Home » Modeling » EMF » EMF databinding TableViewer
EMF databinding TableViewer [message #421466] |
Thu, 07 August 2008 11:13  |
Hi guys,
I am currently struggling with Toms approach of using databinding for
1:n TableViewers.
I have (or at least I think I have) followed the instructions and almost
copied the example of Tom (thanks for the great work).
My problem is that the list remains empty and I would very much
appreciate any hint about what I'm doing wrong or how I can debug this.
Here is the code of the View Part:
public void createPartControl(Composite parent) {
super.createPartControl(parent);
// my small example model
Domain dn = DomainFactory.eINSTANCE.createDomain();
Person p = DomainFactory.eINSTANCE.createPerson();
dn.getPersons().add(p);
// create the viewer
viewer = new TableViewer(parent, SWT.MULTI | SWT.H_SCROLL |
SWT.V_SCROLL | SWT.BORDER | SWT.FULL_SELECTION);
viewer.getControl().setLayoutData(new GridData(SWT.FILL, SWT.FILL,
true, true, 1, 1));
// set up the table
Table table = viewer.getTable();
TableLayout layout = new TableLayout();
table.setLayout(layout);
table.setHeaderVisible(true);
table.setLinesVisible(true);
// Define one exmaple column Columns
TableViewerColumn viewerColumn;
viewerColumn = new TableViewerColumn(viewer, SWT.NONE);
// for simplification I use the standard labelprovider
viewerColumn.setLabelProvider(new ColumnLabelProvider());
viewerColumn.getColumn().setText("Last Name, First Name");
viewerColumn.getColumn().setWidth(200);
viewerColumn.getColumn().setMoveable(true);
// Content Provider
ObservableListContentProvider contentProvider = new
ObservableListContentProvider();
viewer.setContentProvider(contentProvider);
// set input
IObservableList list = EMFObservables.observeList(dn,
DomainPackage.Literals.PERSON__SEMESTERS);
viewer.setInput(list);
Thanks for your help.
Axel
Re: EMF databinding TableViewer [message #421469 is a reply to message #421466] |
Thu, 07 August 2008 11:58   |
Axel Nitert schrieb:
> Hi guys,
> 1:n TableViewers.
> true, true, 1, 1));
> // set up the table
> // Content Provider
> // set input
My guess is that you are getting an exception in your error-log but you
have not been running under -consoleLog because the feature you want to
observe DOMAIN__PERSONS-Feature or am I missing something obvious (I
make the assumption from the title of the column 'Last Name, First Name' ).
My guess of your model looks like this:
Domain
1 - n Person
1 - n Semesters
Is that correct? So what would you like to represent in the viewer?
The list of persons => The viewer is the master
The semsters of a person => The viewer is the detail and you need to use
a EMFObservable#observeDetailList.
So taking this together I think you need to modify your code from above
like this:
--------8<--------
// set input
dn,
DomainPackage.Literals.DOMAIN__PERSONS);
IObservableValue master = ViewerObservables.observeSingleSelection(viewer);
// The detail viewer
TableViewer semesterViewer = new TableViewer(....);
TableViewerColumn c = ......
ObservableListContentProvider contentProvider2 = new
semesterViewer.setContentProvider(contentProvider2);
IObservableList detailList = EMFObservables.observeDetailList(
Realm.getDefault(),
master
semesterViewer.setInput(detailList);
--------8<--------
This is untested code and based on the assumptions I made from your code
so it might be inaccurate :-)
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: EMF databinding TableViewer [message #421471 is a reply to message #421469] |
Thu, 07 August 2008 12:46   |
>> Hi guys,
>> 1:n TableViewers.
>> almost copied the example of Tom (thanks for the great work).
