Where are the constraints??? [message #41359] |
Fri, 19 October 2007 04:23  |
Originally posted by: marco.pantel.unibw.de
Hello everybody!
I tried the OCL library example with ocl 1.1 but I can't find any
OCL-constraint in the ecore-file. Where do they reside? :)
M. Pantel
Re: Where are the constraints??? [message #41492 is a reply to message #41451] |
Sun, 21 October 2007 12:08   |
Originally posted by: steffen.mazanek.unibw.de
Christian,
thanks a lot for this clarification!
Bye,
Steffen
Christian W. Damus schrieb:
> Hi, Steffen,
> This is not the only way to add constraints to an EMF model, and it doesn't
> purport to be "the" way to do this.
> Another option is to define constraints externally to your model using the
> Validation Framework component of EMF. Have a look at the
> org.eclipse.emf.validation.examples.ocl plug-in for examples of:
> - defining OCL constraints right in your plugin.xml using the static
> constraint provider
> - incorporating OCL constraints defined in *.ocl files into the
> validation framework using a dynamic constraint provider
> To answer your original question: the OCL constraints as implemented in the
> article are all specified using EAnnotations, annotating EClasses,
> EStructuralFeatures, and EOperations. There is no EConstraint element in
> Ecore.
> HTH,
> Christian
> Steffen Mazanek wrote:
>> Christian, please correct me If I am wrong.
>> To add constraints to an EMF metamodel presently one has to
>> follow the steps in this tutorial:
> http://www.eclipse.org/articles/article.php?file=Article-EMF -Codegen-with-OCL/index.html
>> Basically one has to add the OCL constraints as EAnnotations
>> and include particular additional templates for code generation.
>> Thereafter these constraints are automatically checked when a
>> particular instance model is validated.
>> Or is there an easier way to include OCL checking in the
>> model validation process?
> -----8<-----
Re: Where are the constraints??? [message #41535 is a reply to message #41506] |
Mon, 22 October 2007 11:00  |
Hi, Marco,
I'm assuming, then, that you have one or more of the following example
plug-ins:
- org.eclipse.emf.validation.examples.general
- org.eclipse.emf.validation.examples.ocl
These examples both use the EMF Validation Framework's
org.eclipse.emf.validation.constraintProviders extension point to
contribute constraints *externally* to the Ecore model. You will find the
constraint definitions in the plugin.xml files of the above-named plug-ins.
The second example (validation.examples.ocl) also has an OCL constraint
provider that parses constraints defined in the *.ocl file.
HTH,
Christian
Marco Pantel wrote:
> Hi Christian,
> I ran the org.eclipse.emf.examples.library v2.3.0 in my runtime
> workbench. The workbench complained successfully when I tried to violate
> one of the contraints. But what I wanted to know is, where the
> contraints of that example are defined.
> Now that you mentioned that EMF does not support defining the
> constraints in ecores, where else can I find the example's
> OCL-definitions?
> Regards,
> Marco
>> Hi, Marco,
>> What do you mean by the OCL library example? What is the plug-in ID?
>> None of the SDK examples in the EMF Validation or MDT OCL components have
>> constraints in Ecore files. EMF doesn't (yet) support the definition of
>> OCL constraints in Ecore models. See
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=191689 for details.
>> Cheers,
>> Christian
>> Marco Pantel wrote:
>>> Hello everybody!
>>> Regards,
>>> M. Pantel
FUDForum. Page generated in 0.04054 seconds
