Home » Modeling » EMF » Re: [emf-dev] Re: Problem loading editor with many ECore Model
Re: [emf-dev] Re: Problem loading editor with many ECore Model [message #422683] |
Fri, 12 September 2008 12:04  |
--------------030402070400040702040003
This mailing list if for developers of EMF, not support of EMF users.
Please use the eclipse.tools.emf newsgroup.
http://www.eclipse.org/modeling/emf/newsgroup-mailing-list.p hp
Nick
Neatsoul wrote:
> In addition to my precedent mail, I would like to add that the
> assertion appears when I have used before loading my editor the
> following instruction : MyObjectPackage.eINSTANCE
> 2008/9/12 Neatsoul <neatsoul33@gmail.com <mailto:neatsoul33@gmail.com>>
> I'm developping a project where I need to have two ECore Model.
> When I'm using only the EObject of my first ECore Model,I can open
> and close "editor" without problem.
> But when i create EObject from the both modelsI have an error when
> I try to open an editor.
> Assert.isTrue(boolean, String) line: 109
> Assert.isTrue(boolean) line: 95
> ProcEditor(MultiPageEditorPart).setActivePage(int) line: 695
> ProcEditor(MultiPageEditorPart).createPartControl(Composite) line:
> 287
> EditorReference.createPartHelper() line: 661
> EditorReference.createPart() line: 426
> EditorReference(WorkbenchPartReference).getPart(boolean) line: 592
> EditorPane(PartPane).setVisible(boolean) line: 299
> PresentablePart.setVisible(boolean) line: 179
> PresentablePartFolder.select(IPresentablePart) line: 268
> LeftToRightTabOrder.select(IPresentablePart) line: 65
> TabbedStackPresentation.selectPart(IPresentablePart) line: 400
> EditorStack(PartStack).refreshPresentationSelection() line: 1256
> EditorStack(PartStack).setSelection(LayoutPart) line: 1209
> EditorStack(PartStack).showPart(LayoutPart, Object) line: 1604
> EditorStack(PartStack).add(LayoutPart, Object) line: 499
> EditorStack.add(LayoutPart, Object) line: 103
> EditorStack(PartStack).add(LayoutPart) line: 485
> EditorStack.add(LayoutPart) line: 112
> EditorSashContainer.addEditor(EditorPane, EditorStack) line: 63
> EditorAreaHelper.addToLayout(EditorPane, EditorStack) line: 217
> EditorAreaHelper.addEditor(EditorReference, String) line: 207
> EditorManager.createEditorTab(EditorReference, String) line: 774
> EditorManager.openEditorFromDescriptor(EditorDescriptor,
> IEditorInput, IMemento) line: 673
> EditorManager.openEditor(String, IEditorInput, boolean, IMemento)
> line: 634
> WorkbenchPage.busyOpenEditorBatched(IEditorInput, String, boolean,
> int, IMemento) line: 2737
> WorkbenchPage.busyOpenEditor(IEditorInput, String, boolean, int,
> IMemento) line: 2651
> WorkbenchPage.access$13(WorkbenchPage, IEditorInput, String,
> boolean, int, IMemento) line: 2643
> WorkbenchPage$10.run() line: 2595
> BusyIndicator.showWhile(Display, Runnable) line: 67
> WorkbenchPage.openEditor(IEditorInput, String, boolean, int,
> IMemento) line: 2590
> WorkbenchPage.openEditor(IEditorInput, String, boolean, int) line:
> 2574
> WorkbenchPage.openEditor(IEditorInput, String) line: 2557
> DataEditorAdvisor.openEditor(IWorkbench, URI) line: 472
> DataEditorAdvisor$OpenAction.run(IAction) line: 400
> WWinPluginAction(PluginAction).runWithEvent(Event) line: 256
> WWinPluginAction.runWithEvent(Event) line: 229
> PluginActionContributionItem(ActionContributionItem).handleW idgetSelection(Event,
> boolean) line: 546
> ActionContributionItem.access$2(ActionContributionItem, Event,
> boolean) line: 490
> ActionContributionItem$5.handleEvent(Event) line: 402
> EventTable.sendEvent(Event) line: 66
> MenuItem(Widget).sendEvent(Event) line: 938
> Display.runDeferredEvents() line: 3682
> Display.readAndDispatch() line: 3293
> Workbench.runEventLoop(Window$IExceptionHandler, Display) line:
> 2389
> Workbench.runUI() line: 2353
> Workbench.access$4(Workbench) line: 2219
> Workbench$4.run() line: 466
> Realm.runWithDefault(Realm, Runnable) line: 289
> Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line:
> 461
> PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line:
> 149
> DataEditorAdvisor$Application.start(IApplicationContext) line: 105
> EclipseAppHandle.run(Object) line: 169
> EclipseAppLauncher.runApplication(Object) line: 106
> EclipseAppLauncher.start(Object) line: 76
> EclipseStarter.run(Object) line: 363
> EclipseStarter.run(String[], Runnable) line: 176
> NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line:
> not available [native method]
> NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
> DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
> Method.invoke(Object, Object...) line: 585
> Main.invokeFramework(String[], URL[]) line: 508
> Main.basicRun(String[]) line: 447
> Main.run(String[]) line: 1173
> Main.main(String[]) line: 1148
> Thanks you for your help !
