Home » Modeling » EMF » [Teneo] Different generation using opposite
[Teneo] Different generation using opposite [message #422587] Wed, 10 September 2008 10:20 Go to next message
I am getting the FK for a 0..1 cardinality set in the optional table in
one case and the parent in the other case using the same annotations as
here. I have stripped out the bulk of the references and attributes for
clarity
<xsd:complexType name="IssueData">
<xsd:sequence minOccurs="0" maxOccurs="1">
<xsd:element minOccurs="0" maxOccurs="1"
ref="gensec:instrumentDomain" ecore:opposite="issueData"/>
<xsd:element minOccurs="0" maxOccurs="unbounded" </xsd:sequence>
<xsd:attribute name="id" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Id
@GeneratedValue(strategy=IDENTITY)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:element name="issueData" type="gensec:IssueData" />
<xsd:complexType name="DebtIssueData">
ref="gensec:instrumentDomain" ecore:opposite="debtIssueData"/>
<xsd:annotation>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:element name="debtIssueData" type="gensec:DebtIssueData" />
<xsd:complexType name="InstrumentDomain">
<xsd:sequence>
ref="gensec:instrumentType" />
</xsd:sequence>
<xsd:annotation>
@Id @GeneratedValue(strategy=IDENTITY)
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:element name="instrumentDomain" type="gensec:InstrumentDomain" />
what I end up with in the database is InstrumentDomain table with a FK
called ISSUEDATA that points to IssueData table. And I get a FK in
DebtIssueData table called INSTRUMENTDOMAIN that points to
InstrumentDomain.
So why is this inconsistent? What I really wanted is that for all
InstrumentDomain references to other elements that have 0..1 cardinality
to have the FK in the optional table, in my example here IssueData and
DebtIssueData would have FKs called issuedata_instrumentdomain and
debtissuedata_instrumentdomain respectively.
You may remember that I did have this
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="1" ref="gensec:debtIssueData"
ecore:opposite="instrumentDomain"/>
<xsd:element minOccurs="0" maxOccurs="1" ref="gensec:issueData"
</xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
I expected that to put the FK into the IssueData and DebtIssueData
respectively. But it does consistently (unlike the above case) put the
FK column into InstrumentDomain table.
Is there any way for me to achieve what I need? I need it because the
data is loaded with a loader that expects the FK to be in the IssueData
and DebtIssueData and any optional element that has a 1 to 1
relationship with another element.
David
Re: [Teneo] Different generation using opposite [message #422597 is a reply to message #422587] Wed, 10 September 2008 16:39 Go to previous messageGo to next message
Hi David,
You can force the location of the key field by setting the PrimaryKeyJoinColumn annotation on the
side where you want the fk field to be.
It this does not help can you post the generated hbm for the reference elements from
InstrumentDomain to IssueData and DebtIssueData (and their opposite)?
gr. Martin
David Wynter wrote:
> clarity
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> InstrumentDomain.
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Different generation using opposite [message #422598 is a reply to message #422597] Wed, 10 September 2008 18:14 Go to previous messageGo to next message
The only example of the use of the PrimaryKeyJoinColumn is as follows
<xsd:annotation>
@SecondaryTable(name="THETONER"
pkJoinColumns={@PrimaryKeyJoinColumn(name="PRINTER_ID")})
</xsd:appinfo>
</xsd:annotation>
So to confirm its use in my case this would mean that IssueData would
look like this?
<xsd:annotation>
@SecondaryTable(name="InstrumentDomain"
pkJoinColumns={@PrimaryKeyJoinColumn(name="id")})
</xsd:appinfo>
</xsd:annotation>
</xsd:sequence>
<xsd:annotation>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
This works for the default TeneoSQLNameStrategy?
Thx.
David
Martin Taal wrote:
> Hi David,
> PrimaryKeyJoinColumn annotation on the side where you want the fk field
> to be.
> elements from InstrumentDomain to IssueData and DebtIssueData (and their
> opposite)?
> gr. Martin
> David Wynter wrote:
>> Hi,
>> in one case and the parent in the other case using the same
>> annotations as here. I have stripped out the bulk of the references
>> and attributes for clarity
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> InstrumentDomain.
