Home » Modeling » EMF » [Teneo] 0..* associations, how to fetch parent from child
[Teneo] 0..* associations, how to fetch parent from child [message #422531] Mon, 08 September 2008 12:57 Go to next message
When you have a 0..* association the source code for the child does not
get generated with a convenience method to get the parent. We have to go
to the parent and use the getChild() method then iterate through the
EList returned looking for the child we are dealing with. E.g.
<xsd:complexType name="IssuerClass">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="unbounded"
ref="gensec:instrumentDomain" />
</xsd:sequence>
<xsd:attribute name="id" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">
@Id @GeneratedValue(strategy=IDENTITY)
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:element name="issuerClass" type="gensec:IssuerClass" />
<xsd:complexType name="InstrumentDomain">
<xsd:sequence>
<xsd:element maxOccurs="unbounded"
ref="gensec:instrumentIdentifier" />
</xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute name="name" type="xsd:string" />
<xsd:attribute name="shortName" type="xsd:string" />
</xsd:complexType>
<xsd:element name="instrumentDomain" type="gensec:InstrumentDomain" />
Will generate code with
EList<InstrumentDomain> getInstrumentDomain();
in IssuerClass. But nothing in the class InstrumentDomain to find its
IssuerClass, if it has one. This makes for very awkward coding when you
are passed a InstrumentDomain object.
I looked in the annotations to see if there was anything to allow me to
add this lookup of the parent in these one to many associations, could
not see it. Is there anything?
Thx.
David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422533 is a reply to message #422531] Mon, 08 September 2008 13:08 Go to previous messageGo to next message
Hi David,
The eContainer() method should give you the parent in this case. You can also explicitly model the
assocation back from the instrumentDomain to the IssuerClass, and set the eopposite, you can use the
ecore:opposite attribute for that (see here
http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf)
gr. Martin
David Wynter wrote:
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422541 is a reply to message #422533] Mon, 08 September 2008 18:41 Go to previous messageGo to next message
I added
ecore:reference="gensec:InstrumentDomain" ecore:opposite="issuerClass"/>
But did not get the expected InstrumentDomain.getIssuerClass() method
generated? I also tried without the ecore:reference but got these weird
errors "the opposite of the opposite many not be a reference different
from this one"
I cannot use eContainer as the database schema has to be as unadorned as
is possible. Using eContainer adds 3 columns from what i read.
David
Martin Taal wrote:
> Hi David,
> also explicitly model the assocation back from the instrumentDomain to
> the IssuerClass, and set the eopposite, you can use the ecore:opposite
> gr. Martin
> David Wynter wrote:
>> Hi,
>> not get generated with a convenience method to get the parent. We have
>> to go to the parent and use the getChild() method then iterate through
>> the EList returned looking for the child we are dealing with. E.g.
>> <xsd:sequence>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> you are passed a InstrumentDomain object.
>> to add this lookup of the parent in these one to many associations,
>> could not see it. Is there anything?
>> Thx.
>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422555 is a reply to message #422541] Tue, 09 September 2008 06:50 Go to previous messageGo to next message
Hi David,
Is it possible (taking your model into account) to add a xsd:element in InstrumentDomain which
points to IssuerClass (using an ecore:reference)? The ecore:opposite should be set in that
xsd:element and it should be the name of the efeature in IssuerClass which has the instrumentdomains
(in this case ecore:opposite="instrumentDomain" probably works).
gr. Martin
David Wynter wrote:
> I added
> from this one"
> Regards,
> David
> Martin Taal wrote:
>> Hi David,
>> can also explicitly model the assocation back from the
>> use the ecore:opposite attribute for that (see here
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> have to go to the parent and use the getChild() method then iterate
>>> through the EList returned looking for the child we are dealing with.
>>> E.g.
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422567 is a reply to message #422555] Tue, 09 September 2008 10:51 Go to previous messageGo to next message
Martin,
I added the suggested element and ended up with this:
<xsd:sequence>
</xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:sequence>
<xsd:element ecore:reference="gensec:IssuerClass"
ecore:opposite="instrumentDomain" minOccurs="0" maxOccurs="1"
</xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
It still did not generate a InstrumentDomain.getIssuerClass() method.
