XPath syntax problem when importing an XML-Schema [message #420734] |
Wed, 09 July 2008 09:06 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: erwann.poupart.cnes.fr
I have got the following error message probably due to an unaccepted Xpath
syntax
when i try to create a new EMF Model starting from the XML-Schema below.
I use Eclipse 3.4, and EMF version 2.4.0.
Error Message :
"Problems were detected when validating and converting the XMLSchemas"
Error : XSD : the value xtce:TelemetryMetaData/ParameterTypeSet/* |
xtce:CommandMetaData/ParameterTypeSet/* of attribute xpath must conform to
pattern '(\. ......
This XML-Schema is considered as valid by XMLSpy and corresponds to an
OMG/SDTF standard (see :
http://www.omg.org/spec/XTCE/20061101/06-11-06.xsd)
Thank You for any help,
Best Regards
Erwann.
FUDForum. Page generated in 0.04409 seconds