>> cardinality to have the FK in the optional table, in my example here
>> IssueData and DebtIssueData would have FKs called
>> issuedata_instrumentdomain and debtissuedata_instrumentdomain
>> respectively.
>> <xsd:sequence>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> IssueData and DebtIssueData and any optional element that has a 1 to 1
>> David
Re: [Teneo] Different generation using opposite [message #422599 is a reply to message #422598] Wed, 10 September 2008 18:19 Go to previous messageGo to next message
Hi David,
The primarykeyjoincolumn should be placed in the following element:
so something like this:
<xsd:element minOccurs="0" maxOccurs="1" ref="gensec:instrumentDomain" ecore:opposite="issueData">
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
gr. Martin
David Wynter wrote:
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> look like this?
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> field to be.
>> their opposite)?
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> FK called ISSUEDATA that points to IssueData table. And I get a FK in
>>> InstrumentDomain.
>>> respectively.
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> the FK column into InstrumentDomain table.
>>> 1 relationship with another element.
>>> David
The Netherlands
Re: [Teneo] Different generation using opposite [message #422652 is a reply to message #422599] Thu, 11 September 2008 17:50 Go to previous messageGo to next message
Been using the annotation you showed below on my large model.
I get this
Exception in thread "main" java.lang.StackOverflowError
at java.util.AbstractList$Itr.next(Unknown Source)
at org.hibernate.util.JoinedIterator.next(JoinedIterator.java:5 3)
at
org.hibernate.mapping.PersistentClass.getProperty(Persistent Class.java:409)
at
org.hibernate.mapping.PersistentClass.getRecursiveProperty(P ersistentClass.java:391)
at
org.hibernate.mapping.PersistentClass.getReferencedProperty( PersistentClass.java:336)
at
org.hibernate.cfg.Configuration$1.getReferencedPropertyType( Configuration.java:2066)
at
org.hibernate.type.EntityType.getIdentifierOrUniqueKeyType(E ntityType.java:515)
at
org.hibernate.type.EntityType.getIdentifierOrUniqueKeyType(E ntityType.java:517)
at
at
at
at
at
at
at
at
When I generate the schema now, but it does generate OK. But though you
might be interested.
David
Martin Taal wrote:
> Hi David,
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> gr. Martin
> David Wynter wrote:
>> Hi,
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> look like this?
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> field to be.
>>> reference elements from InstrumentDomain to IssueData and
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> in DebtIssueData table called INSTRUMENTDOMAIN that points to
>>>> InstrumentDomain.
>>>> respectively.
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> the data is loaded with a loader that expects the FK to be in the
>>>> David
Re: [Teneo] Different generation using opposite [message #422657 is a reply to message #422652] Fri, 12 September 2008 01:16 Go to previous messageGo to next message
Hi David,
Hibernate walks through the associations therefore the call-stack is pretty long. I am surprised
that it works fine eventhough you get this exception.
gr. Martin
David Wynter wrote:
> I get this
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> David
> Martin Taal wrote:
>> Hi David,
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:element>
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> look like this?
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> field to be.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> table in one case and the parent in the other case using the same
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> <xsd:sequence>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> InstrumentDomain.
>>>>> here IssueData and DebtIssueData would have FKs called
>>>>> respectively.
>>>>> <xsd:sequence>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> to 1 relationship with another element.
>>>>> David
The Netherlands
Re: [Teneo] Different generation using opposite [message #422669 is a reply to message #422657] Fri, 12 September 2008 07:50 Go to previous messageGo to next message
Hi Martin,
I'm working with David, trying to do the Hibernate searches for the code
his model generates and the problem above is not just encountered on
generation. We can't actually store objects any more.
