Home » Modeling » EMF » Set<K> vs Map
Set<K> vs Map [message #421844] |
Thu, 14 August 2008 09:38  |
Originally posted by: K_Juenemann.gmx.de
I need to manage a collection of objects of type A which are considered
to be equal if a String member (it is actually a file path, so lets call
it "path") is equal. Besides, A can contain other data. The collection
should
.... ensure, that every A should be unique within the collection
(according to their "path" member)
.... should have an access time of O(1) to retrieve an A for a given path
.... and should be sorted according to the natural ordering of "path"
(for iterating over all values)
.... be typesafe, so ensure that only As are contained by the collection
So what I need is basically a SortedSet. Now I wondered about the right
way to model this with EMF. I know, that you should not override equals
and getHashCode, so I am not sure how to do this right. I see the
following option:
1) define the Datatype JavaTreeSet (which uses java.util.TreeSet)
Here I would have to override getHashcode and Equals I think. I also
wonder if there will be any problems with serialisation.
2) define a one to many reference to A, with unique and ordered = true.
But I would lack the O(1) access time.
3) use a EMap<String, A> which uses the path-member as a key and A's as
values. For some reason, this looks "hacky" to me a little bit, as I am
pulling the pathes out of the A's. This approach would also lack the
ordering.
So, what would be the best idea for modeling something like this? Maybe
I am lacking anything?
Konrad
Re: Set<K> vs Map [message #421847 is a reply to message #421844] |
Thu, 14 August 2008 10:00   |
Konrad,
Comments below.
Konrad Juenemann wrote:
> considered to be equal if a String member (it is actually a file path,
> so lets call it "path") is equal.
I'm already getting concerned that you will be tempted to override
..equals and hashCode on your AImpl class, which is a no no.
> Besides, A can contain other data. The collection should
If you have an EReference to A you could define the "path" EAttribute to
be a key and validation will complain if there is more than one A with
the same key in that reference's value.
Sounds like a map is needed.
You have lots of constraints.
> right way to model this with EMF. I know, that you should not override
> equals and getHashCode, so I am not sure how to do this right. I see
> the following option:
Yes, don't do that.
I guess you can define a comparator and construct it with that.
EObject collections currently always force uniqueness, but that's based
on object identity. They're also always ordered, which means that order
has meaning and is preserved, not that they are sorted.
> as values. For some reason, this looks "hacky" to me a little bit, as
> I am pulling the pathes out of the A's. This approach would also lack
> the ordering.
But you do want a map given you want to find the A given a path in O(1)
time. Even if you didn't use EMF, you'd still want a map like that.
> Maybe I am lacking anything?
I suppose given all the constraints, you're torn between wanting a
TreeMap and a TreeSet. As I said before, even without EMF you're a bit
in bind since a TreeMap is O(log(n)) I think. Perhaps you should has
convenience operations and just build a map the first time you need one
(much like EClass.getEStructuralFeature); you can alway use
ECollections.sort to sort an EList.
> Cheers,
> Konrad
Re: Set<K> vs Map [message #421849 is a reply to message #421847] |
Thu, 14 August 2008 10:25  |
Wow, that was fast. :)
Uhm, I think you are right, Map + sorting + O(1) is not doable. So I
think I will drop the "sorted"-constraint and go for a HashMap / Set.
When I am thinking over it, a HashMap<String, A> might be best, as it
would guarantee uniqueness without forcing me to write a Comparer.
Thank you very much for your help!
Ed Merks schrieb:
> Konrad,
> Comments below.
>> Hi,
> Yes, don't do that.
>> the ordering.
>> Cheers,
>> Konrad
Current Time: Fri Jul 18 18:41:17 EDT 2025
Powered by FUDForum. Page generated in 0.10942 seconds
