Home » Modeling » EMF » [CDO] ExtendedLibrary sample with CDO ?
[CDO] ExtendedLibrary sample with CDO ? [message #422670] |
Fri, 12 September 2008 10:02  |
Does anyone try to wire the Extended Library Editor (the one from EMF
examples) with CDO server ?
I'm not using the CDO session views.
I made some changes ExtendedLibrary editor to connect it to a CDO server,
open a session, get a transaction and create a cdo resource.
Problems raise when I try to add a new library with a writer.
All created objects seem to be transient. When debugging
CDOObjectImpl.dynamicSet() method, and FSMUtil.isTransient(this) always
answers true. Is it normal ?
When I commit the transaction, that fails with this message :
[ERROR] SQL Exception: The statement was aborted because it would have
caused a duplicate key value in a unique or primary key constraint or
unique index identified by 'CDORESOURCE_IDX0' defined on 'CDORESOURCE'.
Before I commit the transaction, I have no exception in eclipse log file.
N.B : Extended Library editor runs with an editing domain which is an EMF
Transactional one.
Does anyone have an idea ?
Stephane.
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422679 is a reply to message #422674] |
Fri, 12 September 2008 11:29   |
Hi Eike,
Yes, I have generated the Extended Library model with changes in the
genmodel as mentionned in the "Preparing EMF Models for CDO" article.
To create a resource, I'm using transaction.createResource(path) method. I
have moved to getOrCreateResource() method.
Once, the resource is created, I add it to a resource set owned by a
transactional editing domain.
Now, at save time, I got this exception stack :
java.lang.IllegalStateException: Failing event COMMIT in state TRANSIENT
for CDOResource@oid1
(data= org.eclipse.emf.internal.cdo.protocol.CommitTransactionResul t @d8d767)
at
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:152)
at
org.eclipse.emf.internal.cdo.CDOStateMachine.commit(CDOState Machine.java:274)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.postCommit(C DOTransactionImpl.java:475)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:246)
at
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOR esourceImpl.java:369)
My editor was already working with a transactional editing domain. I try
CDO to get a multi-user capability on my existing editor.
This editor is a GMF one that only works with a transational editing
domain.
My idea was to open a CDO transaction when the editor is opening. After
every save operation, I would like to commit the CDO transaction to really
flush data to the database.
Between save operations, my transactional editing domain listens to model
changes.
Stephane.
Eike Stepper wrote:
> Stéphane Fournier schrieb:
>> Hi,
>> server, open a session, get a transaction and create a cdo resource.
>> always answers true. Is it normal ?
> I see you're using CDOObjectImpl but just to be sure: Did you regenerate
> the Library model after migrating the genmodel to CDO?
> Usually CDOObjects are TANSIENT as long as they're not attached to a
> CDOTransaction. This is also true for CDOResource (which is a CDOObject,
> too). How did you create the CDOResource?
> The best way is transaction.createResource(path). If objects are then
> attached to other objects that are already attached, the new objects
> will also transition from TRANSIENT to NEW.
> Looks as if a resource with that path (i.e. URI) is already stored in
> the repository.
> Either clear your database from previous attempts or use a different
> resourcepath or call transaction.getOrCreateResource(path).
>> EMF Transactional one.
> That's (IMHO) generally not a good idea!
> Why do you add a second transactional layer on top of CDO?
> Cheers
> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422682 is a reply to message #422679] |
Fri, 12 September 2008 11:42   |
> Hi Eike,
> method. I have moved to getOrCreateResource() method. Once, the
Ah! That's not allowed! Because ResourceSet.resources is like a
containment reference it's like a detach from the CDOTransaction!
The best thing you can do is not using EMF Transaction (sorry
Christian!) on top of CDO.
The second best thing you could try is:
1) Get the ResourceSet out of the TransactionalEditingDomain
2) Call CDOSession.openTransaction(resourceSet) to reuse 1) instead of
creating a new resource set
> TRANSIENT for CDOResource@oid1
> at
> at
> at
> at
> at
> try CDO to get a multi-user capability on my existing editor. This
> editor is a GMF one that only works with a transational editing domain.
> After every save operation, I would like to commit the CDO transaction
> to really flush data to the database.
> model changes.
Many users already asked for compatibility with GMF so I'm very
interested in your results. Please give feedback! ;-)
Cheers
/Eike
> Stephane.
>>> Hi,
>>> EMF examples) with CDO server ?
>> regenerate the Library model after migrating the genmodel to CDO?
>> CDOObject, too). How did you create the CDOResource?
>>> have caused a duplicate key value in a unique or primary key
>>> constraint or unique index identified by 'CDORESOURCE_IDX0' defined
>>> on 'CDORESOURCE'.
>> the repository.
>>> file.