> Best Regards
> _______________________________________________
> emf-dev mailing list
> emf-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/emf-dev
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
<br>
<br>
<a class="moz-txt-link-freetext"
href=" http://www.eclipse.org/modeling/emf/newsgroup-mailing-list.p hp"> http://www.eclipse.org/modeling/emf/newsgroup-mailing-list.p hp</a>
<br>
<br>
<br>
<br>
Nick
<br>
<br>
Neatsoul wrote:
<blockquote
cite="mid:c379d1ee0809120858o7169d1bdn4631805fb5e5b5df@mail.gmail.com"
type="cite">
<div dir="ltr">In addition to my precedent mail, I would like to add
that the assertion appears when I have used before loading my editor
the following instruction : MyObjectPackage.eINSTANCE<br>
<br>
<div class="gmail_quote">2008/9/12 Neatsoul <span dir="ltr"><<a
moz-do-not-send="true" href="mailto:neatsoul33@gmail.com">neatsoul33@gmail.com</a>></span><br>
<blockquote class="gmail_quote"
style="border-left: 1px solid rgb(204, 204, 204); margin: 0pt 0pt 0pt 0.8ex; padding-left: 1ex;">
<div dir="ltr">Hi,<br>
<br>
I'm developping a project where I need to have two ECore Model. When
I'm using only the EObject of my first ECore Model,I can open and close
"editor" without problem.<br>
But when i create EObject from the both modelsI have an error when I
try to open an editor.<br>
<br>
Assert.isTrue(boolean, String) line: 109 <br>
Assert.isTrue(boolean) line: 95 <br>
ProcEditor(MultiPageEditorPart).setActivePage(int) line: 695 <br>
287 <br>
EditorReference.createPartHelper() line: 661 <br>
EditorReference.createPart() line: 426 <br>
EditorReference(WorkbenchPartReference).getPart(boolean) line: 592 <br>
EditorPane(PartPane).setVisible(boolean) line: 299 <br>
PresentablePart.setVisible(boolean) line: 179 <br>
PresentablePartFolder.select(IPresentablePart) line: 268 <br>
LeftToRightTabOrder.select(IPresentablePart) line: 65 <br>
TabbedStackPresentation.selectPart(IPresentablePart) line: 400 <br>
EditorStack(PartStack).refreshPresentationSelection() line: 1256 <br>
EditorStack(PartStack).setSelection(LayoutPart) line: 1209 <br>
EditorStack(PartStack).showPart(LayoutPart, Object) line: 1604 <br>
EditorStack(PartStack).add(LayoutPart, Object) line: 499 <br>
EditorStack.add(LayoutPart, Object) line: 103 <br>
EditorStack(PartStack).add(LayoutPart) line: 485 <br>
EditorStack.add(LayoutPart) line: 112 <br>
EditorSashContainer.addEditor(EditorPane, EditorStack) line: 63 <br>
EditorAreaHelper.addToLayout(EditorPane, EditorStack) line: 217 <br>
EditorAreaHelper.addEditor(EditorReference, String) line: 207 <br>
EditorManager.createEditorTab(EditorReference, String) line: 774 <br>
EditorManager.openEditorFromDescriptor(EditorDescriptor, IEditorInput,
IMemento) line: 673 <br>
EditorManager.openEditor(String, IEditorInput, boolean, IMemento) line:
634 <br>
WorkbenchPage.busyOpenEditorBatched(IEditorInput, String, boolean, int,
IMemento) line: 2737 <br>
IMemento) line: 2651 <br>
WorkbenchPage.access$13(WorkbenchPage, IEditorInput, String, boolean,
int, IMemento) line: 2643 <br>
WorkbenchPage$10.run() line: 2595 <br>
BusyIndicator.showWhile(Display, Runnable) line: 67 <br>
WorkbenchPage.openEditor(IEditorInput, String, boolean, int, IMemento)
line: 2590 <br>
2574 <br>
WorkbenchPage.openEditor(IEditorInput, String) line: 2557 <br>
DataEditorAdvisor.openEditor(IWorkbench, URI) line: 472 <br>
DataEditorAdvisor$OpenAction.run(IAction) line: 400 <br>
WWinPluginAction(PluginAction).runWithEvent(Event) line: 256 <br>
WWinPluginAction.runWithEvent(Event) line: 229 <br>
boolean) line: 546 <br>
ActionContributionItem.access$2(ActionContributionItem, Event, boolean)
line: 490 <br>
ActionContributionItem$5.handleEvent(Event) line: 402 <br>