>> // my small example model Domain dn =
>> // create the viewer viewer = new TableViewer(parent,
>> SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER |
>> true, true, 1, 1));
>> // set up the table
>> // Content Provider ObservableListContentProvider
>> contentProvider = new ObservableListContentProvider();
>> // set input
> Domain
> 1 - n Person
> 1 - n Semesters
> like this:
> --------8<--------
> // set input
> dn,
> Realm.getDefault(),
> master
> --------8<--------
> Tom
Hi Tom,
thanks for the answer. The issue that I am struggling with is more
complex. I want to use the observable list with an EMF linked to a
database (TENEO, Hibernate). In order to narrow down the issue I have
reduced the code and this is why I left PERSON__SEMESTERS in the list.
You are totally right when I replace then code
with
my example works fine.
NOW, back to the original issue. If I use the same code with a
// this prints 3 elements
System.out.println(DomainUtil.getRoot().getPersons().size()) ;
IObservableList list = EMFObservables.observeList(DomainUtil.getRoot(),
The list is still empty and I do not get any exceptions (I have now
-consoleLog switched on ;-) ).
The method DomainUtil.getRoot simply returns the root object that was
create with the following code (the resource is a hibernate teneo resource):
try {
resource.load(Collections.EMPTY_MAP);
} catch (IOException e) {
e.printStackTrace();
if (resource.getContents().size()>0) {
root = (Domain)resource.getContents().get(0);
Do you have any idea what can make the difference here?
By the way thanks for the master detail code this is one of the next
viewers that I am going to create.
Best regards
Axel
Re: EMF databinding TableViewer [message #421477 is a reply to message #421471] |
Thu, 07 August 2008 13:58   |
This certainly looks like a teneo/proxy issue? I guess simply asking for
the for size of a list won't materialize it but I really really have no
idea what's going on here, I've never used teneo myself but if the code
you posted previously works it must be some issue with teneo or proxies.
Did you tried steping through the code with a debugger to see what's
really going on? The only thing you now know is that databinding works
appropiately and the problem is some where else :-(
Tom
>>> Hi guys,
>>> 1:n TableViewers.
>>> SWT.FILL, true, true, 1, 1));
>>> // set up the table
>>> // set input
>> you have not been running under -consoleLog because the feature you
>> want to observe DOMAIN__PERSONS-Feature or am I missing something
>> obvious (I make the assumption from the title of the column 'Last
>> Domain
>> 1 - n Person
>> 1 - n Semesters
>> use a EMFObservable#observeDetailList.
>> above like this:
>> --------8<--------
>> // set input
>> dn,
>> Realm.getDefault(),
>> master
>> --------8<--------
>> code so it might be inaccurate :-)
>> Tom
> Hi Tom,
> with
> resource):
> try {
> Best regards
> Axel
Re: EMF databinding TableViewer [message #421481 is a reply to message #421477] |
Thu, 07 August 2008 14:41   |
Tom,
thanks for the reply.
I agree that it obviously has got something to do with teneo. I tried to
go through the code using the debugger but the thing is that I have no
idea what happens after I call setInput. I thought that the
ContenProviders method getElements should be called. But it isn't.
Do you have an additional hint where the best place would be to set the
breakpoint?
The IObeservableList looks good as far as I can see. there are three
elements in the list.
May be I'll have a look at the teneo forum. It could be a bug with the
setup I chose.
Teneo is really a great framework to persist the EMF model to a
relational database without spending too much time with matching fields
to table columns.
Thanks and best regards
Axel
> Tom
>>>> Hi guys,
>>>> for 1:n TableViewers.
>>>> // set up the table
>>>> // set input
>>> Domain
>>> 1 - n Person
>>> 1 - n Semesters
>>> above like this:
>>> --------8<--------
>>> // set input
>>> dn,
>>> Realm.getDefault(),
>>> master
>>> --------8<--------
>>> Tom
>> Hi Tom,
>> with
>> resource):
>> try {
>> Best regards
>> Axel
Re: EMF databinding TableViewer [message #421486 is a reply to message #421481] |
Thu, 07 August 2008 15:56   |
Axel,
I don't see anything obviously wrong. Generally Teneo will just surface
things in a transparent way so everything ought to be working nicely.
