Home » Modeling » EMF » tutorial fails: unresolved bundles
tutorial fails: unresolved bundles [message #421475] Thu, 07 August 2008 13:49 Go to next message
sorry, if this is a dumb question, but I am stuck:
I installed EMF on Eclipse 3.4 and tried the 'library' tutorial.
Everything seemed to work fine to the point, when I generated
the code. The generator seems to work, however the code is
seemingly incorrect.
The root problem seems to be, that the system does not
find the EMF bundles.
For example, the MANIFEST.MF files are marked with
Manifest-Version: 1.0
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: de.hfinster.library.presentation
Require-Bundle: org.eclipse.core.runtime,
library.edit;visibility:=reexport,
org.eclipse.emf.ecore.xmi;visibility:=reexport,
*** Bundle 'org.eclipse.emf.ecore.xmi' cannot be resolved ***
org.eclipse.emf.edit.ui;visibility:=reexport
*** Bundle 'org.eclipse.emf.edit.ui' cannot be resolved ***
I double checked, that the plugins are available.
See the list of EMF plugins extracted from the configuration details
(at the end of the posting).
I would be grateful, if anyone could point me into the right direction.
Kind regards
Harald
org.eclipse.emf (2.4.0.v200806091234) "EMF - Eclipse Modeling Framework"
[Starting]
org.eclipse.emf.activities (2.4.0.v200806091234) "EMF Activities
Example" [Starting]
org.eclipse.emf.ant (2.4.0.v200806091234) "EMF Ant Tasks" [Starting]
org.eclipse.emf.cheatsheets (2.4.0.v200806091234) "EMF Cheat Sheets"
[Starting]
org.eclipse.emf.codegen (2.4.0.v200806091234) "EMF Code Generation" [Active]
org.eclipse.emf.codegen.ecore (2.4.0.v200806091234) "EMF Ecore Code
Generator" [Active]
org.eclipse.emf.codegen.ecore.ui (2.4.0.v200806091234) "EMF Ecore Code
Generator UI" [Active]
org.eclipse.emf.codegen.ui (2.4.0.v200806091234) "EMF Code Generation
UI" [Starting]
org.eclipse.emf.common (2.4.0.v200806091234) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.4.0.v200806091234) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.4.0.v200806091234) "CommonJ SDO - Service
Data Objects" [Starting]
org.eclipse.emf.converter (2.4.0.v200806091234) "EMF Model Converter"
[Starting]
org.eclipse.emf.databinding (1.0.0.v200806091234) "EMF Data Binding"
[Starting]
org.eclipse.emf.databinding.edit (1.0.0.v200806091234) "EMF Edit Data
Binding" [Starting]
org.eclipse.emf.doc (2.4.0.v200806091234) "EMF Developer Guide" [Starting]
org.eclipse.emf.ecore (2.4.0.v200806091234) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.4.0.v200806091234) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200806091234) "EMF Change
Edit" [Starting]
org.eclipse.emf.ecore.edit (2.4.0.v200806091234) "EMF Ecore Edit" [Active]
org.eclipse.emf.ecore.editor (2.4.0.v200806091234) "EMF Sample Ecore
Editor" [Active]
org.eclipse.emf.ecore.sdo (2.4.0.v200806091234) "EMF SDO - EMF's Service
Data Objects Implementation" [Starting]
org.eclipse.emf.ecore.sdo.doc (2.4.0.v200806091234) "EMF SDO Developer
Guide" [Starting]
org.eclipse.emf.ecore.sdo.edit (2.4.0.v200806091234) "EMF SDO Edit"
[Starting]
org.eclipse.emf.ecore.sdo.editor (2.4.0.v200806091234) "EMF SDO Editor"
[Starting]
org.eclipse.emf.ecore.sdo.source (2.4.0.v200806091234) "EMF SDO Source"
[Resolved]
org.eclipse.emf.ecore.xmi (2.4.0.v200806091234) "EMF XML/XMI
Persistence" [Active]
org.eclipse.emf.edit (2.4.0.v200806091234) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.4.0.v200806091234) "EMF Edit UI" [Active]
org.eclipse.emf.example.installer (1.0.0.v200806091234) "EMF Example
Installer" [Starting]
org.eclipse.emf.examples (2.4.0.v200806091234) "EMF Examples" [Starting]
org.eclipse.emf.examples.generator.validator (1.1.0.v200806091234) "EMF
Generator Extension Example" [Active]
org.eclipse.emf.examples.library (2.4.0.v200806091234) "EMF Extended
Library Model Example" [Starting]
org.eclipse.emf.examples.library.edit (2.4.0.v200806091234) "EMF
