Home » Modeling » EMF » efficient emf query
| efficient emf query [message #417952] |
Mon, 31 March 2008 08:34  |
I executed the EMF query Library application which consists of the EMF
model (Writer, Book, Borrower, Library etc.)
------------------------:Consider the statement :------------------
"To select the borrowers of the books a particular writer has written"
Writer myWriter = (Writer)value; //assume I get the writer object here
String name = myWriter.getName();
EObjectCondition condition = new EObjectReferenceValueCondition(
new
EObjectTypeRelationCondition(EXTLibraryPackage.eINSTANCE.get Borrower()),
EXTLibraryPackage.eINSTANCE.getBorrower_Borrowed(),
new EObjectTypeRelationCondition(EXTLibraryPackage.eINSTANCE.get Book()),
EXTLibraryPackage.eINSTANCE.getBook_Author(),
new
EObjectAttributeValueCondition(EXTLibraryPackage.eINSTANCE.g etWriter_Name(),
new StringValue(name)))
SELECT statement = new SELECT(
new FROM(chosenOne.eResource().getContents()),
new WHERE(condition));
//chosenOne.eResource().getContents() ---> This is the list of all the
objects
--------------------:This worked fine:---------------
Now, I need to do this.
"To select the list of writers of the books a particular borrower has
borrowed"
Borrower myBorrower = (Borrower)value; //assume I get the borrower object
here
Basically from borrowers I can get the list of books he/she has borrowed.
Getting the writer name of these books will give me the required data.
I want to run the select statement, without passing the entire library
content but only by passing the borrower object.
new FROM(myborrower),
Please help me with what should the condition be, to get the desired list
of writers ?
Thanks and Regards,
-Amol.
| Re: efficient emf query [message #417963 is a reply to message #417952] |
Mon, 31 March 2008 12:12   |
Amol,
Christian is not around and I'm not familiar with this stuff. I'd just
get the borrower's list of books and collect the authors of each such
book into a set and be done with it...
Amol wrote:
> new
> new
> EXTLibraryPackage.eINSTANCE.getBook_Author(), new
> new FROM(chosenOne.eResource().getContents()), new
> WHERE(condition));
> objects
> borrowed"
> object here
> borrowed. Getting the writer name of these books will give me the
> required data.
> new FROM(myborrower), new WHERE(condition));
> list of writers ?
> Thanks and Regards,
> -Amol.
| Re: efficient emf query [message #417998 is a reply to message #417952] |
Tue, 01 April 2008 11:28  |
Hi, Amol,
As Ed indicates in his replies, this isn't actually a case where the
complexity of the query structure appears to bring much value, as a
Borrower directly references its borrowed books, and these reference their
authors.
Note that the EMF Query API doesn't have an analog of SQL's
column-projection capability. Thus, you cannot write a query that will
project the authors of books related to your borrower.
Initializing a FROM clause with your borrower will result in a SELECT
statement that can only return that borrower and/or the objects that it
contains. There is, currently, no provision for queries to crawl the
cross-reference graph, but only the content tree. You might see how far
you can get in implementing this yourself, though, using a custom FROM
clause implementation.
HTH,
Christian
Amol wrote:
> new
> new
> objects
> borrowed"
> here
> of writers ?
> Thanks and Regards,
> -Amol.
Current Time: Wed Nov 05 14:10:15 EST 2025
Powered by FUDForum. Page generated in 0.04468 seconds