Axel Nitert wrote:
> Tom,
> to go through the code using the debugger but the thing is that I have
> no idea what happens after I call setInput. I thought that the
> the breakpoint?
> setup I chose.
> fields to table columns.
> Axel
>> for the for size of a list won't materialize it but I really really
>> have no idea what's going on here, I've never used teneo myself but
>> if the code you posted previously works it must be some issue with
>> teneo or proxies.
>> works appropiately and the problem is some where else :-(
>> Tom
>>>>> Hi guys,
>>>>> this.
>>>>> TableViewer(parent, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL |
>>>>> // set up the table
>>>>> // Content Provider
>>>>> // set input
>>>> Domain
>>>> 1 - n Person
>>>> 1 - n Semesters
>>>> to use a EMFObservable#observeDetailList.
>>>> above like this:
>>>> --------8<--------
>>>> // set input
>>>> dn,
>>>> Realm.getDefault(),
>>>> master
>>>> --------8<--------
>>>> Tom
>>> Hi Tom,
>>> have reduced the code and this is why I left PERSON__SEMESTERS in
>>> the list.
>>> with
If you print out the DomainUtil.getRoot() list it's not empty? It's
really a list of Domain instances?
Should the observable list really be the input? Probably dumb question....
>>> was create with the following code (the resource is a hibernate
>>> teneo resource):
>>> try {
>>> Best regards
>>> Axel
Re: EMF databinding TableViewer [message #421488 is a reply to message #421486] |
Thu, 07 August 2008 16:37   |
Ed,
I was successfully using the following content and label providers before:
viewer.setContentProvider(new
AdapterFactoryContentProvider(editingDomain.getAdapterFactor y()));
viewer.setLabelProvider(new
AdapterFactoryLabelProvider(editingDomain.getAdapterFactory( )));
and set the input with:
viewer.setInput(new
ItemProvider("Persons",null,DomainUtil.getRoot().getPersons()));
This was working great except that the view didn't update when adding or
removing persons in the model.
Back to your questions:
-> Well, getRoot() returns one single element: the Domain. The domain
itself has a method called getPersons(). It's a 1:n relation. I thought
that I have to create the observablelist with the code mentioned above.
May be I am doing something wrong here.
-> I don't know another way to show the person list of the Domain object.
Any further suffestion for debugging?
Best regards
Axel
Ed Merks schrieb:
> Axel,
> Axel Nitert wrote:
>> Tom,
>> the breakpoint?
>> setup I chose.
>> Axel
>>> teneo or proxies.
>>> Tom
>>>>>> Hi guys,
>>>>>> this.
>>>>>> // set up the table
>>>>>> // Content Provider
>>>>>> // set input
>>>>> Domain
>>>>> 1 - n Person
>>>>> 1 - n Semesters
>>>>> above like this:
>>>>> --------8<--------
>>>>> // set input
>>>>> dn,
>>>>> Realm.getDefault(),
>>>>> master
>>>>> --------8<--------
>>>>> Tom
>>>> Hi Tom,
>>>> the list.
>>>> with
>>>> teneo resource):
>>>> try {
>>>> Best regards
>>>> Axel
Re: EMF databinding TableViewer [message #421490 is a reply to message #421488] |
Thu, 07 August 2008 16:52   |
Axel,
Comments below.
Axel Nitert wrote:
> Ed,
> before:
> viewer.setInput(new
> or removing persons in the model.
It seems to me the input should have been the getRoot() object. What
happens if you did that instead? Does it show more than just the
persons list?
> thought that I have to create the observablelist with the code
> mentioned above. May be I am doing something wrong here.
I'm not sure the viewer has any special support for an observable list;
maybe that's just my data binding ignorance.
> question....
But a breakpoint some of the AdapteFactoryContentProvider methods like
getElements and getChildren. Likely you'll find the list is the
"object" passed in and it can't be adapted hence you get nothing in the
view...