Extended Library Edit Example" [Starting]
org.eclipse.emf.examples.library.editor (2.4.0.v200806091234) "EMF
Extended Library Editor Example" [Starting]
org.eclipse.emf.examples.source (2.4.0.v200806091234) "EMF Examples
Source" [Resolved]
org.eclipse.emf.exporter (2.4.0.v200806091234) "EMF Model Exporter"
[Starting]
org.eclipse.emf.exporter.html (2.4.0.v200806091234) "EMF Model Exporter
Example" [Starting]
org.eclipse.emf.importer (2.4.0.v200806091234) "EMF Model Importer"
[Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200806091234) "EMF Ecore
Importer" [Starting]
org.eclipse.emf.importer.java (2.4.0.v200806091234) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.4.0.v200806091234) "EMF Rose Importer"
[Starting]
org.eclipse.emf.java (2.4.0.v200806091234) "EMF Java Model Example"
[Starting]
org.eclipse.emf.java.edit (2.4.0.v200806091234) "EMF Java Edit Example"
[Starting]
org.eclipse.emf.java.editor (2.4.0.v200806091234) "EMF Java Editor
Example" [Starting]
org.eclipse.emf.mapping (2.4.0.v200806091234) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.4.0.v200806091234) "EMF Ecore Mapping"
[Starting]
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200806091234) "EMF Ecore
Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200806091234) "EMF Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200806091234) "EMF
Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.4.0.v200806091234) "EMF Ecore to
XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200806091234) "EMF Ecore to
XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.4.0.v200806091234) "EMF Mapping UI" [Starting]
org.eclipse.emf.mapping.xsd2ecore (2.4.0.v200806091234) "XSD to Ecore
Mapping" [Starting]
org.eclipse.emf.mapping.xsd2ecore.editor (2.4.0.v200806091234) "XSD to
org.eclipse.emf.source (2.4.0.v200806091234) "EMF Source" [Resolved]
Re: tutorial fails: unresolved bundles [message #421476 is a reply to message #421475] Thu, 07 August 2008 13:46 Go to previous messageGo to next message
Hi Harald,
Are you sure that the Target Platform of your workspace is identical
with the host IDE installation?
Only in this case the configuration details are meaningful. In the other
case you should verify the Traget Platform plugins in the Plugin
Development preferences.
Cheers
/Eike
Harald Finster schrieb:
> Hello,
> Kind regards
> Harald
> [Starting]
> Example" [Starting]
> [Starting]
> Generator" [Active]
> UI" [Starting]
> [Starting]
> [Starting]
> Binding" [Starting]
> [Starting]
> Edit" [Starting]
> Editor" [Active]
> Guide" [Starting]
> [Starting]
> [Starting]
> [Resolved]
> Source" [Resolved]
> [Starting]
> Example" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> Example" [Starting]
> [Starting]
> Mapping" [Starting]
Re: tutorial fails: unresolved bundles [message #421478 is a reply to message #421476] Thu, 07 August 2008 14:08 Go to previous messageGo to next message
Hi Eike,
thanks for your ultra-quick reply.
Your hint seems to be the right pointer.
I am not sure - indeed.
I just checked "Target Platform" Preferences
and found the location /usr/local/packages/eclipse,
which seems to be identical with my development system.
(The executable is /usr/local/packages/eclipse/eclipse)
However, as you said, the EMF plugins are missing in
the list of Plug-Ins. (I expected to find all plugins
installed in the development system there - but my
understanding seems to be incorrect here.)
Well, now I have to find out how to get them there.
(Certainly not an EMF specific problem.)
Again, thanks a lot and kind regards
Harald
Eike Stepper wrote:
> Hi Harald,
> Cheers
> /Eike
>> Hello,
>> Kind regards
>> Harald
Re: tutorial fails: unresolved bundles (solved) [message #421482 is a reply to message #421475] Thu, 07 August 2008 15:06 Go to previous messageGo to next message
thanks to your help I managed to solve the problem.
