Home » Modeling » EMF » EObjectEList isUnique and EReferences that are not unique
EObjectEList isUnique and EReferences that are not unique [message #417010] Fri, 22 February 2008 12:29 Go to next message
I see from https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325
that its a known "problem" that EMF does not generate code for EReferences
which are NOT unique which deal with the non uniqueness.
I can't see people modeling non unique references very often, but they
could still hand me models which have this set, though no one has. Do you
have any intention, beyond the workaround, to do any work in this area?
Don't do it because I asked because I can't think of any real examples
that do it...
Re: EObjectEList isUnique and EReferences that are not unique [message #417016 is a reply to message #417010] Fri, 22 February 2008 14:07 Go to previous messageGo to next message
JF,
We always have good intentions, and in a sense fixing this would be
trivial. But the downstream implications are a little overwhelming. So
much code assumes that an object will occur at most once in the list.
It does seem to be extremely rare. The last time someone wanted this,
they needed to define like a "signature", i.e., a list of types. But in
the end they ended up with a parameter list and the problem went way.
It would take many weeks of careful investigation to track down the
implications of the change, so it won't happen this release for sure.
> EReferences which are NOT unique which deal with the non uniqueness.
> you have any intention, beyond the workaround, to do any work in this
> area? Don't do it because I asked because I can't think of any real
> examples that do it...
> Thanks
Re: EObjectEList isUnique and EReferences that are not unique [message #417081 is a reply to message #417016] Tue, 26 February 2008 06:57 Go to previous message
Thanks for taking the time to reply Ed.
If I ever come up with a useful example I'll let you know
Previous Topic:Is there any way to do custom proxy resolution?
Next Topic:Use of ProgressMonitorJobsDialog with job scheduling
Current Time: Fri Sep 19 11:02:50 EDT 2025
Powered by FUDForum. Page generated in 0.03490 seconds