> Best regards
> Axel
> Ed Merks schrieb:
>> Axel,
>> surface things in a transparent way so everything ought to be working
>> nicely.
>> Axel Nitert wrote:
>>> Tom,
>>> tried to go through the code using the debugger but the thing is
>>> that I have no idea what happens after I call setInput. I thought
>>> that the ContenProviders method getElements should be called. But it
>>> isn't.
>>> the breakpoint?
>>> the setup I chose.
>>> Axel
>>>> asking for the for size of a list won't materialize it but I really
>>>> really have no idea what's going on here, I've never used teneo
>>>> myself but if the code you posted previously works it must be some
>>>> what's really going on? The only thing you now know is that
>>>> databinding works appropiately and the problem is some where else :-(
>>>> Tom
>>>>>>> Hi guys,
>>>>>>> databinding for 1:n TableViewers.
>>>>>>> and almost copied the example of Tom (thanks for the great work).
>>>>>>> debug this.
>>>>>>> // set up the table
>>>>>>> // Content Provider
>>>>>>> // set input
>>>>>> but you have not been running under -consoleLog because the
>>>>>> feature you want to observe DOMAIN__PERSONS-Feature or am I
>>>>>> missing something obvious (I make the assumption from the title
>>>>>> Domain
>>>>>> 1 - n Person
>>>>>> 1 - n Semesters
>>>>>> above like this:
>>>>>> --------8<--------
>>>>>> // set input
>>>>>> dn,
>>>>>> Realm.getDefault(),
>>>>>> master
>>>>>> --------8<--------
>>>>>> your code so it might be inaccurate :-)
>>>>>> Tom
>>>>> Hi Tom,
>>>>> the list.
>>>>> with
>> question....
>>>>> now -consoleLog switched on ;-) ).
>>>>> teneo resource):
>>>>> try {
>>>>> next viewers that I am going to create.
>>>>> Best regards
>>>>> Axel
Re: EMF databinding TableViewer [message #421934 is a reply to message #421720] |
Mon, 18 August 2008 15:15   |
Hi Tom,
I didn't have much time to go through your code and unfortunately a
BundleException when I was trying to run the example (using Ganymede on
mac os and windows).
However, I was able to understand what the code is about and I have to
say that this is really a very interesting example which covers lots of
differenf aspects of a data based RCP application.
Honestly, I think it is even a bit too complex to go into the topic of
data binding. Going through the way of Datasource, DatasourceService,
PersistenceService and PersistenceRegistry really consumes a lot of time
without the appropriate examplanation.
So, I am really hoping that you are adding a great tutorial to this
excellent piece of code.
Now, self-interested as I am ;-) I would like to come back to my
original problem which I still wasn't able to solve.
But at least I think I found out what the problem is.
HibernatePersistableEList<E>(PersistableEList<E>).equals(Object) line: 550
EditingDomainEObjectObservableList(ObservableList).equals(Ob ject) line: 87
TableViewer(StructuredViewer).equals(Object, Object) line: 684
TableViewer(AbstractTableViewer).internalRefresh(Object, boolean) line: 631
TableViewer(AbstractTableViewer).internalRefresh(Object) line: 620
AbstractTableViewer$2.run() line: 576
The internally used PersistableEList is not equal to the
EditingDomainEObjectObservableList which prevents the function
internalRefresh from calling internalRefreshAll which then calls
getElements().
The code is still the same as in ther very beginning of my example and
it seems that this issue is really related to teneo.
May be, you have another idea why the two lists are different.
BTW, the function internalRefresh is called twice. 1. on
viewer.setLabelProvider which is then correctly calling
internalRefreshAll but without any data to display and then 2. on
setInput with the behaviour described above.
I will go on debugging but would really appreciate any additional help.
Thanks.
Axel
> Hi Axel,
> Yesterday I proposed a talk about this tutorial for ESE. You can follow
> the submission here [1] or leave a comment.