David
Martin Taal wrote:
> Hi David,
> InstrumentDomain which points to IssuerClass (using an ecore:reference)?
> The ecore:opposite should be set in that xsd:element and it should be
> gr. Martin
> David Wynter wrote:
>> Hi,
>> I added
>> weird errors "the opposite of the opposite many not be a reference
>> different from this one"
>> as is possible. Using eContainer adds 3 columns from what i read.
>> Regards,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> with. E.g.
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> its IssuerClass, if it has one. This makes for very awkward coding
>>>> when you are passed a InstrumentDomain object.
>>>> Thx.
>>>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422568 is a reply to message #422567] Tue, 09 September 2008 11:13 Go to previous messageGo to next message
--------------020002020509020100090905
David,
I think what you want is
<xsd:element ecore:opposite="issuerClass" minOccurs="0"
maxOccurs="unbounded" ref="lib:instrumentDomain" />
David Wynter wrote:
> Martin,
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> Regards,
> David
> Martin Taal wrote:
>> Hi David,
>> in InstrumentDomain which points to IssuerClass (using an
>> which has the instrumentdomains (in this case
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> I added
>>> method generated? I also tried without the ecore:reference but got
>>> these weird errors "the opposite of the opposite many not be a
>>> reference different from this one"
>>> unadorned as is possible. Using eContainer adds 3 columns from what
>>> i read.
>>> Regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> You can also explicitly model the assocation back from the
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> does not get generated with a convenience method to get the
>>>>> parent. We have to go to the parent and use the getChild() method
>>>>> then iterate through the EList returned looking for the child we
>>>>> <xsd:sequence>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> <xsd:sequence>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> me to add this lookup of the parent in these one to many
>>>>> associations, could not see it. Is there anything?
>>>>> Thx.
>>>>> David
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
David,<br>
<br>
I think what you want is<br>
<blockquote>&lt;xsd:element ecore:opposite="issuerClass" minOccurs="0"
maxOccurs="unbounded" ref="lib:instrumentDomain" /&gt;<br>
</blockquote>
<br>
David Wynter wrote:
<blockquote cite="mid:ga62d0$h9m$1@build.eclipse.org" type="cite">Martin,
<br>
<br>
<br>
<br>
&nbsp;&nbsp; &lt;xsd:complexType name="IssuerClass"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:sequence&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element minOccurs="0" maxOccurs="unbounded"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; ref="gensec:instrumentDomain" /&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:sequence&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:attribute name="id" type="xsd:int"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:annotation&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &lt;xsd:appinfo source="teneo.jpa"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; @Id @GeneratedValue(strategy=IDENTITY)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &lt;/xsd:appinfo&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:annotation&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:attribute&gt;
<br>
&nbsp;&nbsp; &lt;/xsd:complexType&gt;
<br>
&nbsp;&nbsp; &lt;xsd:element name="issuerClass" type="gensec:IssuerClass" /&gt;
<br>
<br>
&nbsp;&nbsp; &lt;xsd:complexType name="InstrumentDomain"&gt;
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element maxOccurs="unbounded"
<br>
&nbsp;ref="gensec:instrumentIdentifier" /&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element ecore:reference="gensec:IssuerClass"
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:annotation&gt;
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:annotation&gt;
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:attribute name="name" type="xsd:string" /&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:attribute name="shortName" type="xsd:string" /&gt;
<br>
<br>
&nbsp;&nbsp; &lt;xsd:element name="instrumentDomain"
<br>
&nbsp;type="gensec:InstrumentDomain" /&gt;
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
Martin Taal wrote:
<br>
<blockquote type="cite">Hi David,
<br>
ecore:reference)? The ecore:opposite should be set in that xsd:element
instrumentdomains (in this case ecore:opposite="instrumentDomain"
probably works).
