Home » Modeling » EMF » initializing EMap
initializing EMap [message #417239] Mon, 03 March 2008 08:51 Go to next message
Originally posted by: karin.schellner.lixto.com
I need to specify an EMap in my ecore model and did already find several
articles on this, one (I think from Ed) is giving the following
instructions:
>To define an EDataType for EMap, you'd need to use "Sample Ecore
> Editor->Show Generics" to enable the editor of Generics. You'd create
> the EDataType, set the instance class name to
> org.eclipse.emf.common.util.EMap and you'd use "Create Child->EType
> Parameter" to create type parameters "K" and "V". Then where you
> reference this data type (as the return type of an operation for
> example), you could expand to show the generic type and right click on
> it to invoke "Create Child->EGeneric Type Parameter" and then you could
> use the properties view to make the type parameter's classifier
> reference "B".
(http://www.eclipsepowered.com/eclipse/forums/t92052.html)
I think I did everything right following this example - I could generate the
model and use the getter and setter.
I am just having problems getting the map stored persistently, as I am most
probably using the wrong class for construction:
private EMap<String,Integer> statusMap = new BasicEMap<String,Integer>();
the example often cited is the one used in EAnnotation:
details = new EcoreEMap<String,
String>(EcorePackage.Literals.ESTRING_TO_STRING_MAP_ENTRY,
EStringToStringMapEntryImpl.class, this, EcorePackage.EANNOTATION__DETAILS)
here the EcoreEMap is used, but I am pretty unsure about how to use this
constructor (also I have a String-Integer-Map not a String-String-Map) ...
Can anyone help in this matter?
Thanks very much,
karin.
Re: initializing EMap [message #417240 is a reply to message #417239] Mon, 03 March 2008 09:01 Go to previous messageGo to next message
--------------040606010706050306090806
Karin,
Comments below.
Karin Schellner wrote:
> instructions:
>> reference "B".
That advice was specifically for defining an EDataType for an EMap so
you could reference it in an EOperation, for example.
The instructions in the FAQ are what you need:
http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_ Map_in_EMF.3F
It's important that you end up defining an EClass with
instanceTypeName="java.util.Map$Entry" as well as two features, one
named key and one named value. You'll EMap feature will then be a a
containment EReference of that EClass type.
> Thanks very much,
> karin.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Karin,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:fqgvo7$cli$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
instructions:
</pre>
<blockquote type="cite">
<pre wrap="">To define an EDataType for EMap, you'd need to use "Sample Ecore
Editor-&gt;Show Generics" to enable the editor of Generics. You'd create
org.eclipse.emf.common.util.EMap and you'd use "Create Child-&gt;EType
it to invoke "Create Child-&gt;EGeneric Type Parameter" and then you could
reference "B".
</pre>
</blockquote>
<pre wrap=""><!---->(<a class="moz-txt-link-freetext" href="http://www.eclipsepowered.com/eclipse/forums/t92052.html">http://www.eclipsepowered.com/eclipse/forums/t92052.html</a>)
</pre>
</blockquote>
you could reference it in an EOperation, for example. <br>
<pre wrap="">
private EMap&lt;String,Integer&gt; statusMap = new BasicEMap&lt;String,Integer&gt;();
details = new EcoreEMap&lt;String,
String&gt;(EcorePackage.Literals.ESTRING_TO_STRING_MAP_E NTRY,
</pre>
</blockquote>
The instructions in the FAQ are what you need: <a
href=" http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_ Map_in_EMF.3F"> http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_ Map_in_EMF.3F</a><br>
<br>
named key and one named value.&nbsp; You'll EMap feature will then be a a
containment EReference of that EClass type.<br>
<pre wrap="">
Thanks very much,
karin.
</pre>
</blockquote>
<br>
</body>
</html>
--------------040606010706050306090806--
Re: initializing EMap [message #417355 is a reply to message #417240] Thu, 06 March 2008 04:14 Go to previous message
------=_NextPart_000_0013_01C87F72.E3E7AEB0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks Ed, it worked fine with these instructions!
The instructions in the FAQ are what you need: =
http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_ Map_in_EMF.3F=
It's important that you end up defining an EClass with =
instanceTypeName=3D"java.util.Map$Entry" as well as two features, one =
named key and one named value. You'll EMap feature will then be a a =
containment EReference of that EClass type. =20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3268" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks Ed, it worked fine with these=20
instructions!</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>The instructions in the FAQ are what you need: <A=20
href=3D" http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_ Map_i=
n_EMF.3F"> http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_create_a_ Map=
_in_EMF.3F</A><BR><BR>It's=20
important that you end up defining an EClass with=20
named key=20
and one named value.&nbsp; You'll EMap feature will then be a a =
containment=20
EReference of that EClass type.&nbsp; =
<BR></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0013_01C87F72.E3E7AEB0--
Previous Topic:Constrain which values an attribute is allowed to get
Next Topic:Customizing property values
Current Time: Sat Jul 19 02:47:12 EDT 2025
Powered by FUDForum. Page generated in 0.03138 seconds
