Home » Modeling » EMF » [CDO]: CDO Resource Launcher
[CDO]: CDO Resource Launcher [message #422580] |
Wed, 10 September 2008 03:22  |
Hi ViK!
I tested this stuff yesterday and I got everything rolling fine (I use a
ganymede ide, cdo/net4j bundles from cvs and a target platform built a
month ago).
I really like the idea and I think its even better than to provide a
preferences page as I wanted in bug 242230 (it's more flexible). Let me
try to sum up what could be done to this. I'd be happy to provide stuff
here:
- component to display cdo launcher files in a common navigator
- wizards to create launcher files
- launch compare view to compare 2 resources
- any further ideas?
Cheers
André
Re: [CDO]: CDO Resource Launcher [message #422581 is a reply to message #422580] |
Wed, 10 September 2008 05:38   |
Hi André,
> month ago).
Great that everything worked fine :D
I agree in the part of having a server page preferences. Indeed, I've
already have a preferences page for our product, where you store just
repository URIs. This central place for URIs is then used in wizards,
allowing the user to choose a repository.
So, I agree that we could store Session information in a preferences
page, but I find storing Views (or Transactions or Audits) a bit
redundant, since that information is already stored in a launcher model.
Furthermore, the ideas described in the bug (the drop down menu and
such) also somehow collide with the idea of the launcher. The main idea
of the launcher was to allow the user having a file in the common
navigator representing a model stored in a CDO Server, trying to imitate
the "models as files". Of course, the 242230 would be a great
enhancement, but would give the same functionality for something that
the launcher already does: two ways to do the same thing.
Let me
> here:
What do you mean here? The launcher is a file, so it will already be
showed up as an IFile in the navigator.
The wizard would allow you to select sessions (Repository URI) from the
registry, right?
Great! This will imply working on EMF Compare integration with CDO.
Shouldn't be a prob, just passing teh 2 root objects to compare. Eike
told me that the server might need some cache tweaking ...
Any comments, Eike?
Not at the time, but I'm sure plenty will eventually emerge :)
> Cheers
> André
Cheers!
ViK
Re: [CDO]: CDO Resource Launcher [message #422582 is a reply to message #422581] |
Wed, 10 September 2008 05:52   |
The term "server preferences" always confuses me because we really mean
client side preferences. Can we call it "session preferences"?
Isn't that true for session properties as well?
> idea of the launcher was to allow the user having a file in the common
> imitate the "models as files". Of course, the 242230 would be a great
I think the whole *preferences* idea collides with the launcher model.
Both approaches support infrastructure creation from information
persistent somewhere on the client. Only the exact location of the
persistent information differs: Workspace vs. PreferencePage.
With the wizards you talked about available we could perhaps implement
the PreferencePage-based approach by using the launcher model
internally. What do you think?
> the registry, right?
No, I think the wizards would support the creation of configuration data
for the various components.
With the launcher model (which also represents a form of a registry) we
don't need the registries anymore.
> Any comments, Eike?
Hmm, I can't remember anymore and I don't see the relation. You must
help me ;-)
Cheers
/Eike
Re: [CDO]: CDO Resource Launcher [message #422583 is a reply to message #422582] |
Wed, 10 September 2008 06:25   |
Eike,
comments below
Agree! I also like to call it "CDO repository preferences". But let's go
on with "session preferences" :P
Yes, but I see the session preferences more like a little help for
wizards: If a session preferences doesn't exist, the user would have to
write the repository URI in a wizard each time they want a retrieve a
resource from the same repository. Instead, having a session
preferences, the user only needs to choose it from a dialog.
Furthermore, with the new patch of "query resources", the user doesn't
need to enter the resource path either: he would be also able to choose
the resource from a dialog as well.
At the end, the generated CDOLauncher would contain all the information
needed to open a session/view/transaction/audit over a resource.
Sure, both collide, but I think we could get the most of both.
