Teneo Hibernate Dialect must be explicitly set [message #422691] |
Fri, 12 September 2008 18:31  |
All,
Its my first attempt with teneo and I'm getting an error: "Hibernate
Dialect must be explicitly set".
The dialect is being set in hibernate.properties and the file must be
being read because it also contains things like url, username , etc all of
which are working.
My EMF is trivial and is generated from an xsd. I doubt it is the problem
but I've included it below for good measure. IMHO the
hibernate.properties is also correct.
Any observations?
hibernate.properties:
hibernate.dialect org.hibernate.dialect.MySQLInnoDBDialect
hibernate.connection.driver_class com.mysql.jdbc.Driver
hibernate.connection.url jdbc:mysql://localhost:3306/epicase
hibernate.connection.username epiuser
hibernate.connection.password
xsd file:
<!-- edited with XMLSpy v2006 rel. 3 sp2 (http://www.altova.com) by Gena
Samanc (Apogen Technologies) -->
<xs:schema xmlns="qq.mob.epicase.xsd"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:loc="qq.mob.location.xsd"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
targetNamespace="qq.mob.epicase.xsd" elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xs:complexType name="EpiCase">
<xs:sequence>
<xs:element name="zcta" type="xs:string"/>
<xs:element name="disease" type="xs:string"/>
<xs:element name="stage" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
Re: Teneo Hibernate Dialect must be explicitly set [message #422736 is a reply to message #422735] |
Mon, 15 September 2008 12:19  |
Hi Geoffry,
Yes this was an issue I solved a few weeks back. When you update to the latest 1.0.1 M build of
Teneo then this should be solved.
gr. Martin
Geoffry Roberts wrote:
> Martin Taal wrote:
>> Hi Geoffry,
>> Which version of Teneo are you using? A few weeks back I solved an issue
> My About eclipse plug ins listing shows the version to be:
> 1.1.v200806091234
> It is what was in the ganymede distribution.
> that hibernate.properties
>> were not used by hibernate.
>> Can you check if the hibernate.properties file is indeed copied to the
> output folder? It should be
> Yes, hibernate.properties is indeed in the output folder.
> Just so you'll know, I use Hibernate extensively sans teneo. It is only
> when I try the EMF/teneo that I encounter this problem. As I stated
> before, hibernate.properties is being read, by hibernate. It would
> appear that it's only when teneo gets involved that things go wrong.
>> present in the build.properties of the plugin.
>> gr. Martin
>>> All,
>>> all of which are working.
>>> problem but I've included it below for good measure. IMHO the
>>> Any observations?
>>> xsd file:
>>> <?xml version="1.0" encoding="UTF-8"?>
>>> Gena Samanc (Apogen Technologies) -->
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> </xs:schema>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.05160 seconds
