Home » Modeling » EMF » AdapterFactoryLabelProvider doesnt work in TableViewer
AdapterFactoryLabelProvider doesnt work in TableViewer [message #418591] Mon, 21 April 2008 12:25 Go to next message
i am trying to set up a table containing EObject instances:
TableViewer viewer = new TableViewer(myTable);
//viewer.setLabelProvider(new AdapterFactoryLabelProvider(new
MyModelItemProviderAdapterFactory()));
viewer.add(myEObjectList.toArray());
If I use this without a LableProvider the rows are created i can see the
standard toString representations of the EObjects. But if i use the
Labelprovider Second line in the snippet), the rows remain white. I use
the same LabelProvider for a treeview, where it works fine:
public class LabelProvider extends AdapterFactoryLabelProvider implements
ILabelProvider {
public LabelProvider() {
super(new ModelItemProviderAdapterFactory());
Thanks for any help.
Re: AdapterFactoryLabelProvider doesnt work in TableViewer [message #418599 is a reply to message #418591] Mon, 21 April 2008 16:49 Go to previous messageGo to next message
Jonas,
Comments below.
Jonas wrote:
Did you set the content provider? I guess not, but that's kind of expected.
> the standard toString representations of the EObjects. But if i use
> the Labelprovider Second line in the snippet), the rows remain white.
> I use the same LabelProvider for a treeview, where it works fine:
It works in the standard generated editor as well, right?
> ILabelProvider {
Does your model support column label providers? In Eclipse 2.4 there's
new support for populating a column viewer based on some property of the
object. Which version are you using?
Re: AdapterFactoryLabelProvider doesnt work in TableViewer [message #418624 is a reply to message #418599] Tue, 22 April 2008 09:55 Go to previous messageGo to next message
>> Hi,
No the list that i am providing is a list of referenced EObjects. So the
standard Content Provider should not work.
Yes it does...
>> ILabelProvider {
I am using Ganymede M 5 and EMF 2.4
Re: AdapterFactoryLabelProvider doesnt work in TableViewer [message #418625 is a reply to message #418624] Tue, 22 April 2008 10:08 Go to previous messageGo to next message
Jonas,
I'm not sure what to suggest. Setting a breakpoints in the label
providers getColumText method will maybe help track down where things
are going astray...
Jonas wrote:
>>> Hi,
>> expected.
> the standard Content Provider should not work.
>>> white. I use the same LabelProvider for a treeview, where it works
>>> fine:
> Yes it does...
>>> implements
>>> ILabelProvider {
>> there's new support for populating a column viewer based on some
>> property of the object. Which version are you using?
Re: AdapterFactoryLabelProvider doesnt work in TableViewer [message #418760 is a reply to message #418625] Mon, 28 April 2008 17:12 Go to previous message
I finally found the problem:
1. I had to turn on "Create column provider" in genModel
2. Set the lableprovider before populating the table!
Anyway, thanks Ed!
Jonas
Ed Merks schrieb:
> Jonas,
> are going astray...
> Jonas wrote:
>>>> Hi,
>>> expected.
>>>> fine:
>> Yes it does...
>>>> implements
>>>> ILabelProvider {
Previous Topic:AdapterFactories
Next Topic:warning dialog when editing property in properties sheet
Current Time: Fri Jul 18 13:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.28491 seconds