<br>
<br>
gr. Martin
<br>
<br>
David Wynter wrote:
<br>
<blockquote type="cite"><br>
<br>
<br>
I added
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;xsd:element minOccurs="0" maxOccurs="unbounded"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; ref="gensec:instrumentDomain"
ecore:reference="gensec:InstrumentDomain"&nbsp;
ecore:opposite="issuerClass"/&gt;
<br>
<br>
from this one"
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
Martin Taal wrote:
<br>
<br>
can also explicitly model the assocation back from the instrumentDomain
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf"> http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf</a>)
<br>
<br>
gr. Martin
<br>
<br>
David Wynter wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
go to the parent and use the getChild() method then iterate through the
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; ref="gensec:instrumentDomain" /&gt;
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;xsd:annotation&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;xsd:appinfo source="teneo.jpa"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; @Id @GeneratedValue(strategy=IDENTITY)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;/xsd:appinfo&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;/xsd:annotation&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; EList&lt;InstrumentDomain&gt; getInstrumentDomain();
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
--------------020002020509020100090905--
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422570 is a reply to message #422568] Tue, 09 September 2008 11:56 Go to previous messageGo to next message
There seems to be some confusion, lets say you have a parent 0..* child.
The standard xsd will generate a method for the parent to get all the
children. I simply want a method that for a child it will fetch its only
parent.
The element you suggested ended up adding the method with the right name
but it returns objects not of the type of the parent, in this case
IssuerClass, but of the type of the child, in the case InstrumentDomain.
So it appears to be a self referential relationship it set up.
I changed it to this.
<xsd:element ecore:opposite="issuerClass" minOccurs="0" maxOccurs="1"
ref="gensec:issuerClass" />
This does what I expect it to do in the InstrumentDomain class, adding
IssuerClass InstrumentDomain.getIssuerCLass()
but it adds a superflous method
InstrumentDomain IssuerClass.getIssuerClass();
I already have EList<InstrumentDomain> IssuerClass.getInstrumentDomain()
Which is the real one I need.
What I want is going to be required by a large proportion of developers.
Say I am presented an InstrumentDomain object and need to get its
IssuerClass, my current only option seems to be to resort to the native
SQL and use the foreign key in the table underlying InstrumentDomain to
get it.
David
Ed Merks wrote:
> David,
> David Wynter wrote:
>> Martin,
>> <xsd:sequence>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> Regards,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> I added
>>>> i read.
>>>> Regards,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> Thx.
>>>>>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422571 is a reply to message #422570] Tue, 09 September 2008 12:10 Go to previous messageGo to next message
David,
Comments below.
David Wynter wrote:
You think?
> lets say you have a parent 0..* child. The standard xsd will generate
> a method for the parent to get all the children. I simply want a
> method that for a child it will fetch its only parent.
I gathered that...
> name but it returns objects not of the type of the parent, in this
> case IssuerClass,
In InstrumentDomain I get:
IssuerClass getIssuerClass();
The IssuerClass contains the InstrumentDomain and the InstrumentDomain
has a method for accessing that parent. I'm not sure what I messed.
> but of the type of the child, in the case InstrumentDomain. So it
Just the names tell me this can't possibly be right...
This you get even without the opposite, right?
This is the part that's wrong because you aren't using opposite
appropriately.
> developers. Say I am presented an InstrumentDomain object and need to
> get its IssuerClass, my current only option seems to be to resort to
> the native SQL and use the foreign key in the table underlying
> InstrumentDomain to get it.
I think a wire got cross somewhere. If you want any of your containment
references to have an inverse (all elements referring to complex types
will result in containment references), then you put an ecore:opposite
on that element/element-ref and you give the name of the feature as it
will appear in the reference's type. So say I have a class Parent that
has an element "child" of type "Child", I would put
ecore:opposite="parent" on that element declaration in the Parent
complex type and as a result the Child EClass would end up with a
"parent" feature of type "Parent"...
> David
> Ed Merks wrote:
>> David,
>> David Wynter wrote:
>>> Martin,
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> Regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> xsd:element in InstrumentDomain which points to IssuerClass (using
>>>> IssuerClass which has the instrumentdomains (in this case
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> I added
>>>>> what i read.
>>>>> Regards,
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> can use the ecore:opposite attribute for that (see here
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> method then iterate through the EList returned looking for the
>>>>>>> <xsd:sequence>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> <xsd:sequence>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> find its IssuerClass, if it has one. This makes for very awkward
>>>>>>> coding when you are passed a InstrumentDomain object.
