September 2008 06:17   |
Jasper,
Comments below.
> not have that I'd like to put out here, to get some feedback.
This relates somewhat to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247130. One tricky aspect
to the desire to veto updates that Eike and I discussed a few days ago
is that during the process of updating a bidirectional reference as many
as 6 different pointer swizzles involving as many 4 different objects
are involved. A veto part way through the process is very difficult to
address. As long as all the ends involved have the same notion of what
should be vetoed, it's not a problem... A cross document bidirectional
reference where one of the two documents is read-only is problematic
when edited from the writable side...
> add an EAttribute to an EClass, would be great if CDO picked up on
> that, added a column to the table, and could keep going without a
> database re-write.
How dynamic is this? While the model is live and instances exist? Not
even Java with hot replace supports such a thing...
> In the simple case of an addition of a feature or a class, it seems
> doable to me: if there is a difference between the Ecore xml in the
If you're not expecting live objects to grow, it seems okay...
I think Teneo addresses such issues fully...
> Jasper.
Re: [CDO] Explicit locking / Changes to EPackages [message #422816 is a reply to message #422813] |
Tue, 16 September 2008 06:21   |
Although I have some concerns with making this a default capability of a
CDO repository I think the idea is worth being discussed in a Bugzilla ;-)
> database re-write. In the simple case of an addition of a feature or a
> class, it seems doable to me: if there is a difference between the
> Ecore xml in the database and that in the EPackage being registered,
> the new features can be found and added.
This topic has been discussed several times, for example search the web
for "model-evolution CDO".
I always thought this is a cool feature but it'd be *very* hard to
implement correctly, particularly because CDO supports
recording/accessing historical states of the model instances!
I don't see a possibility to add this feature anytime soon. If you're
willing to discuss technical details and contribute major effort please
feel free to file a Bugzilla.
In the DBStore or the HibernateStore?
For the DBStore I would not mind an enhancement request and for the
HibernateStore I'd suggest to talk to Martin first.
Cheers
/Eike
Re: [CDO] Explicit locking / Changes to EPackages [message #422819 is a reply to message #422816] |
Tue, 16 September 2008 07:09   |
Ed, Eike,
Thanks for your quick responses. I've opened enhancement requests for
the locking issue and the class-name conflicts:
http://bugs.eclipse.org/247427
http://bugs.eclipse.org/247428
Regarding the class-name conflicts and prefixes to address it, I'm
talking about the DBStore. The HibernateStore may or may not address
this problem, but it's unusable to me because it doesn't keep a revision
history..
On the matter of model-evolution CDO, I'm not concerned about live
objects. If it's a requirement for all sessions to be closed for a
change to an EPackage, that doesn't bother me. It's really about the
database. Domain models inevitably evolve, and it's undesirable to
dispatch a DBA to manually fix things. On the other hand, I realize that
indeed it's a hard problem. Will sleep on it before I submit an
enhancement request ;-)
Thanks guys,
Jasper.
> Cheers
> /Eike
Re: [CDO] Explicit locking / Changes to EPackages [message #422821 is a reply to message #422816] |
Tue, 16 September 2008 08:23   |
Hi Eike, Jasper,
You can annotate the ECLass with a @Table annotation to force a certain tablename.
Or another way is that Teneo supports prepending the package prefix before the classname. But I
checked currently with cdo this feature is not reachable (the api does not offer it yet). I will add
this.
The @Table annotation works.
gr. Martin
> Cheers
> /Eike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] Explicit locking / Changes to EPackages [message #422822 is a reply to message #422821] |
Tue, 16 September 2008 08:34  |
Martin Taal schrieb:
> Hi Eike, Jasper,
> certain tablename.
> before the classname. But I checked currently with cdo this feature is
> not reachable (the api does not offer it yet). I will add this.
Thank you for clarifying this, Martin ;-)
Cheers
/Eike
> gr. Martin
>>> the CDOObject interface, allowing the caller to flag an object as
>>> not editable by any users other than him/her. Whenever another user
>> of a CDO repository I think the idea is worth being discussed in a
>> Bugzilla ;-)
>>> a class, it seems doable to me: if there is a difference between the
>> web for "model-evolution CDO".
>> please feel free to file a Bugzilla.
>>> it be better to prepend the package name? Currently two EClasses
>>> with the same name, but with different features, can't coexist.
>> Cheers
>> /Eike
Current Time: Wed Jul 23 18:30:53 EDT 2025
Powered by FUDForum. Page generated in 0.05032 seconds