The model approach has two additional advantage: the launcher is
shareable among clients, and is easily shown in the navigator as a file,
behaving like a "direct link" to the resource. The preference page
configuration is not shareable, and we would need work how to show
preferences data as a IResource in the navigator (I really think is a
cool idea having it in the navigator) :(
But we would loose a good point of the model approach, which is having
it in the common navigator.
Ok, I get your point now. I think having the model as a registry is a
nice idea, but I still miss the good feature of having it in the common
navigator. If you find a way to workaround that, I'll agree. Otherwise,
I will agree as well, it's you project, your decisions :P :P
And don't forget also the "shareable" feature of the original approach.
I guess the "registry model" could also be shareable.
>> Any comments, Eike?
> help me ;-)
You suggested that the object graph could end up being loaded totally...
And I think the same as well. That could be kind of inefficient for the
CDO Server.
> Cheers
> /Eike
Re: [CDO]: CDO Resource Launcher [message #422584 is a reply to message #422583] |
Wed, 10 September 2008 06:45   |
>>> model.
> to write the repository URI in a wizard each time they want a retrieve
> a resource from the same repository. Instead, having a session
I'm not sure if I understand completely. The repository information
would be in a file. So for a combo box (or similar) we'd only need a
mechanism to determine all such files, right?
> choose the resource from a dialog as well.
> information needed to open a session/view/transaction/audit over a
> resource.
>>> common navigator representing a model stored in a CDO Server, trying
>>> to imitate the "models as files". Of course, the 242230 would be a
>>> great enhancement, but would give the same functionality for
>>> something that the launcher already does: two ways to do the same
>>> thing.
>> model. Both approaches support infrastructure creation from
>> information persistent somewhere on the client. Only the exact
>> location of the persistent information differs: Workspace vs.
>> PreferencePage.
> file, behaving like a "direct link" to the resource. The preference
> page configuration is not shareable, and we would need work how to
> show preferences data as a IResource in the navigator (I really think
> is a cool idea having it in the navigator) :(
Please note that a preference page is not required to store the
configuration values in an IPreferenceStore!
We can also use the launcher model files if we store them somewhere in
the configuration area.
Then we can reuse not only the persistent format and save/load
implementation but also the wizards that create the files and their
content...
>> implement the PreferencePage-based approach by using the launcher
>> model internally. What do you think?
No, this approach would still be fully included.
>> data for the various components.
>> we don't need the registries anymore.
> common navigator. If you find a way to workaround that, I'll agree.
> Otherwise, I will agree as well, it's you project, your decisions :P :P
I don't see the problem. It's "just" an EMF model, i.e. a forrest of
EObjects. We should care from where these were loaded.
> approach. I guess the "registry model" could also be shareable.
You mean being able to share, let's say, a configured connector instance
among multiple sessions?
All this is still in the launcher model.
I only recommend to reuse this cool model for the implementation of the
preference pages, together with a different storage location (maybe just
a URIHandler is needed to redirect I/O).
>>> Eike told me that the server might need some cache tweaking ...
>>> Any comments, Eike?
>> help me ;-)
> the CDO Server.
While completly loading the compared resources is more than probable, I
don't see a way to prevent that.
They are loaded because their content is needed, right?
Cheers
/Eike
Re: [CDO]: CDO Resource Launcher [message #422591 is a reply to message #422581] |
Wed, 10 September 2008 13:53   |
Originally posted by: andras.okros.optxware.com
Hello Victor,
Maybe I do something wrong, but I only see the root elements in the
resource after loading it (no attributes, or anything else). The editor
I use is good (a CDO enhanced one), because it works with my own plain
xml file based loader well.
Thanks in advance if you have some ideas, what can be wrong. (I use the
CDO version 1.0.0.v200806180411) Let me know, if you need some more
information about this.
András
Víctor Roldán Betancort írta:
> Hi André,
>> a ganymede ide, cdo/net4j bundles from cvs and a target platform built
>> a month ago).
> Cheers!
