Home » Modeling » EMF » Using variables in JET
Using variables in JET [message #414700] Fri, 16 November 2007 21:19 Go to next message
Hi All,
Can I use java/Jet variables in Jet templates.
Ex:
<c:setVariable select="somevalue" var="varaibaleName"/>
Here "somevalue" is not an XML XPATH expression. I want to assign
"somevalue" value to "varaibaleName" varibale name.
Just like java,
String varaibaleName = "somevalue";
How can I achieve in JET templates?
Thanks in advance.
Re: Using variables in JET [message #414703 is a reply to message #414700] Sat, 17 November 2007 07:23 Go to previous messageGo to next message
Thiru,
It's best to ask about JET on the M2T newsgroup. I've added it to the
"to" list of the reply, so you don't need to repost.
Thiru wrote:
> Hi All,
> Ex:
> Just like java,
> Thanks in advance.
Re: Using variables in JET [message #414720 is a reply to message #414703] Mon, 19 November 2007 21:42 Go to previous messageGo to next message
Originally posted by: richphs.hotmail.com
Please help me.
The variable has been declared on the Jet templates and it has been
returned NodeSet Type in the java scriptlet.
I don't know how to process the nodeSet type variable which comes from the
Jet variable in Jet templates
How can I code on the java scriptlet?
<control:setVariable var="screenDefOfScreenList"
select=" $function//Event/ReferenceInformation/RelatedScreen/ScreenDe fOfScreenList "
if(context.hasVariable("screenDefOfScreenList"))
NodeSet screenList =
(NodeSet)context.getVariable("screenDefOfScreenList");
// I don't know how to do below.....
EObjectInspector eObjectInspector = new EObjectInspector();
for (Iterator i = screenList.iterator(); i.hasNext();) {
Object object = i.next();
//eObject = (EObject)object;
Object[] screenDefAttributes = eObjectInspector.getChildren(object);
for (int j = 0; j < screenDefAttributes.length; j++){
//screenDefElement =
(ScreenDef)eObjectInspector.getParent(screenDefAttributes[j] );
<%= eObjectInspector.nameOf(screenDefAttributes[j]) %>
Re: Using variables in JET [message #414734 is a reply to message #414720] Tue, 20 November 2007 08:22 Go to previous message
Park:
The best thing to do would be to NOT try to process the NodeSet in Java
unless you really have to. Looking at your code fragment, you could do this
with JET tags:
<%-- iterate over screen lists --%>
<c:iterate
var="listMember">
<%-- write some attribute of listMember to the output --%>
<c:get select="$listMember/@someAttribute name"/>
<%-- really tricky. See what attributes $listMember has --%>
<c:iterate select="$listMember/@*" var="listMemberAttr">
<c:get select="local-name($listMemberAttr")"/> = <c:get
select="$listMemberAttr"/>
</c:iterate>
</c:iterate>
Tell me more about what you want to do. I am happy to help.
Paul
"park" <richphs@hotmail.com> wrote in message
news:1e56344c38877de23b44ea3feffcc5eb$1@www.eclipse.org...
> Please help me.
Previous Topic:EMF load resource behavior when the resource is a Database via Teneo
Next Topic:Zip/Jar archive schemes not acknowledged by UriConverter?
Current Time: Wed Jul 16 07:32:58 EDT 2025
Powered by FUDForum. Page generated in 0.28992 seconds