> Tom
> [1] https://www.eclipsecon.org/submissions/view_talk.php?id=48
>> Tom, Ed,
>> I will have a look into Toms EMF Data-Binding example. But this week I
>> am very busy. Either I find the solution myself or I will send you an
>> example which isolates the problem.
>> It's great to have an example which combines all these fancy
>> technologies. May be I can add some ideas for Teneo to your example.
>> Let's see. Thanks so far.
>> Axel
Re: EMF databinding TableViewer [message #421938 is a reply to message #421934] |
Mon, 18 August 2008 15:47   |
Hi again,
I found a workaround after I wrote the last post. It simply came to my
mind after pressing save.
I have added a comparer to my TableViewer which looks like this:
IElementComparer elistComparer = new IElementComparer() {
public boolean equals(Object a, Object b) {
if (a instanceof EditingDomainEObjectObservableList
&& b instanceof EditingDomainEObjectObservableList) {
return a==b;
return a.equals(b);
public int hashCode(Object element) {
return element.hashCode();
And then of course I added viewer.setComparer(elistComparer).
I don't know if this is the best way but at least it solved my problem
so far.
What do you think?
Axel
> Hi Tom,
> 550
> 87
> 631
> getElements().
> Thanks.
> Axel
>> Hi Axel,
>> follow the submission here [1] or leave a comment.
>> Tom
>>> Tom, Ed,
>>> I am very busy. Either I find the solution myself or I will send you
>>> an example which isolates the problem.
>>> Axel
Re: EMF databinding TableViewer [message #421951 is a reply to message #421938] |
Tue, 19 August 2008 05:48   |
Hi Axel,
I really need a sample project to track this down :-) What is the call
stack to get to internalRefresh(Object,boolean)?
Tom
> Hi again,
> return a==b;
> return a.equals(b);
> so far.
> What do you think?
> Axel
>> Hi Tom,
>> on mac os and windows).
>> of differenf aspects of a data based RCP application.
>> time without the appropriate examplanation.
>> 550
>> line: 87 TableViewer(StructuredViewer).equals(Object, Object) line:
>> 684 TableViewer(AbstractTableViewer).internalRefresh(Object,
>> boolean) line: 631
>> getElements().
>> Thanks.
>> Axel
>>> Hi Axel,
>>> Tom
>>>> Tom, Ed,
>>>> Axel
Re: [Teneo] Violates List.equal()-contract [was Re: EMF databinding TableViewe] [message #422220 is a reply to message #422213] |
Tue, 26 August 2008 08:19   |
Hi Tom,
That's right, that's why Teneo violates the equals of a list implementation. I can make it so that
it does a real equals if the list has already been loaded but that only solves part of the issues.
Fyi, Hibernate also does equals on collections in a bit different way (uses the key of the owner and
the name of the efeature holding the collection).
I need to know a bit more about how the equals check is done.
Can you post the code snippet that does the equals on the elist (and the equals implementation of
the list wrapper)? What gets passed to the equals, the wrapped list or the wrapperlist?
gr. Martin
Tom Schindl wrote:
> Hi Axel,
> Thanks for the project. It's in fact a Teneo vs Standard-List definition
> problem. PersistableEList is breaking the List.equals-contract defined
> in the List-interface which defines the following:
> * Compares the specified object with this list for equality. Returns
> * <tt>true</tt> if and only if the specified object is also a list, both
> * lists have the same size, and all corresponding pairs of elements in
> * the two lists are <i>equal</i>. (Two elements <tt>e1</tt> and
> * <tt>e2</tt> are <i>equal</i> if <tt>(e1==null ? e2==null :
> * e1.equals(e2))</tt>.) In other words, two lists are defined to be
> * equal if they contain the same elements in the same order. This
> * definition ensures that the equals method works properly across
> * different implementations of the <tt>List</tt> interface.
> * @param o the object to be compared for equality with this list.
> * @return <tt>true</tt> if the specified object is equal to this list.
