[Announce] EMF Teneo Builds [message #419765] |
Fri, 06 June 2008 04:14  |
This post is here to act as a container for all the Teneo build notices.
Note that Teneo has graduated incubation and thus these notices will now
appear in eclipse.tools.emf instead of eclipse.technology.emft.
Re: [Announce] EMF TENEO 1.0.1 M200809231814 is available [message #423286 is a reply to message #423223] |
Fri, 26 September 2008 06:27   |
Hi Neil,
I tested this. I downloaded a fresh eclipse 3.4 and then went through the update manager to install
new features, only the Teneo build from the 21st of september was listed. So I installed this. This
went fine afaics.
Then I downloaded the 23 sept. build separately and put it in the dropins (unzipped the zip file in
the dropins). After restarting only the org.eclipse.emf.teneo plugin was from the 23 sept. build,
the other teneo builds were from the 21st.
Then I went to the update manager and selected the teneo feature (21 sept.) and selected update. Now
the 23 sept. build was shown to me and I could select it and install it.
After restarting the 23 sept. build was there.
I am not at all a p2 expert so I am not sure why using the dropins folder did not work (directly
putting them in the eclipse directory won't work with 3.4). The update manager worked for me though.
Can you try just to update the Teneo feature?
gr. Martin
Neil Brennan wrote:
> On Wed, 24 Sep 2008 06:30:23 +0000, Martin Taal wrote:
>> http://www.eclipse.org/modeling/emf/news/relnotes.php?
> project=teneo&version=M200809231814
>> http://www.eclipse.org/modeling/emf/downloads/?
> project=teneo&showAll=1&hlbuild=M200809231814#M20080 9231814
> Hi. This may be a little off-topic, but I am having HEAPS of trouble
> installing this update on Ganymede 3.4 on Mac OS X 10.5.5
> Updating via the p2 equinox interface just hangs forever when I try,
> and nothing is getting picked up when I drop the package in the
> dropins folder.
> Even putting the features and plugins directly into the matching
> directories in my Eclipse install does not result in them being recognised
> in any way.
> Any help at all would be very much appreciated.
> Regards,
> Neil Brennan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Announce] EMF TENEO 1.1.0M5 is available [message #428105 is a reply to message #428100] |
Tue, 10 March 2009 15:45   |
Hi Stéphane,
All relevant questions. The changes since 1.0.0 can be found in the release notes. This search gave 68 issues/feature
changes.
http://www.eclipse.org/modeling/emf/news/relnotes.php?projec t=teneo&version=1.0.x&types=
Some annotations have been added, but most of them are bug fixes.
Another important development is support for EclipseLink.This has been added in the 1.0.4 build/1.1.0 build. We have not
announced it yet because we need to add some documentation and also generate the orm.xml.
The 1.0.4 and 1.1.0 builds are done using the same source code base. So there is no difference between the two, other
than that the environment in which the build/tests are done is different (eclipse 3.4/emf 2.4 versus eclipse 3.5/emf
2.5). The current architecture of Teneo allows it to be gradually extended with new annotations without breaking other
behavior that's why I can keep one code base.
gr. Martin
Stéphane Fournier wrote:
> Hi Martin,
> I clicked the link to the release notes but it's still empty.
> Could you provide it asap please ?
> What is the Teneo 1.1.0 roadmap ? What are the new features ? ... I did
> not find any plan on the web.
> If I've clearly understood : - Teneo 1.0.0 runs against EMF 2.3 ?
> - Teneo 1.0.1, 1.0.2, 1.0.3... runs against EMF 2.4 ?
> - Teneo 1.1.0 runs against EMF 2.5 ?
> Where can I find the differences between 1.0.0 and 1.0.1 (1.0.2) in
> terms of features ?
> Stephane.
> Martin Taal wrote:
>> The following build [1] will be available at eclipse.org in the next
>> 30-60
> mins.
>> [1]
> http://www.eclipse.org/modeling/emf/downloads/?project=teneo &showAll=1&hlbuild=S200902270403#S200902270403
>> Updated release notes [2] should be updated within 24hrs.
>> [2]
> http://www.eclipse.org/modeling/emf/news/relnotes.php?projec t=teneo&version=1.1.0M5
The Netherlands
FUDForum. Page generated in 0.21285 seconds