> ViK
Re: [CDO]: CDO Resource Launcher [message #422593 is a reply to message #422591] |
Wed, 10 September 2008 14:11   |
Hi András,
Uhm, strange...
Are you sure you are using the generated enhanced editor? I mean, you
properly set the generated ID in the launcher model attribute
"editorId", right? (it's, by default, the same as the original editor
ID, but ended in "enhanced", if I recall correctly. you can see it in
the plugin.xml at the extensions tab).
Could you try to launch the resource using CDOEditor instead? (its ID is
"org.eclipse.emf.cdo.ui.CDOEditor") and see if you get the same behaviour?
That's almost the Ganymede's code, I believe (CDO project page shows
"200806241000" available to download. Mark was also experiencing some
problems with the initial Ganymede release. I'm not sure about what
could be happening... I always suggest to try out the HEAD code...
I haven't tried out yet the launcher with Ganymede release.
I'll go on with it tomorrow and let you now know :D
ViK.
Re: [CDO]: CDO Resource Launcher [message #422611 is a reply to message #422593] |
Thu, 11 September 2008 05:58   |
Hi Vik,
The launcher has the same behaviour with the CDOEditor
(org.eclipse.emf.cdo.ui.CDOEditor).
I haven't tried it out with the HEAD, however I get it working by
inserting the
session.getPackageRegistry().putEPackage(OurModelPackage.eIN STANCE);
code into the CDOEditorLauncher. Although it is not a good general approach.
Maybe the Automatic Package Registry doesn't works well? Do you have any
tips?
András
> Hi András,
>> editor I use is good (a CDO enhanced one), because it works with my
>> own plain xml file based loader well.
> Uhm, strange...
>> the CDO version 1.0.0.v200806180411) Let me know, if you need some
>> more information about this.
> Cheers,
> ViK.
Re: [CDO]: CDO Resource Launcher [message #422612 is a reply to message #422611] |
Thu, 11 September 2008 06:14   |
Hi András,
I've already tried out in a clean Ganymede release, and everything seems
to work fine for me :S
Just detected a small bug that triggers the launching once the wizard
creates an instance, since by default the wizard tries to open the
editor, and in this case, it finds the "launch" action as default action
(dunno why... maybe setting content-type priority to low...)
If it works that way for you, it means the auto-registry is not
registering your model properly. Some of the reasons could be:
- The model code is not native (although I believe dynamic mode should
work).
- (most probably) The model is not registered in the EMF registry. Are
you running the launcher file in the same workspace where the model's
code is located? Have you tried running the launcher in a
runtime-workbench? (run -> run-as -> Eclipse Application)
HTH,
ViK.
András Ökrös escribió:
> Hi Vik,
> inserting the
> approach.
> tips?
> Cheers,
> András
>> Hi András,
>> Uhm, strange...
>> is "org.eclipse.emf.cdo.ui.CDOEditor") and see if you get the same
>> behaviour?
>> Cheers,
>> ViK.
Re: [CDO]: CDO Resource Launcher [message #422613 is a reply to message #422612] |
Thu, 11 September 2008 06:24   |
Guys,
We could add to the launcher model to be able to configure packages to
register with the session.
What do you think?
Cheers
/Eike
> Hi András,
> seems to work fine for me :S
> action (dunno why... maybe setting content-type priority to low...)
> work).
> HTH,
> ViK.
>> Hi Vik,
>> inserting the
>> approach.
>> any tips?
>> Cheers,
>> András
>>> Hi András,
>>> Uhm, strange...
>>> you properly set the generated ID in the launcher model attribute
>>> editor ID, but ended in "enhanced", if I recall correctly. you can
>>> see it in the plugin.xml at the extensions tab).
>>> ID is "org.eclipse.emf.cdo.ui.CDOEditor") and see if you get the
>>> same behaviour?
>>> some problems with the initial Ganymede release. I'm not sure about
>>> what could be happening... I always suggest to try out the HEAD code...