EventTable.sendEvent(Event) line: 66 <br>
MenuItem(Widget).sendEvent(Event) line: 938 <br>
Display.runDeferredEvents() line: 3682 <br>
Display.readAndDispatch() line: 3293 <br>
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2389
<br>
Workbench.runUI() line: 2353 <br>
Workbench.access$4(Workbench) line: 2219 <br>
Workbench$4.run() line: 466 <br>
Realm.runWithDefault(Realm, Runnable) line: 289 <br>
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 461
<br>
149 <br>
DataEditorAdvisor$Application.start(IApplicationContext) line: 105 <br>
EclipseAppHandle.run(Object) line: 169 <br>
EclipseAppLauncher.runApplication(Object) line: 106 <br>
EclipseAppLauncher.start(Object) line: 76 <br>
EclipseStarter.run(Object) line: 363 <br>
EclipseStarter.run(String[], Runnable) line: 176 <br>
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
available [native method] <br>
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39 <br>
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25 <br>
Method.invoke(Object, Object...) line: 585 <br>
Main.invokeFramework(String[], URL[]) line: 508 <br>
Main.basicRun(String[]) line: 447 <br>
Main.run(String[]) line: 1173 <br>
Main.main(String[]) line: 1148 <br>
<br>
<br>
Thanks you for your help !<br>
<br>
Best Regards<br>
<br>
</div>
</blockquote>
</div>
<br>
</div>
<pre wrap="">
<hr size="4" width="90%">
<a class="moz-txt-link-abbreviated" href="mailto:emf-dev@eclipse.org">emf-dev@eclipse.org</a>
<a class="moz-txt-link-freetext" href="https://dev.eclipse.org/mailman/listinfo/emf-dev">https://dev.eclipse.org/mailman/listinfo/emf-dev</a>
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="72">--
Eclipse Modeling :: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/modeling">http://www.eclipse.org/modeling</a>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/index.php/User:Nickb">http://wiki.eclipse.org/index.php/User:Nickb</a>
</pre>
</body>
</html>
--------------030402070400040702040003--
Re: [emf-dev] Re: Problem loading editor with many ECore Model [message #422688 is a reply to message #422683] |
Fri, 12 September 2008 13:42  |
--------------050700080107060307010907
It sounds likely that something earlier on failed to create any pages at
all. Use the debugger to step through the code to determine what might
be going wrong. Also check the log for prior exceptions since this one
appears more to be a symptom of something more primary...
> Cheers,
> Nick
>> Hi,
>> open and close "editor" without problem.
>> when I try to open an editor.
>> line: 287
>> 592
>> line: 634
>> boolean, int, IMemento) line: 2737
>> line: 2574
>> boolean) line: 546
>> boolean) line: 490
>> 2389
>> 461
>> 149
>> 105
>> Best Regards
>> emf-dev@eclipse.org
<html>
<head>
</head>
at all. Use the debugger to step through the code to determine what
might be going wrong. Also check the log for prior exceptions since
this one appears more to be a symptom of something more primary...<br>
<br>
<br>
Nick Boldt wrote:
<blockquote cite="mid:48CA931E.8000308@ca.ibm.com" type="cite">
<br>
<br>
<a moz-do-not-send="true" class="moz-txt-link-freetext"
<br>
<br>
<br>
<br>
Nick
<br>
<br>
Neatsoul wrote:
<blockquote
type="cite">
add
<br>
<br>
<br>
287 <br>
634 <br>
line: 2590 <br>
2574 <br>
line: 490 <br>
<br>
<br>
149 <br>
<br>
<br>
<br>
Best Regards<br>
<br>
</div>
</blockquote>
</div>
<br>
</div>
<pre wrap=""><hr size="4" width="90%">
<a moz-do-not-send="true" class="moz-txt-link-abbreviated"
</pre>
</blockquote>
<br>
Eclipse Modeling :: <a moz-do-not-send="true"
</pre>
</blockquote>
</body>
</html>
--------------050700080107060307010907--
Current Time: Fri Jul 25 22:13:14 EDT 2025
Powered by FUDForum. Page generated in 0.07240 seconds