> boolean equals(Object o);
> But I think Teneo has good reasons to violate this contract because
> without violating LazyLoading would not work, I guess because the whole
> list has to materialized to compare to Lists (Am I right Martin?).
> IMHO there are multiple things to fix.
> a) Databinding uses a highly in effecient way to check the equality of
> its wrapped lists. I filed [1] and with this fix even Teneo-Lists
> work aproppiately.
> b) Teneos PersistableEList should IMHO at least use Object#hashCode() in
> its equal check if it can not fullfill the List#equals-contract so
> databindings design with WrappedLists would work too. If Databinding
> doesn't release a fix in time for 3.4.1 (whose deadline is already
> tomorrow I has Ed whether we could get a fix in the
> EMF-Observables-List)
> Tom
> [1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=245183
>> Could please file a bug against EMF attach me to it? Please also post
>> the bug number to this thread.
>> Tom
>>> Ah you need to use jface.databinding from 3.4.1-maint or head. The
>>> databinding guys fixed a bug in their implementation. I'll add a
>>> version to my MANIFEST.MF.
>>> Tom
>>>> Hi Tom,
>>>> You are right the problem is solved now. But after configuring a new
>>>> data source I have opened the association administration and receive
>>>> the attached exception in the view on the right hand side.
>>>> May be I am still doing something wrong.
>>>> By the way I have finished preparing my example project which you
>>>> could use to check my original problem. I will send it to you via
>>>> email shortly.
>>>> Thanks again
>>>> Axel
>>>> java.lang.NullPointerException
>>>> at
>>>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1532)
>>>> at
>>>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1027)
>>>> at
>>>> at.bestsolution.soccer.core.model.soccer.impl.SoccerImpl.eGe t(SoccerImpl.java:196)
>>>> at
>>>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1012)
>>>> at
>>>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1004)
>>>> at
>>>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:999)
>>>> at
>>>> org.eclipse.emf.databinding.EObjectObservableMap.doGet(EObje ctObservableMap.java:83)
>>>> at
>>>> org.eclipse.core.databinding.observable.map.ComputedObservab leMap$1.handleSetChange(ComputedObservableMap.java:52)
>>>> at
>>>> org.eclipse.core.databinding.observable.set.SetChangeEvent.d ispatch(SetChangeEvent.java:61)
>>>> at
>>>> org.eclipse.core.databinding.observable.ChangeManager.fireEv ent(ChangeManager.java:129)
>>>> at
>>>> org.eclipse.core.databinding.observable.set.ObservableSet.fi reSetChange(ObservableSet.java:67)
>>>> at
>>>> org.eclipse.core.internal.databinding.observable.Unmodifiabl eObservableSet.access$0(UnmodifiableObservableSet.java:1)
>>>> at
>>>> org.eclipse.core.internal.databinding.observable.Unmodifiabl eObservableSet$1.handleSetChange(UnmodifiableObservableSet.j ava:30)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableSet.access$1(DetailObservableSet.java:1)
>>>> at
>>>> org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableSet$1.handleSetChange(DetailObservableSet. java:42)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.eclipse.core.databinding.observable.set.WritableSet.add( WritableSet.java:90)
>>>> at
>>>> org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableSet.add(DetailObservableSet.java:106)
>>>> at
>>>> org.eclipse.jface.internal.databinding.viewers.ObservableCol lectionTreeContentProvider$TreeNode. <init>(ObservableCollectionTreeContentProvider.java:284)
>>>> at
>>>> org.eclipse.jface.internal.databinding.viewers.ObservableCol lectionTreeContentProvider.getOrCreateNode(ObservableCollect ionTreeContentProvider.java:181)
>>>> at
>>>> org.eclipse.jface.internal.databinding.viewers.ObservableCol lectionTreeContentProvider.getChildren(ObservableCollectionT reeContentProvider.java:162)
>>>> at
>>>> org.eclipse.jface.internal.databinding.viewers.ObservableCol lectionTreeContentProvider.getElements(ObservableCollectionT reeContentProvider.java:158)
>>>> at
>>>> org.eclipse.jface.databinding.viewers.ObservableListTreeCont entProvider.getElements(ObservableListTreeContentProvider.ja va:155)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:937)
>>>> at
>>>> org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1330)
>>>> at
>>>> org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:385)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChil dren(AbstractTreeViewer.java:636)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:602)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:799)
>>>> at
>>>> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
>>>> at
>>>> org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.internalInitial izeTree(AbstractTreeViewer.java:1490)
>>>> at
>>>> org.eclipse.jface.viewers.TreeViewer.internalInitializeTree( TreeViewer.java:823)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1474)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1365)