>>>>>>> allow me to add this lookup of the parent in these one to many
>>>>>>> Thx.
>>>>>>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422573 is a reply to message #422571] Tue, 09 September 2008 12:59 Go to previous messageGo to next message
Comments below. To clarify, IssuerClass is the parent and
InstrumentDomain is the child.
David
Ed Merks wrote:
> David,
> Comments below.
> David Wynter wrote:
>> Hi,
> You think?
> I gathered that...
>> case IssuerClass,
No I got this with exactly what I showed there. For clarity as here:
this is inside the InstrumentDomain complexType definition
> appropriately.
OK that is clear to me
I am now confused. Reading this makes me think I should add to the
element definition in IssuerClass complexType definition. Terminology is
a problem. So to clarify.
1. In this case the containment reference in IssuerClass is:
2. The feature name is thus "gensec:issuerClass"? (although "reference's
type" suggests to me the far end of this relationship)
When I tried this as the reference
<xsd:element ecore:opposite="gensec:issuerClass" minOccurs="0"
maxOccurs="unbounded" ref="gensec:instrumentDomain" />
I got an error "The name "gensec:issuerClass" is not well formed"
Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> David Wynter wrote:
>>>> Martin,
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> Regards,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> I added
>>>>>> what i read.
>>>>>> Regards,
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> <xsd:sequence>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> <xsd:sequence>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> Thx.
>>>>>>>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422576 is a reply to message #422573] Tue, 09 September 2008 15:58 Go to previous messageGo to next message
David,
Comments below.
David Wynter wrote:
> David
> Ed Merks wrote:
>> David,
>> Comments below.
>> David Wynter wrote:
>>> Hi,
>> You think?
>>> generate a method for the parent to get all the children. I simply
>>> want a method that for a child it will fetch its only parent.
>> I gathered that...
>>> case IssuerClass,
>> InstrumentDomain has a method for accessing that parent. I'm not
>> sure what I messed.
>>> maxOccurs="1" ref="gensec:issuerClass" />
>>> adding IssuerClass InstrumentDomain.getIssuerCLass()
Using ecore:opposite will not create a feature in the class containing
this element declaration. So your getIssuerClass method is appearing
because of the element declaration, not because of the ecore:opposite
annotation.
>> appropriately.
>>> to get its IssuerClass, my current only option seems to be to resort
>>> to the native SQL and use the foreign key in the table underlying
>> containment references to have an inverse (all elements referring to
>> complex types will result in containment references), then you put an
>> ecore:opposite on that element/element-ref and you give the name of
>> the feature as it will appear in the reference's type. So say I have
>> a class Parent that has an element "child" of type "Child", I would
>> put ecore:opposite="parent" on that element declaration in the Parent
Yes, that's what I showed. It would have been more clear had I shown it
in context:
<xsd:sequence>
</xsd:sequence>
> Terminology is a problem. So to clarify.
Yes.
No, the feature name should just be a well formed Java identifier
representing the actual name of the EMF feature you want generated.
> (although "reference's type" suggests to me the far end of this
> relationship)
It will be a feature in the type of the element, i.e, InstrumentDomain.
Remove the "gensec:", and you should be golden.
> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> David Wynter wrote:
>>>>> Martin,
>>>>> <xsd:sequence>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> <xsd:sequence>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> Regards,
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> that xsd:element and it should be the name of the efeature in
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> I added
>>>>>>> got these weird errors "the opposite of the opposite many not be
>>>>>>> a reference different from this one"
>>>>>>> what i read.
>>>>>>> Regards,
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> case. You can also explicitly model the assocation back from
>>>>>>>> you can use the ecore:opposite attribute for that (see here
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> <xsd:sequence>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> <xsd:sequence>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> awkward coding when you are passed a InstrumentDomain object.
>>>>>>>>> Thx.
>>>>>>>>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422577 is a reply to message #422576] Tue, 09 September 2008 18:47 Go to previous messageGo to next message
I am golden, for a moment at least.
I added this ecore:opposite to other elements in the same complexType. I
am getting this error message.