>>> an EMF Transactional one.
>> Cheers
>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422685 is a reply to message #422682] |
Fri, 12 September 2008 12:11   |
Eike Stepper wrote:
I tried what you suggested at 2).
Now, I got the exception below. I'm using the embbeded derby store.
Indeed, after the resource creation a log mentionned that Legacy system is
not available. What does it mean ?
Ok, to give you feedbacks to run editor based on CDO and EMF Transaction,
if I succeed ;)
Stephane.
org.eclipse.emf.cdo.util.LegacySystemNotAvailableException: Legacy system
not available
at
org.eclipse.emf.internal.cdo.util.FSMUtil.checkLegacySystemA vailability(FSMUtil.java:82)
at
org.eclipse.emf.internal.cdo.CDOStore.handleContainmentAdd(C DOStore.java:562)
at org.eclipse.emf.internal.cdo.CDOStore.add(CDOStore.java:427)
at
org.eclipse.emf.internal.cdo.CDOObjectImpl$CDOStoreEList.del egateAdd(CDOObjectImpl.java:666)
at
org.eclipse.emf.common.util.DelegatingEList.addAllUnique(Del egatingEList.java:671)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.doAddAllUnique(DelegatingNotifyingListImpl.java:495)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:436)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:396)
at
org.eclipse.emf.common.util.DelegatingEList.addAll(Delegatin gEList.java:593)
at org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand .java:403)
at
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:129)
at
org.eclipse.emf.common.command.CommandWrapper.execute(Comman dWrapper.java:180)
at
org.eclipse.emf.edit.command.CreateChildCommand.execute(Crea teChildCommand.java:263)
at
org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFC ommandOperation.java:116)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:137)
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
at
com.thalesgroup.mde.tig.ef.internal.command.WorkspaceCommand StackImpl.doExecute(WorkspaceCommandStackImpl.java:125)
>> Hi Eike,
>> at
>> at
>> at
>> at
>> at
>> model changes.
> Cheers
> /Eike
>> Stephane.
>>>> Hi,
>>>> on 'CDORESOURCE'.
>>> the repository.
>>>> file.
>>> Cheers
>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422687 is a reply to message #422685] |
Fri, 12 September 2008 12:55   |
> system is not available. What does it mean ?
Usually an indication that you are trying to attach non-native objects
to a transaction (or a bug).
but from the stack trace I can see that you're not using a brand new CDO
source from HEAD.
Only yesterday we committed substantial changes. Can youplease re-test
with newest HEAD?
Cheers
/Eike
> Transaction, if I succeed ;)
> Stephane.
> system not available
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> Hi Eike,
>> of creating a new resource set
>>> at
>>> at
>>> at
>>> at
>>> at
>>> transaction to really flush data to the database.
>>> model changes.
>> Cheers
>> /Eike
>>> Stephane.
>>>>> Hi,
>>>> a CDOTransaction. This is also true for CDOResource (which is a
>>>> then attached to other objects that are already attached, the new
>>>> objects will also transition from TRANSIENT to NEW.
>>>> in the repository.
>>>> different resourcepath or call transaction.getOrCreateResource(path).
>>>>> log file.
>>>> Cheers
>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422696 is a reply to message #422687] |
Sat, 13 September 2008 15:53   |
Ok Eike,
I'll check-out the latest release immediately.
I will test that on next Monday.
Stephane.
> source from HEAD.
> with newest HEAD?
> Cheers
> /Eike
>> Stephane.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>>> Hi Eike,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> model changes.
>>> Cheers
>>> /Eike
>>>> Stephane.
>>>>>> Hi,
>>>>> in the repository.
>>>>>> log file.
>>>>> Cheers
>>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422697 is a reply to message #422696] |
Sat, 13 September 2008 17:08   |
Comments below.
At home, I can use thunderbird to read newsgroup ouf :)
Stéphane Fournier wrote:
> Ok Eike, I'll check-out the latest release immediately.
> Stephane.
Hi Eike,
I checked out the latest release and I tested again. I got the exception
below.
What does it mean exactly "attach non-native objects"? EMF objects that
do not extend CDO objects ?
I'm sorry if the question is stupid, but to make sure I've correctly
understand.
Stephane.
Exception stack :
at
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl$Persisten tContents.inverseAdd(CDOResourceImpl.java:567)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:448)
at
at
at
at
at
at
at
at
at
at
com.thalesgroup.mde.tig.ef.command.TigCommandStack.doExecute (TigCommandStack.java:40)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:164)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:217)
at
org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction. run(StaticSelectionCommandAction.java:232)
>> CDO source from HEAD.
>> with newest HEAD?
>> Cheers
>> /Eike
>>> Stephane.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>>> Hi Eike,
>>>>> the genmodel as mentionned in the "Preparing EMF Models for CDO"
>>>>> article.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> I try CDO to get a multi-user capability on my existing editor.