>>>> at
>>>> org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:397)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1328)
>>>> at
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1467)
>>>> at
>>>> org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
>>>> at
>>>> at.bestsolution.soccer.ui.associationadmin.AssociationAdmini strationViewPart.updateState(AssociationAdministrationViewPa rt.java:243)
>>>> at
>>>> at.bestsolution.soccer.ui.associationadmin.AssociationAdmini strationViewPart.createPartControl(AssociationAdministration ViewPart.java:212)
>>>> at
>>>> org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
>>>> at
>>>> org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
>>>> at
>>>> org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2127)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1062)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.j ava:3773)
>>>> at
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3770)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3746)
>>>> at
>>>> at.bestsolution.soccer.ui.associationadmin.handler.OpenAssoc iationAdministrationHandler.execute(OpenAssociationAdministr ationHandler.java:22)
>>>> at
>>>> org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
>>>> at
>>>> org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
>>>> at
>>>> org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
>>>> at
>>>> org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
>>>> at
>>>> org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
>>>> at
>>>> org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:619)
>>>> at
>>>> org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:605)
>>>> at
>>>> org.eclipse.ui.menus.CommandContributionItem$4.handleEvent(C ommandContributionItem.java:595)
>>>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
>>>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1561)
>>>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1585)
>>>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1570)
>>>> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 360)
>>>> at
>>>> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3474)
>>>> at
>>>> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3064)
>>>> at
>>>> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
>>>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
>>>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
>>>> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
>>>> at
>>>> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
>>>> at
>>>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
>>>> at
>>>> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>>>> at
>>>> at.bestsolution.soccer.app.intro.Application.start(Applicati on.java:20)
>>>> at
>>>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>> at
>>>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>>>> at
>>>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>>>> at java.lang.reflect.Method.invoke(Method.java:585)
>>>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
>>>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
>>>> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
>>>> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Violates List.equal()-contract [was Re: EMF databinding TableViewe] [message #422222 is a reply to message #422221] |
Tue, 26 August 2008 09:24   |
Hi Tom,
Hmm, would it make sense that the ObservableList.equals would do something like this:
public boolean equals(Object o) {
getterCalled();
if( o == this ) {
return true;
if (o instanceof ObservableList) {
final List otherWrappedList = ((ObservableList)o).getWrappedList();
return wrappedList.equals(otherWrappedList);
return wrappedList.equals(o);
ObservableList does not have a getWrappedList method, but maybe something else can be used to get to
the wrappedList member.
So when equaling on a ObservableList, that if the wrappedLists of two ObservableLists are equal then
the ObservableLists are equal. I am not limited by any knowledge of ObservableList :-) but it seems
an okay definition imho.
What do you think?
gr. Martin
Tom Schindl wrote:
> Hi Martin,
> The code in question is shown in
> org/eclipse/core/databinding/observable/list/ObservableList. java
> Until now the code looked like this:
> ----------8<----------
> getterCalled();
> So when you have
> ObservableList a(ObservableList (id=140))
> a.wrappedList(PersistableEList(id=141))
> ObservableList b(ObservableList (id=140))
> b.wrappedList(PersistableEList(id=141))
> and you call a.equals(b) you'll get false because the code executed in
> then is
> wrappedList(PersistableEList(id=141)).equals(o(ObservableLis t (id=140)))
> which will result in false because of the equals definition in
> PersistableEList. Matt and Boris already approved the following change
> to the ObservableList#equals() for 3.4.1 (today is the last dev day for
> 3.4.1).