"The opposite of opposite may not be a reference different from this one"
I checked for typos in the feature names. Am I allowed more than one of
the referenced elements to have the same feature name?
Thx.
David
"Ed Merks wrote:
> David,
> Comments below.
> David Wynter wrote:
>> Hi,
>> David
>> Ed Merks wrote:
>>> David,
>>> Comments below.
>>> David Wynter wrote:
>>>> Hi,
>>> You think?
>>> I gathered that...
>>>> case IssuerClass,
>>> sure what I messed.
> annotation.
>>> appropriately.
> in context:
> <xsd:sequence>
> </xsd:sequence>
> Yes.
>> relationship)
>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> David Wynter wrote:
>>>>>> Martin,
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> <xsd:sequence>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> Regards,
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> I added
>>>>>>>> what i read.
>>>>>>>> Regards,
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> <xsd:sequence>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:attribute>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> <xsd:sequence>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:attribute>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> Thx.
>>>>>>>>>> David
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422578 is a reply to message #422577] Tue, 09 September 2008 18:53 Go to previous messageGo to next message
--------------040703010402060808030200
David,
Opposites must be pairs. I.e., the opposite of an opposite must be the
original feature. Thus, if you have multiple containment references to
the same type of object each such containment reference but specify an
opposite with a *different *name.
David Wynter wrote:
> I am getting this error message.
> of the referenced elements to have the same feature name?
> Thx.
> David
> "Ed Merks wrote:
>> David,
>> Comments below.
>> David Wynter wrote:
>>> Hi,
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> Comments below.
>>>> David Wynter wrote:
>>>>> Hi,
>>>> You think?
>>>> I gathered that...
>>>>> right name but it returns objects not of the type of the parent,
>>>>> in this case IssuerClass,
>>>> sure what I messed.
>> containing this element declaration. So your getIssuerClass method
>> is appearing because of the element declaration, not because of the
>> ecore:opposite annotation.
>>>> appropriately.
>>>>> resort to the native SQL and use the foreign key in the table
>>>>> underlying InstrumentDomain to get it.
>>>> to complex types will result in containment references), then you
>>>> put an ecore:opposite on that element/element-ref and you give the
>>>> name of the feature as it will appear in the reference's type. So
>>>> say I have a class Parent that has an element "child" of type
>>>> "Child", I would put ecore:opposite="parent" on that element
>>>> declaration in the Parent complex type and as a result the Child
>>>> EClass would end up with a "parent" feature of type "Parent"...
>> it in context:
>> <xsd:sequence>
>> </xsd:sequence>
>> Yes.
>>> relationship)
>>> Thx.
>>>>> David
>>>>> Ed Merks wrote:
>>>>>> David,
>>>>>> David Wynter wrote:
>>>>>>> Martin,
>>>>>>> <xsd:sequence>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> <xsd:sequence>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> method.
>>>>>>> Regards,
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> I added
>>>>>>>>> what i read.
>>>>>>>>> Regards,
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> eopposite, you can use the ecore:opposite attribute for that
>>>>>>>>>> (see here
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> child does not get generated with a convenience method to
>>>>>>>>>>> get the parent. We have to go to the parent and use the
>>>>>>>>>>> getChild() method then iterate through the EList returned
>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> many associations, could not see it. Is there anything?
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
<html>
<head>
<title></title>
</head>
David,<br>
<br>
Opposites must be pairs.&nbsp; I.e., the opposite of an opposite must be the
original feature.&nbsp; Thus, if you have multiple containment references to
opposite with a <b>different </b>name.<br>
<br>
<br>
David Wynter wrote:
<blockquote cite="mid:ga6u8e$kvc$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
one"
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
"Ed Merks wrote:
<br>
<blockquote type="cite">David,
<br>
<br>
Comments below.
<br>
<br>
David Wynter wrote:
<br>
<br>
<br>
<br>
<br>
David
<br>
Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
David Wynter wrote:
<br>
<br>
<br>
<br>
</blockquote>
You think?
<br>
<blockquote type="cite">lets say you have a parent 0..* child.
only parent.
<br>
</blockquote>
I gathered that...
