Home » Modeling » EMF » How to access EList template type at runtime
How to access EList template type at runtime [message #417052] Mon, 25 February 2008 06:42 Go to next message
Originally posted by: john.obyrne.gmail.com
I would like at runtime to be able to do
if (element instanceof EList<MyTemplate>)
// Do something
else if (element instanceof EList<MyOtherTemplate>)
// Do something else
I know it's not possible to know at runtime the template type (even using
reflection) in java. In the previous code generated engine we used, we had a
method on our Collection which was:
T getManagedType() {
return T.class;
which allowed us to know the Template type at runtime.
Is there a possibility in EMF to get the template type at runtime? (using
EMF self describing capability maybe)
John
Re: How to access EList template type at runtime [message #417055 is a reply to message #417052] Mon, 25 February 2008 07:10 Go to previous messageGo to next message
John,
The lists returned by multi-valued references always implements
EStructuralFeature.Setting which provides access to the
EStructuralFeature managed by that list, which in turn provides access
to the feature's eType, i.e., the EClassifier. For a generated model,
that EClassifier's instance class would be what you're after.
John O'Byrne wrote:
> // Do something
> return T.class;
> John
Re: How to access EList template type at runtime [message #417063 is a reply to message #417055] Mon, 25 February 2008 12:25 Go to previous message
Thanks, it works perfectly :)
I use the following code:
public static boolean isCollectionOf(EList<?> list, Class<?> type) {
if (list instanceof Setting) {
Setting setting = (Setting) list;
if
(type.isAssignableFrom(setting.getEStructuralFeature().getEG enericType().getEClassifier().getInstanceClass()))
return true;
return false;
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fpub8h$l56$1@build.eclipse.org...
> John,
> EStructuralFeature.Setting which provides access to the EStructuralFeature
> managed by that list, which in turn provides access to the feature's
> eType, i.e., the EClassifier. For a generated model, that EClassifier's
> John O'Byrne wrote:
>> Hi,
>> // Do something
>> had a method on our Collection which was:
>> return T.class;
>> Thanks,
>> John
Previous Topic:Using Model Listeners / Adapters in AbstractPropertySections
Next Topic:Proper way to reflectively add/remove value from multi-valued feature?
Current Time: Sat Jul 19 00:16:42 EDT 2025
Powered by FUDForum. Page generated in 0.02859 seconds