The stack trace on a JUnit test setup() looks like this:
java.lang.ExceptionInInitializerError
at com.stpware.secm.dwr.HibernateUtil.<clinit>
(HibernateUtil.java:78)
at com.stpware.secm.dwr.TestSearchEquity.setUp
(TestSearchEquity.java:40)
at junit.framework.TestCase.runBare(TestCase.java:128)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run
(JUnit3TestReference.java:130)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run
(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts
(RemoteTestRunner.java:460)
(RemoteTestRunner.java:673)
(RemoteTestRunner.java:386)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main
(RemoteTestRunner.java:196)
Caused by: java.lang.StackOverflowError
at java.util.Arrays.copyOf(Arrays.java:2760)
at java.util.ArrayList.toArray(ArrayList.java:305)
at org.hibernate.util.JoinedIterator.<init>(JoinedIterator.java:33)
at org.hibernate.mapping.PersistentClass.getPropertyIterator
(PersistentClass.java:541)
at org.hibernate.mapping.RootClass.getPropertyClosureIterator
(RootClass.java:87)
at
org.hibernate.mapping.PersistentClass.getReferenceableProper tyIterator
(PersistentClass.java:321)
at org.hibernate.mapping.PersistentClass.getReferencedProperty
(PersistentClass.java:336)
at org.hibernate.cfg.Configuration$1.getReferencedPropertyType
(Configuration.java:2066)
at org.hibernate.type.EntityType.getIdentifierOrUniqueKeyType
(EntityType.java:515)
(EntityType.java:517)
...followed by thousands of the same line until DEATH.
I think David is going to send you the xsd directly as it is far too larg
to paste here!
Neil
On Fri, 12 Sep 2008 07:16:09 +0200, Martin Taal wrote:
> Hi David,
> pretty long. I am surprised that it works fine eventhough you get this
> exception.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> I get this
>> at java.util.AbstractList$Itr.next(Unknown Source) at
>> org.hibernate.util.JoinedIterator.next(JoinedIterator.java:5 3) at
(PersistentClass.java:409)
>> at
(PersistentClass.java:391)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> look like this?
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> field to be.
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> InstrumentDomain.
>>>>>> respectively.
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> David
Re: [Teneo] Different generation using opposite [message #422681 is a reply to message #422657] Fri, 12 September 2008 11:42 Go to previous messageGo to next message
I finally narrowed this issue down. It is the addition of the
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
That appears to cause the exception. I checked out the version of my xsd
that was prior to adding these new annotations to control which end of a
0..1 relationship the FK was placed. Just the addition of a single one
of these annotations causes the StackOverflowException.
Thx.
David
Martin Taal wrote:
> Hi David,
> exception.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> I get this
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> you might be interested.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> would look like this?
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> field to be.
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> references and attributes for clarity
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> a FK called ISSUEDATA that points to IssueData table. And I get a
>>>>>> FK in DebtIssueData table called INSTRUMENTDOMAIN that points to
>>>>>> InstrumentDomain.
>>>>>> respectively.
>>>>>> <xsd:sequence>
>>>>>> ref="gensec:debtIssueData" ecore:opposite="instrumentDomain"/>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> David
Re: [Teneo] Different generation using opposite [message #422718 is a reply to message #422681] Sun, 14 September 2008 18:24 Go to previous messageGo to next message
I had a close look at the generated hibernate.hbm.xml and it is
generated with identical treatments for debtIssueData and issueData.
Which suggests that the in memory model that Teneo generates and uses is
different to that that would be generated by the hibernate.hbm.xml.
Unfortunately when I tried to get it to use that hibernate.hbm.xml using
both the PersistanceOptions.MAPPING_FILE_PATH with either relative or
full pathnames it got a HbStoreException and could not find the file. I
also tried the USE_MAPPING_FILE = true and it ran at least but produced
no schema.
I am on Windows XP using 1.0.1 Teneo.
David
David Wynter wrote:
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> exception.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> I get this
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> field to be.
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> <xsd:sequence>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> InstrumentDomain.
>>>>>>> respectively.
>>>>>>> <xsd:sequence>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> DebtIssueData respectively. But it does consistently (unlike the
>>>>>>> above case) put the FK column into InstrumentDomain table.
>>>>>>> David
Re: [Teneo] Different generation for 0..2 [message #422723 is a reply to message #422718] Mon, 15 September 2008 07:01 Go to previous messageGo to next message
I cannot find a way forward with this problem.
