Serializing/Deserializing subtypes [message #414832] |
Fri, 23 November 2007 11:16  |
Originally posted by: petarsams.yahoo.com
Hello all,
I have this ECORE metamodel:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="porodica"
nsURI="http:///porodica.ecore" nsPrefix="por">
<eClassifiers xsi:type="ecore:EClass" name="Family">
<eStructuralFeatures xsi:type="ecore:EReference" name="members"
ordered="false"
lowerBound="1" upperBound="-1" eType="#//Member" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="dad"
eType="#//Father"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="mom"
eType="#//Mother"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="sons" upperBound="-1"
eType="#//Son"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="daughters"
upperBound="-1"
eType="#//Daughter"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Mother"
eSuperTypes="#//Member"/>
<eClassifiers xsi:type="ecore:EClass" name="Father"
<eClassifiers xsi:type="ecore:EClass" name="Son" eSuperTypes="#//Member"/>
<eClassifiers xsi:type="ecore:EClass" name="Daughter"
<eClassifiers xsi:type="ecore:EClass" name="Member">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
I have this instance of above model:
<por:Family xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:por="http:///porodica.ecore">
<por:members xsi:type="por:Father" name="N1"/>
<por:members xsi:type="por:Mother" name="N2"/>
<por:members xsi:type="por:Daughter" name="N3"/>
<por:members xsi:type="por:Son" name="N4"/>
<por:members xsi:type="por:Daughter" name="N5"/>
<por:members xsi:type="por:Son" name="N6"/>
</por:Family>
What should I do in the code of deserializer in order to be able to load
next instance without reporting "Feature Father not found ...."
<por:Father name="N1"/>
<por:Mother name="N2"/>
<por:Daughter name="N3"/>
<por:Son name="N4"/>
<por:Daughter name="N5"/>
<por:Son name="N6"/>
</por:Family>
I must note that I am getting XMI file as is and that I am not able to
change the layout of elements in Family XMI. I also don't have control of
serialization
process.
Thanx for your attention.
Re: Serializing/Deserializing subtypes [message #414840 is a reply to message #414839] |
Fri, 23 November 2007 16:23   |
--------------000102000102050901040103
Petar,
Given an XSD that describes the XML serialization, you can convert it to
an Ecore model as illustrated in this tutorial.
Tutorial: Generating an EMF Model using XML Schema
< http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html>
You can use annotations on your Ecore model to direct how serialization
and deserialization is done. This document describes the annotations.
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
If you had a schema that corresponds to the actual serialization you
will be receiving that might be the best starting point.
This article might be useful too:
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
PetarSams wrote:
> Hi Ed,
> I am dealing with complex problem using XMLVM to create XML representation
> of
> Java byte code and .net assembly language and then using QVT operational
> mapping on them. XMLVM
> gives me XML files which i cannot change.
> The XML file, for which you told that it is not good, comes from my head.
> I am using it to simplify problem explanation.
> I don't know about XML schemas and i think i can not use them. I use
> smartQVT, and it can only work with ecore and xmi formats.
> Can i use annotations in Ecore files or something else to tell
> deserializer/serializer to that <por:Father is subtype of <por:Member? I
> mean if
> <por:members is EReference on type EClass Member, and EClass Father is
> subtype of EClass Member, it should be possible to cast this somewhere
> wthout error.
> This is the part of the code that smartQVT uses to load files
> this.resource.unload();
> this.resource.load(Collections.EMPTY_MAP);
> Iterator iter = this.resource.getAllContents();
> while (iter.hasNext()) {
> EObject element = (EObject) iter.next();
> extent.add(element);
> Maybe i can change something here?
> I read that some of them use something like MetaData to tell serializer how
> to organize layout of the elements.
> I would like to learn what i actually need to solve my problem. If you can
> just point to me what i need to learn it would be great.
> Thanx a lot
> "PetarSams" <petarsams@yahoo.com> wrote in message
> news:fi6ud4$ga0$1@build.eclipse.org...
>> Hello all,
>> <?xml version="1.0" encoding="UTF-8"?>
>> ordered="false"
>> eType="#//Father"/>
>> eType="#//Mother"/>
>> upperBound="-1" eType="#//Son"/>
>> upperBound="-1"
>> </eClassifiers>
>> lowerBound="1" eType="ecore:EDataType
>> </eClassifiers>
>> </ecore:EPackage>
>> </por:Family>
>> </por:Family>
>> serialization
>> process.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Petar,<br>
<br>
to an Ecore model as illustrated in this tutorial.<br>
<blockquote><a
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
</blockquote>
and deserialization is done. This document describes the annotations.<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a><br>
</blockquote>
will be receiving that might be the best starting point.<br>
<br>
This article might be useful too:<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
<br>
</blockquote>
PetarSams wrote:
<blockquote cite="mid:fi7dd8$khq$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
of
mean if
wthout error.
Thanx a lot
"PetarSams" <a class="moz-txt-link-rfc2396E" href="mailto:petarsams@yahoo.com"><petarsams@yahoo.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fi6ud4$ga0$1@build.eclipse.org">news:fi6ud4$ga0$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hello all,
xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xmlns:ecore=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a> name="porodica"
nsURI=<a class="moz-txt-link-rfc2396E" href="http:///porodica.ecore">"http:///porodica.ecore"</a> nsPrefix="por">
ordered="false"
eType="#//Father"/>
eType="#//Mother"/>
upperBound="-1"
</eClassifiers>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore#//EString">http://www.eclipse.org/emf/2002/Ecore#//EString</a>"/>
</eClassifiers>
</ecore:EPackage>
<por:Family xmi:version="2.0" xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:por=<a class="moz-txt-link-rfc2396E" href="http:///porodica.ecore">"http:///porodica.ecore"</a>>
</por:Family>
</por:Family>
serialization
process.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000102000102050901040103--
Re: Serializing/Deserializing subtypes [message #414852 is a reply to message #414839] |
Mon, 26 November 2007 08:15  |
Originally posted by: udaykabe.hotmail.com
Petar,
XSLT might be an option to do the job. Take a look at the sample XSLT
stylesheet that I have attached. You could use something like it to
transform your XMLVM documents to ecore files.
The attached stylesheet will copy all nodes from the input to the output
while transforming the por:Father, por:Mother, por:Son and por:Daughter
elements into por:members elements.
Uday
news:fi7dd8$khq$1@build.eclipse.org...
> Hi Ed,
> of
> mean if
> wthout error.
> how
> Thanx a lot
>> Hello all,
>> ordered="false"
>> eType="#//Father"/>
>> eType="#//Mother"/>
>> upperBound="-1"
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> </por:Family>
>> </por:Family>
>> serialization
>> process.
Attachment: sample.xsl
(Size: 1.44KB, Downloaded 245 times)
FUDForum. Page generated in 0.04124 seconds