>>>>> editing domain.
>>>>> model changes.
>>>> Cheers
>>>> /Eike
>>>>> Stephane.
>>>>>>> Hi,
>>>>>> in the repository.
>>>>>>> log file.
>>>>>>> is an EMF Transactional one.
>>>>>> Cheers
>>>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422720 is a reply to message #422699] |
Mon, 15 September 2008 04:46   |
Thanks folks for your support !
I missed the following point : to create the marker file (CDO.MF).
I can test again mixing CDO transactions and EMFT transactions.
Stephane.
Simon McDuff wrote:
> Hi Stephane,
> CDO do not support Legacy object anymore.
> I know Eike is currently working on a feature in EMF that will allow CDO to
> support easily legacy objects. In my opinion, it is a question of time
> (months. :-)).
> To be able to persist objects through CDO please follow this guideline:
http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO#Modify_ an_Existing_GenModel
> You just need to modify your genmodel.
> Simon
> "Stéphane Fournier" <stephane.fournier@netcourrier.com> a écrit dans le
> message de news: gaha51$145$1@build.eclipse.org...
>> Comments below.
>>> Stephane.
>> Hi Eike,
>> below.
>> When you said :
>> Usually an indication that you are trying to attach non-native objects to
>> What does it mean exactly "attach non-native objects"? EMF objects that do
>> understand.
>> Stephane.
>> Exception stack :
>> not available
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>>> source from HEAD.
>>>> with newest HEAD?
>>>> Cheers
>>>> /Eike
>>>>> Stephane.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>>> Hi Eike,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> domain.
>>>>>>> model changes.
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Stephane.
>>>>>>>>> Hi,
>>>>>>>>> resource.
>>>>>>>>> on 'CDORESOURCE'.
>>>>>>>> in the repository.
>>>>>>>>> file.
>>>>>>>> Cheers
>>>>>>>> /Eike
Re: [CDO] ExtendedLibrary sample with CDO ? [message #422721 is a reply to message #422720] |
Mon, 15 September 2008 05:27  |
Gosh! People always used to criticize me for the lack of documentation
and now you don't read it! :P
> Stephane.
> Simon McDuff wrote:
>> Hi Stephane,
>> CDO to support easily legacy objects. In my opinion, it is a question
>> of time (months. :-)).
>> Simon
>> le message de news: gaha51$145$1@build.eclipse.org...
>>> Comments below.
>>>> Stephane.
>>> Hi Eike,
>>> exception below.
>>> objects to a transaction (or a bug).
>>> that do not extend CDO objects ?
>>> understand.
>>> Stephane.
>>> Exception stack :
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>>> new CDO source from HEAD.
>>>>> re-test with newest HEAD?
>>>>> Cheers
>>>>> /Eike
>>>>>> Stephane.
>>>>>> Legacy system not available
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>>> Hi Eike,
>>>>>>>> in the genmodel as mentionned in the "Preparing EMF Models for
>>>>>>>> CDO" article.
>>>>>>>> transaction.createResource(path) method. I have moved to
>>>>>>>> getOrCreateResource() method. Once, the resource is created, I
>>>>>>>> add it to a resource set owned by a transactional editing domain.
>>>>>>> instead of creating a new resource set
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> domain. I try CDO to get a multi-user capability on my existing
>>>>>>>> editor. This editor is a GMF one that only works with a
>>>>>>>> opening. After every save operation, I would like to commit the
>>>>>>>> CDO transaction to really flush data to the database.
>>>>>>>> listens to model changes.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Stephane.
>>>>>>>>>> Hi,
>>>>>>>>>> from EMF examples) with CDO server ?
>>>>>>>>>> CDO server, open a session, get a transaction and create a
>>>>>>>>>> cdo resource.
>>>>>>>>>> FSMUtil.isTransient(this) always answers true. Is it normal ?
>>>>>>>>> attached to a CDOTransaction. This is also true for
>>>>>>>>> CDOResource (which is a CDOObject, too). How did you create
>>>>>>>>> the CDOResource?
>>>>>>>>> are then attached to other objects that are already attached,
>>>>>>>>> the new objects will also transition from TRANSIENT to NEW.
>>>>>>>>>> would have caused a duplicate key value in a unique or
>>>>>>>>>> primary key constraint or unique index identified by
>>>>>>>>> stored in the repository.
>>>>>>>>>> eclipse log file.
>>>>>>>>>> which is an EMF Transactional one.
>>>>>>>>> Cheers
>>>>>>>>> /Eike
Current Time: Wed Jul 23 12:17:40 EDT 2025
Powered by FUDForum. Page generated in 0.11342 seconds