In the end I decided to try to force the FK in the entities related 0..1
to instrumentDomain by adding these
<xsd:element ecore:opposite="instrumentDomain" minOccurs="0"
maxOccurs="2" ref="gensec:lastCAE" />
maxOccurs="2" ref="gensec:debtIssueData" />
maxOccurs="2" ref="gensec:issueData" />
i.e. forcing the FK in a 0..2 relationship. The hibernate.hbm.xml
generated does not make sense. Here are the 3 0..2 I show above as
inside the
<class name="com.stpenable.gensec.impl.InstrumentDomainImpl"
entity-name="InstrumentDomain" abstract="false" lazy="false"
table="`instrumentdomain`">
<one-to-one name="lastCAE" entity-name="LastCAE"
foreign-key="instrumentdomain_lastcae" cascade="all" lazy="false"
property-ref="instrumentDomain"/>
the other 2 do not appear!!!!!!
They appear as
<one-to-one name="instrumentDomain" entity-name="InstrumentDomain"
foreign-key="issuedata_instrumentdomain" cascade="all" lazy="false"
constrained="true"/>
inside the
<class name="com.stpenable.gensec.impl.IssueDataImpl"
entity-name="IssueData" abstract="false" lazy="false" table="`issuedata`">
and as
foreign-key="debtissuedata_instrumentdomain" cascade="all" lazy="false"
property-ref="debtIssueData"/>
inside the
<class name="com.stpenable.gensec.impl.DebtIssueDataImpl"
entity-name="DebtIssueData" abstract="false" lazy="false"
table="`debtissuedata`">
How can it treat the same annotation (0..2) completely differently?? Is
this a bug?
David
David Wynter wrote:
> no schema.
> David
> David Wynter wrote:
>> Hi,
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:element>
>> xsd that was prior to adding these new annotations to control which
>> end of a 0..1 relationship the FK was placed. Just the addition of a
>> single one of these annotations causes the StackOverflowException.
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> this exception.
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> I get this
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> field to be.
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> same annotations as here. I have stripped out the bulk of the
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> <xsd:sequence>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> with a FK called ISSUEDATA that points to IssueData table. And I
>>>>>>>> get a FK in DebtIssueData table called INSTRUMENTDOMAIN that
>>>>>>>> points to InstrumentDomain.
>>>>>>>> all InstrumentDomain references to other elements that have 0..1
>>>>>>>> respectively.
>>>>>>>> <xsd:sequence>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> because the data is loaded with a loader that expects the FK to
>>>>>>>> be in the IssueData and DebtIssueData and any optional element
>>>>>>>> that has a 1 to 1 relationship with another element.
>>>>>>>> David
Re: [Teneo] Different generation for 0..2 [message #422724 is a reply to message #422723] Mon, 15 September 2008 07:07 Go to previous message
Hi David,
What do you see generated on the java side? I would expect that the maxOccurs="2" will generate a
list in java. This should then generate a one-to-many in hibernate.
Btw, would it be possible for me to send me your complete model (by email)? This would help me to
look in more detail at the issues you encounter.
gr. Martin
David Wynter wrote:
> inside the
> They appear as
> entity-name="InstrumentDomain" foreign-key="issuedata_instrumentdomain"
> cascade="all" lazy="false" constrained="true"/>
> inside the
> and as
> inside the
> this a bug?
> David
> David Wynter wrote:
>> Hi,
>> is different to that that would be generated by the hibernate.hbm.xml.
>> using both the PersistanceOptions.MAPPING_FILE_PATH with either
>> relative or full pathnames it got a HbStoreException and could not
>> find the file. I also tried the USE_MAPPING_FILE = true and it ran at
>> least but produced no schema.
>> David
>> David Wynter wrote:
>>> Hi,
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> this exception.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> I get this
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:element>
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> follows
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> fk field to be.
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> <xsd:sequence>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> I get a FK in DebtIssueData table called INSTRUMENTDOMAIN that
>>>>>>>>> 0..1 cardinality to have the FK in the optional table, in my
>>>>>>>>> example here IssueData and DebtIssueData would have FKs called
>>>>>>>>> respectively.
>>>>>>>>> <xsd:sequence>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> the above case) put the FK column into InstrumentDomain table.
>>>>>>>>> David
The Netherlands
Previous Topic:[CDO] ExtendedLibrary sample with CDO ?
Next Topic:[CDO]: CDO Resource Launcher
Current Time: Sun Jul 27 06:39:56 EDT 2025
Powered by FUDForum. Page generated in 0.31860 seconds