>>> Cheers,
>>> ViK.
Re: [CDO]: CDO Resource Launcher [message #422614 is a reply to message #422613] |
Thu, 11 September 2008 06:39   |
--> https://bugs.eclipse.org/bugs/attachment.cgi?id=112298
Eike Stepper schrieb:
> Guys,
> What do you think?
> Cheers
> /Eike
>> Hi András,
>> should work).
>> Are you running the launcher file in the same workspace where the
>> model's code is located? Have you tried running the launcher in a
>> HTH,
>> ViK.
>>> Hi Vik,
>>> inserting the
>>> approach.
>>> any tips?
>>> Cheers,
>>> András
>>>> Hi András,
>>>>> the resource after loading it (no attributes, or anything else).
>>>>> The editor I use is good (a CDO enhanced one), because it works
>>>>> with my own plain xml file based loader well.
>>>> Uhm, strange...
>>>> same behaviour?
>>>>> use the CDO version 1.0.0.v200806180411) Let me know, if you need
>>>>> some more information about this.
>>>> shows "200806241000" available to download. Mark was also
>>>> experiencing some problems with the initial Ganymede release. I'm
>>>> not sure about what could be happening... I always suggest to try
>>>> Cheers,
>>>> ViK.
Re: [CDO]: CDO Resource Launcher [message #422615 is a reply to message #422613] |
Thu, 11 September 2008 06:46   |
Eike,
It's a great idea :D I think this feature would be necessary if
auto-registry is set to off, and would be equivalent to the help
provided by the Package Manager Dialog in the Session View.
However, to allow the new model referencing, we would need to add a new
multi-valued EReference to EObjects, that would be in turn the EPackages
to register. However, I always find problematic having a model that
contains references/attributes to EObjects.
Alternatives?
ViK.
> Guys,
> What do you think?
> Cheers
> /Eike
>> Hi András,
>> work).
>> HTH,
>> ViK.
>>> Hi Vik,
>>> inserting the
>>> approach.
>>> any tips?
>>> Cheers,
>>> András
>>>> Hi András,
>>>> Uhm, strange...
>>>> same behaviour?
>>>> Cheers,
>>>> ViK.
Re: [CDO]: CDO Resource Launcher [message #422616 is a reply to message #422614] |
Thu, 11 September 2008 06:48   |
Ok, through URI's
You don't even give me time to answer to your post xD
>> Guys,
>> What do you think?
>> Cheers
>> /Eike
>>> Hi András,
>>> should work).
>>> HTH,
>>> ViK.
>>>> Hi Vik,
>>>> inserting the
>>>> approach.
>>>> any tips?
>>>> Cheers,
>>>> András
>>>>> Hi András,
>>>>> Uhm, strange...
>>>>> same behaviour?
>>>>> Cheers,
>>>>> ViK.
Re: [CDO]: CDO Resource Launcher [message #422619 is a reply to message #422616] |
Thu, 11 September 2008 07:30   |
> Ok, through URI's
You'll need this time to implement the model that I designed! ;-)
>>> Guys,
>>> to register with the session.
>>> What do you think?
>>> Cheers
>>> /Eike
>>>> Hi András,
>>>> wizard creates an instance, since by default the wizard tries to
>>>> open the editor, and in this case, it finds the "launch" action as
>>>> default action (dunno why... maybe setting content-type priority to
>>>> low...)
>>>> should work).
>>>> HTH,
>>>> ViK.
>>>>> Hi Vik,
>>>>> inserting the
>>>>> approach.
>>>>> have any tips?
>>>>> Cheers,
>>>>> András
>>>>>> Hi András,
>>>>>> Uhm, strange...
>>>>>> can see it in the plugin.xml at the extensions tab).
>>>>>> (its ID is "org.eclipse.emf.cdo.ui.CDOEditor") and see if you get
>>>>>> the same behaviour?
>>>>>>> need some more information about this.
>>>>>> Cheers,
>>>>>> ViK.
