Home » Modeling » EMF » Smarter ItemProviderAdapter.hasChildren() implementation
Smarter ItemProviderAdapter.hasChildren() implementation [message #415539] Thu, 20 December 2007 06:00 Go to next message
I've realized that the current (2.4M4) implementation of the
ItemProviderAdapter.hasChildren() method is simple but not very
efficient. Especially in cases where the underlying object knows the
sizes of all containment features but needs do expensive network
requests to fill the collections with proper values. Currently I inject
an own ItemProviderAdapter base class into the hierarchy of the
generated item providers which avoids to access the children themselves:
public class CDOItemProviderAdapter extends ItemProviderAdapter
public CDOItemProviderAdapter(AdapterFactory adapterFactory)
super(adapterFactory);
@SuppressWarnings("deprecation")
public boolean hasChildren(Object object)
Collection<? extends EStructuralFeature> anyChildrenFeatures =
getChildrenFeatures(object);
if (anyChildrenFeatures.isEmpty())
anyChildrenFeatures = getChildrenReferences(object);
EObject eObject = (EObject)object;
for (EStructuralFeature feature : anyChildrenFeatures)
if (feature.isMany())
List<?> children = (List<?>)eObject.eGet(feature);
if (!children.isEmpty())
return true;
else
if (eObject.eIsSet(feature))
return true;
return false;
This method seems to work pretty well for me. Do you see any obstacles
with it?
Would it be possible to change the EMF code accordingly?
If so, be aware that the first five lines of my method only replicate
the function of the private getAnyChildrenFeatures() method!
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Re: Smarter ItemProviderAdapter.hasChildren() implementation [message #415545 is a reply to message #415539] Thu, 20 December 2007 08:28 Go to previous messageGo to next message
Eike,
Comments below.
Eike Stepper wrote:
> ItemProviderAdapter.hasChildren() method is simple but not very efficient.
I can imagine that for lazy loading situations asking for the actual
children is less than optimal. The design does ensure that no matter
how folks specialize getChildren, the hasChildren will be correct and
won't require parallel changes.
> Especially in cases where the underlying object knows the sizes of all
> containment features but needs do expensive network requests to fill
> the collections with proper values. Currently I inject an own
> ItemProviderAdapter base class into the hierarchy of the generated
> @Override
> return true;
> else
> return true;
> return false;
> with it?
That seems like a good approach. I could imagine though that the
default value of a feature might be displayed as a child...
Possible, but you could imagine that breaking clients. Perhaps we could
provide the implementation of the method but leave it to clients to
configure something to actually use it. You'd likely still want your
own root class for that...
> Regards,
> Eike Stepper
Re: Smarter ItemProviderAdapter.hasChildren() implementation [message #415555 is a reply to message #415545] Thu, 20 December 2007 10:00 Go to previous messageGo to next message
Ed Merks schrieb:
> Eike,
> Comments below.
> Eike Stepper wrote:
>> Hi,
>> efficient.
I understand this although I'd be happier to have efficient versions and
force (JavaDoc) an overwriter of getChildren() to at least think about
an efficient version of hasChildren() for his getChildren(). But that's
quite subjective.
>> all containment features but needs do expensive network requests to
>> fill the collections with proper values. Currently I inject an own
>> @Override
>> return true;
>> else
>> return true;
>> return false;
>> obstacles with it?
I don't understand the part about the default value. Do you say that the
current implementation doesn't show certain children because they
represent a default value? If it's "only" a default how could it be
changed or removed if it's not visible at the same time?
> could provide the implementation of the method but leave it to clients
> to configure something to actually use it. You'd likely still want
> your own root class for that...
I think having the impl in ItemProviderAdapter would be good, especially
due to the possible reuse of getAnyChildrenFeatures(). Ahh, and I don't
have to maintain it ;-)
I filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=213592
Eike Stepper
Re: Smarter ItemProviderAdapter.hasChildren() implementation [message #415557 is a reply to message #415555] Thu, 20 December 2007 10:07 Go to previous message
--------------010308070500030307070401
Eike,
Comments below.
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
>> Comments below.
>> Eike Stepper wrote:
>>> Hi,
>>> efficient.
> and force (JavaDoc) an overwriter of getChildren() to at least think
> about an efficient version of hasChildren() for his getChildren(). But
> that's quite subjective.
With hindsight that's certainly a reasonable approach too, but generally
I tried to avoid breaking clients with subsequent changes, which
sometimes prevents us from making good changes...
>>> @Override
>>> return true;
>>> else
>>> return true;
>>> return false;
>>> obstacles with it?
> the current implementation doesn't show certain children because they
Note *this *part of the implementation for getting the children, which
doesn't use eIsSet as a guard:
public Collection<?> getChildren(Object object)
ChildrenStore store = getChildrenStore(object);
if (store != null)
return store.getChildren();
store = createChildrenStore(object);
List<Object> result = store != null ? null : new
ArrayList<Object>();
for (EStructuralFeature feature : getAnyChildrenFeatures(object))
int index = 0;
for (Object unwrappedChild : children)
Object child = wrap(eObject, feature, unwrappedChild, index);
if (store != null)
store.getList(feature).add(child);
else
result.add(child);
index++;
else
* Object child = eObject.eGet(feature);
if (child != null)*
child = wrap(eObject, feature, child,
CommandParameter.NO_INDEX);
if (store != null)
store.setValue(feature, child);
else
result.add(child);
return store != null ? store.getChildren() : result;
>> clients to configure something to actually use it. You'd likely
>> still want your own root class for that...
> especially due to the possible reuse of getAnyChildrenFeatures(). Ahh,
> and I don't have to maintain it ;-)
Yep, I think that makes it easier for clients.
> Regards,
> Eike Stepper
<html>
<head>
http-equiv="Content-Type">
</head>
Eike,<br>
<br>
Comments below.<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid:fke02j$37n$2@build.eclipse.org" type="cite">Ed
Merks schrieb:
<br>
<blockquote type="cite">Eike,
<br>
<br>
Comments below.
<br>
<br>
<br>
Eike Stepper wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
efficient.
<br>
</blockquote>
Previous Topic:DanglingHREFException at save after replacing two EClasses
Next Topic:Problem in Loading of Dynamic EMF model using EMF resource Load
Current Time: Sat Jul 19 01:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.04636 seconds