I opened "Preferences" "Target Platform" "PlugIns"
"Add" and used the "Repository or Update Site" option
to add the EMF plugins ... and - voila - the bundles
can be resolved.
Greetings Harald
Re: tutorial fails: unresolved bundles [message #421504 is a reply to message #421478] Fri, 08 August 2008 03:35 Go to previous messageGo to next message
> Hi Eike,
In fact my nntp client shows that my answer arrived 3 minutes *before*
your question ;-)
That's my personal record!
Cheers
/Eike
> Harald
> Eike Stepper wrote:
>> Hi Harald,
>> Cheers
>> /Eike
>>> Hello,
>>> Kind regards
>>> Harald
Re: tutorial fails: unresolved bundles [message #421515 is a reply to message #421504] Fri, 08 August 2008 07:43 Go to previous messageGo to next message
Eike,
The EMF newsgroup supports the innovative new time tunneling
communications protocol to better support preemptive answering of
questions. We should get Scott to incorporate it in ECF.
>> Hi Eike,
> your question ;-)
> Cheers
> /Eike
>> Harald
>> Eike Stepper wrote:
>>> Hi Harald,
>>> other
>>> Cheers
>>> /Eike
>>>> Hello,
>>>> direction.
>>>> Kind regards
>>>> Harald
Re: tutorial fails: unresolved bundles [message #421527 is a reply to message #421515] Fri, 08 August 2008 09:22 Go to previous messageGo to next message
Ed Merks schrieb:
> Eike,
Hehe, I'll beam it up to Scott when I solved some minor issues with
structural integrity ;-)
>>> Hi Eike,
>> *before* your question ;-)
>> Cheers
>> /Eike
>>> Harald
>>> Eike Stepper wrote:
>>>> Hi Harald,
>>>> other
>>>> Cheers
>>>> /Eike
>>>>> Hello,
>>>>> direction.
>>>>> Kind regards
>>>>> Harald
Re: tutorial fails: unresolved bundles [message #421565 is a reply to message #421527] Sat, 09 August 2008 15:35 Go to previous messageGo to next message
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
LOL :-)
Sorry, that I have to bother you with more trivial (for you) questions
again. Now, I have all classes/plugins generated without any errors.
When I try to start one of the plugins (according to the tutorial),
I get the error shown below.
Again: I checked for the existence of the file, which seems to cause the
trouble:
/usr/local/packages/eclipse/plugins/org.eclipse.core.runtime _3.4.0.v20080512.jar
it is there.
I assume, that I have to modify my startup/launch configuration anyhow.
But how?
And, if you answer my question, I promise to solve the 'time tunneling
problem' :-)
Thanks for your patience
Greetings Harald
org.osgi.framework.BundleException: Exception in
org.eclipse.equinox.internal.simpleconfigurator.Activator.st art() of
bundle org.eclipse.equinox.simpleconfigurator.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.IllegalStateException: Bundle
" reference:file:/usr/local/packages/eclipse/plugins/org.eclip se.core.runtime_3.4.0.v20080512.jar "
has been uninstalled
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.chec kValid(AbstractBundle.java:1228)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:262)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
at
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.startBundles(ConfigApplier.java:317)
at
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.install(ConfigApplier.java:86)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:12 4)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:13 8)
at
org.eclipse.equinox.internal.simpleconfigurator.Activator.st art(Activator.java:48)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
.... 21 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: tutorial fails: unresolved bundles [message #421566 is a reply to message #421565] Sun, 10 August 2008 02:05 Go to previous messageGo to next message
--------------070901060907010404020005
Hi Harald,
Maybe it's just that the versions that are stored in your launch config
don't exist anymore in your installation. Have you tried to "Add
Required Plugins" and "Validate" your launch config (Plugins tab)?
Enjoy your Sunday ;-)
/Eike
> Eike Stepper wrote:
>> Ed Merks schrieb:
>>> Eike,
> LOL :-)
> trouble:
> it is there.
> But how?
> problem' :-)
> Greetings Harald
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> .... 21 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hi Harald,<br>
<br>
Required Plugins" and "Validate" your launch config (Plugins tab)? <br>
<br>
Enjoy your Sunday ;-)<br>
/Eike<br>
<br>
<br>
<br>
<br>
<blockquote cite="mid:489DF19E.4000107@gmx.de" type="cite">
<pre wrap="">Eike Stepper wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Ed Merks schrieb:
</pre>
<pre wrap="">Eike,
</pre>
</blockquote>
<pre wrap="">Hehe, I'll beam it up to Scott when I solved some minor issues with
</pre>
</blockquote>
<pre wrap=""><!---->
LOL :-)
trouble:
it is there.