Re: [CDO]: CDO Resource Launcher [message #422641 is a reply to message #422612] |
Thu, 11 September 2008 12:00   |
Hi ViK, Eike,
The extension of the launcher model sounds great :).
My test-model is not native (emm.. I don't know how can it be :) ). I
run the launcher in a runtime-workbench, the model code (with the
launcher's code) is in the host eclipse. I tried to put the model code
in the runtime-workbench as well, but it didn't helped.
Maybe there is something wrong with the EMF registry config? I didn't
done anything to it, I think the generator created the extension
automatically (org.eclipse.emf.ecore.generated_package).
Thanks in advance if you have any suggestions. I'll keep on trying for
sure, and let you know if I found the cause.
András
> Hi András,
> work).
> HTH,
> ViK.
Re: [CDO]: CDO Resource Launcher [message #422644 is a reply to message #422641] |
Thu, 11 September 2008 12:12   |
András,
Sorry, I meant CDO Native :P Otherwise, you'll be using dynamic mode.
(works fine but with some drawbacks)
For this, you have to create a new .genmodel with configured
specifically for CDO. This is can be done using a wizard contributed by
CDO in the EMF Model project. Take a look at:
http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO
Maybe this could help with you problem :)
> I run the launcher in a runtime-workbench, the model code (with the
You were already doing it in the right way, son forget about my second
hypothesis :P
Yes, and that's fine. So I think the EMF registry has nothing to do with
your problem.
Maybe dynamic mode is related with your problem. I'll try to reproduce
your problem with a non-native model.
Thanks!
ViK
Re: [CDO]: CDO Resource Launcher [message #422647 is a reply to message #422644] |
Thu, 11 September 2008 13:03   |
Vik,
First, thanks for the fast answer!
Ok I understand now the CDO Native stuff. My model is CDO Native then
:). On the host eclipse the CDO Sessions view says, that this model is
?/Dynamic (Registry/Repository). After opening a resource it became
Dynamic both. The general cdo editor works just fine here.
In the runtime eclipse I never tried out the CDO Session view until now.
The package manager says its Native/Dynamic, but after the first start,
it bacame Dynamic both. Starting the general editor from here produces
the same problem, that the launcher, the editor doesn't recognize my
package at all.. (So after all, it seems that this problem has nothing
to do with your launcher, or enhanced editor :)
András
> András,
> hypothesis :P
> your problem.
> Thanks!
> ViK
Re: [CDO]: CDO Resource Launcher [message #422649 is a reply to message #422647] |
Thu, 11 September 2008 14:10   |
András,
You are welcome!
Yes, this is the expected behaviour. The model is not registered in the
EMF Registry, since the plugin's extension points are not exposed to the
workbench.
Yes, it seems is a problem related with your model.
Usually, if everything is fine, it appears to me as "Native/Static".
It seems that your registry recognizes properly the model's code as
native. I can't really say why, after opening a resource, it turns into
"Dynamic" both. Have you tried creating a new resource, instead of
opening an already existing one in the CDO Server repository? Maybe the
problem is the stored instance that you are trying to open?
> András
>> András,
>> by CDO in the EMF Model project. Take a look at:
>>> code in the runtime-workbench as well, but it didn't helped.
>> hypothesis :P
>> with your problem.
>>> for sure, and let you know if I found the cause.
>> Thanks!
>> ViK
Re: [CDO]: CDO Resource Launcher [message #422733 is a reply to message #422591] |
Mon, 15 September 2008 11:31  |
An update to the CDO 2.0 HEAD code solved the problem.
András
András Ökrös írta:
> Hello Victor,
> Best regards,
> András
>> Hi André,
>>> use a ganymede ide, cdo/net4j bundles from cvs and a target platform
>>> built a month ago).
>> Cheers!
>> ViK
Current Time: Sun Jul 27 10:04:49 EDT 2025
Powered by FUDForum. Page generated in 0.27256 seconds