> getterCalled();
> if( o == this ) {
> return true;
> I also proposed a second patch (in the bug report 245183) where I was
> passing on the wrapped list but it looks like this won't make it in the
> general framework. This is not ideal because then we'll have the same
> problem we have before in cases like this:
> ObservableList a(ObservableList (id=142))
> If the situation stays like this we have 2 possibilities:
> a) You rewrite the equals-method of PersistableEList like this:
> equals(Object o) {
> if( o == this ) {
> return true;
> } else if( o.hashCode() == this.hashCode() ) {
> return true;
> // Maybe do the full compare when list is materialized
> return false;
> b) We (Ed) overloads equals in
> org.eclipse.emf.databinding.EObjectObservableList and does what I
> proposed in https://bugs.eclipse.org/bugs/show_bug.cgi?id=245183#c2
> Tom
> Martin Taal schrieb:
>> Hi Tom,
>> implementation. I can make it so that it does a real equals if the
>> (uses the key of the owner and the name of the efeature holding the
>> collection).
>> the equals implementation of the list wrapper)? What gets passed to
>> gr. Martin
The Netherlands
Re: [Teneo] Violates List.equal()-contract [was Re: EMF databinding TableViewe] [message #422223 is a reply to message #422222] |
Tue, 26 August 2008 09:32   |
It's quite easy to get access to the wrappedList because you can simply
do ((ObservableList)o).wrappedList which is protected so could also be
reach in subclasses too ;-)
And that's what I proposed in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245183#c2 and Matt replied
in comment 3 voting against. I once more asked for clarification and
potential addition of this in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245183#c17
I think we should continue discussion in the bug report because I don't
know if Boris and Matt are following this newsgroup.
Tom
> Hi Tom,
> getterCalled();
> if( o == this ) {
> return true;
> something else can be used to get to the wrappedList member.
> ObservableLists are equal then the ObservableLists are equal. I am not
> limited by any knowledge of ObservableList :-) but it seems an okay
> definition imho.
> What do you think?
> gr. Martin
> Tom Schindl wrote:
>> Hi Martin,
>> getterCalled();
>> So when you have
>> then is
>> for 3.4.1).
>> getterCalled();
>> if( o == this ) {
>> return true;
>> the general framework. This is not ideal because then we'll have the
>> same problem we have before in cases like this:
>> equals(Object o) {
>> if( o == this ) {
>> return true;
>> return true;
>> return false;
>> Tom
>>> Hi Tom,
>>> collection).
>>> gr. Martin
Re: [Teneo] Violates List.equal()-contract [was Re: EMF databinding TableViewe] [message #422256 is a reply to message #422223] |
Wed, 27 August 2008 08:47  |
Just for the ones who are not described to the bug. Thanks to the quick
response of Matt and Boris a fix (which we are all happy with went) into
3.4.1.
Tom
> Tom
>> Hi Tom,
>> getterCalled();
>> if( o == this ) {
>> return true;
>> definition imho.
>> What do you think?
>> gr. Martin
>> Tom Schindl wrote:
>>> Hi Martin,
>>> getterCalled();
>>> So when you have
>>> in then is
>>> change to the ObservableList#equals() for 3.4.1 (today is the last
>>> dev day for 3.4.1).
>>> getterCalled();
>>> if( o == this ) {
>>> return true;
>>> equals(Object o) {
>>> if( o == this ) {
>>> return true;
>>> return true;
>>> return false;
>>> Tom
>>>> Hi Tom,
>>>> way (uses the key of the owner and the name of the efeature holding
>>>> the collection).
>>>> gr. Martin
Current Time: Tue Aug 12 01:50:29 EDT 2025
Powered by FUDForum. Page generated in 0.18862 seconds