But how?
problem' :-)
Greetings Harald
at
at
at
at
at
at
at
at
at
at
at
at
at
"reference:<a class="moz-txt-link-freetext" href=" file:/usr/local/packages/eclipse/plugins/org.eclipse.core.ru ntime_3.4.0.v20080512.jar "> file:/usr/local/packages/eclipse/plugins/org.eclipse.core.ru ntime_3.4.0.v20080512.jar </a>"
at
at
at
at
at
at
at
at
at
at
..... 21 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
</blockquote>
</body>
</html>
--------------070901060907010404020005--
Re: tutorial fails: unresolved bundles [message #421567 is a reply to message #421566] Sun, 10 August 2008 03:49 Go to previous messageGo to next message
Eike Stepper wrote:
> Hi Harald,
yes, I tried that, and "Validate" tells me, that there aren't any
problems :~}
Looks like a broken installation - I just testes the "Hello World"
RCP example, which fails with the same (?) error.
I will reinstall everything from scratch.
You too (and apologies for sending my previous mail to your
personal e-mail address - I hit the wrong button).
Greetings Harald
Re: tutorial fails: unresolved bundles [message #421570 is a reply to message #421567] Sun, 10 August 2008 04:21 Go to previous messageGo to next message
ok, a few more details on this:
I reinstalled Eclipse (Ganymede)
eclipse-SDK-3.4-linux-gtk-x86_64.tar.gz
from scratch.
I tested the Hello-RCP example and it works (as expected).
I installed (via "Software Updated and Add-Ons) the
EMF SDK (EMF SDK 2.4.0 EMF + SDO + XSD)
"Hello-RCP" still works fine.
I created the 'library-project' as described in
the tutorial (from annotated java).
I get the "unresolved bundle" error as described in
my original posting.
I add EMF to my target platform (as suggested).
The errors in the EMF library project disappear.
When I try the "Hello RCP" now, I get the same error(s)
as in the EMF project (see at the bottom of the posting).
So, my conclusion is: installing EMF breaks my installation.
Greetings Harald
!SESSION 2008-08-10 10:19:28.780
eclipse.buildId=unknown
java.version=1.6.0_06
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -application hello_world.application
Command-line arguments: -application hello_world.application -data
/home/finster/workspace-test-1/../runtime-hello_world.applic ation -dev
file:/home/finster/workspace-test-1/.metadata/.plugins/org.e clipse.pde.core/hello_world.application/dev.properties
-os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2008-08-10 10:19:29.361
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.IllegalArgumentException: The System Bundle's start level can
not be modified.
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1117)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:642)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:619)
at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2008-08-10 10:19:29.363
!MESSAGE
!STACK 0
not be modified.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2008-08-10 10:19:29.366
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Platform not running
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
Re: tutorial fails: unresolved bundles [message #421572 is a reply to message #421570] Sun, 10 August 2008 04:41 Go to previous messageGo to next message
> Hello,
> from scratch.
That's hardly imagineable!
Try to "Reload" the target platform and "Clear the configuration area
before launching" in the launch config.
Check that the config area is writeable, etc.
Cheers
/Eike
> Greetings Harald
> !STACK 0
> not be modified.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> not be modified.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
Re: tutorial fails: unresolved bundles [message #421573 is a reply to message #421572] Sun, 10 August 2008 05:47 Go to previous message
maybe, I just wanted to be a bit provocative ;-)
this seems to do the trick - yes!
In addition, I reinstalled Eclipse in my 'private' (home) directory
instead of the system directory 9as before) in order to make sure,
that I have full permissions.
Seems to work for me at the moment.
Thanks a lot for your support.
Admittedly, I still do not understand the mechanism, how eclipse
manages plugins, bundles, target-platforms etc.
Greetings
Harald
Previous Topic:[CDO] New packages
Next Topic:TreeViewer refresh
Current Time: Sat Oct 11 11:23:06 EDT 2025
Powered by FUDForum. Page generated in 0.08215 seconds