<br>
name but it returns objects not of the type of the parent, in this case
IssuerClass, </blockquote>
<br>
<br>
&nbsp;IssuerClass getIssuerClass();
<br>
<br>
has a method for accessing that parent.&nbsp; I'm not sure what I messed.
<br>
<blockquote type="cite">but of the type of the child, in the
case InstrumentDomain.&nbsp; So it appears to be a self referential
<br>
<br>
<br>
<br>
maxOccurs="1" ref="gensec:issuerClass" /&gt;
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
maxOccurs="1"
<br>
&nbsp;ref="gensec:issuerClass" /&gt;
<br>
<br>
</blockquote>
this element declaration.&nbsp; So your getIssuerClass method is appearing
annotation.
<br>
<br>
<br>
</blockquote>
appropriately.
<br>
</blockquote>
<br>
I already have EList&lt;InstrumentDomain&gt;
<br>
<br>
<br>
<br>
<br>
</blockquote>
I think a wire got cross somewhere.&nbsp; If you want any of your
ecore:opposite on that element/element-ref and you give the name of the
feature as it will appear in the reference's type.&nbsp; So say I have a
class Parent that has an element "child" of type "Child", I would&nbsp; put
<br>
</blockquote>
element definition in IssuerClass complexType definition. </blockquote>
Yes, that's what I showed.&nbsp; It would have been more clear had I shown
it in context:
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element ecore:opposite="issuerClass" minOccurs="0"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; ref="lib:instrumentDomain" /&gt;
<br>
<br>
<br>
<blockquote type="cite">Terminology is a problem. So to clarify.
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element minOccurs="0" maxOccurs="unbounded"
<br>
</blockquote>
Yes.
<br>
<blockquote type="cite">2. The feature name is thus
<br>
</blockquote>
<br>
<blockquote type="cite">(although "reference's type" suggests to me
<br>
</blockquote>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element ecore:opposite="gensec:issuerClass" minOccurs="0"
maxOccurs="unbounded" ref="gensec:instrumentDomain" /&gt;
<br>
<br>
<br>
</blockquote>
<br>
Thx.
<br>
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; maxOccurs="unbounded" ref="lib:instrumentDomain" /&gt;
<br>
<br>
<br>
David Wynter wrote:
<br>
<blockquote type="cite">Martin,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
Martin Taal wrote:
<br>
<br>
probably works).
<br>
<br>
gr. Martin
<br>
<br>
David Wynter wrote:
<br>
<br>
<br>
I added
<br>
<br>
<br>
<br>
from this one"
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
Martin Taal wrote:
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
David Wynter wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------040703010402060808030200--
Re: [Teneo] 0..* associations, how to fetch parent from child [message #422579 is a reply to message #422578] Tue, 09 September 2008 19:10 Go to previous message
Thx, all working. Big model with 382 elements and about 100 opposites
David
Ed Merks wrote:
> David,
> David Wynter wrote:
>> Hi,
>> Thx.
>> David
>> "Ed Merks wrote:
>>> David,
>>> Comments below.
>>> David Wynter wrote:
>>>> Hi,
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> Comments below.
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>> You think?
>>>>> I gathered that...
>>>>> sure what I messed.
>>>>> appropriately.
>>> it in context:
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> Yes.
>>>> relationship)
>>>> Thx.
>>>>>> David
>>>>>> Ed Merks wrote:
>>>>>>> David,
>>>>>>> David Wynter wrote:
>>>>>>>> Martin,
>>>>>>>> <xsd:sequence>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> <xsd:sequence>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> method.
>>>>>>>> Regards,
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I added
>>>>>>>>>> what i read.
>>>>>>>>>> Regards,
>>>>>>>>>> David
>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>> Hi David,
>>>>>>>>>>> (see here
>>>>>>>>>>> gr. Martin
>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>>> Thx.
>>>>>>>>>>>> David
Previous Topic:Avoiding "Cannot modify resource set without a write transaction" in lazy initialization
Next Topic:[CDO] Transparent CDO integration into generated EMF editor
Current Time: Sun Jul 27 00:35:01 EDT 2025
Powered by FUDForum. Page generated in 0.05219 seconds
