Home » Modeling » EMF » EMF load resource behavior when the resource is a Database via Teneo
EMF load resource behavior when the resource is a Database via Teneo [message #414642] |
Thu, 15 November 2007 18:05  |
Hi All,
I'm posting this here because I needed to make some EMF tweaks in order
to make my project work the Teneo.
The problem seems to be that EMF treats a Resource as something that can
be completely loaded into memory. With my 57 million record table that
plan fails in a spectacular way.
I've built a patch that fixes this behavior by adding a method called
setSuppressFullResourceLoading(boolean).
Then I've got code like this in a few places:
public EObject getEObject(URI uri, boolean loadOnDemand)
//--- JJH
// if you trim the fragment and try to load this URL
// you are going to download the entire database table!
// getResource(uri.trimFragment(), loadOnDemand);
Resource resource =null;
//--- JJH
if(EcoreUtil.getSuppressFullResourceLoading()){
resource = getResource(uri, loadOnDemand);
else{
resource = getResource(uri.trimFragment(), loadOnDemand);
//--- JJH
if (resource != null)
//--- JJH
if(resource.getContents().size()==1){
return resource.getContents().get(0);
//--- JJH
return resource.getEObject(uri.fragment());
else
return null;
I need this on the 2.3 code since that is what our project is based on
and the company is standardizing on RAD 7 (basically Eclipse 3.2.2)
If you agree that this is an OK way around this problem, can I use the
..psf you posted recently to build a patch against the 2.3 branch?
Jason Henriksen
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414650 is a reply to message #414642] |
Thu, 15 November 2007 18:47   |
--------------090006030203070002050108
Jason,
Comments below.
jason henriksen wrote:
> Hi All,
> order to make my project work the Teneo.
> can be completely loaded into memory. With my 57 million record table
> that plan fails in a spectacular way.
Ouch.
That sounds like a Teneo thing...
> //--- JJH
> //--- JJH
> else{
> //--- JJH
> //--- JJH
> //--- JJH
> else
> return null;
I don't recognize EcoreUtil.getSuppressFullResourceLoading() is that
org.eclipse.emf.ecore.util.EcoreUtil or some other one? I assume you
are using ID's because if you are using fragment paths, it would
normally just walk down the branch that's used for that path. You
didn't say, but I assume this in ResourceSetImpl. Normally that looks
like this:
Resource resource = getResource(uri.trimFragment(), loadOnDemand);
else
return null;
I imagine you could just provide your override in your own derived
ResourceSetImpl without changing the base implementation that everyone
uses. I can't say I really understand what getting a the resource with
the fragment still attached would accomplish. Is this more a question
for Teneo that Martin would normally answer on the EMFT newgroup?
> Jason Henriksen
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Jason,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:fhijbi$9c7$1@build.eclipse.org" type="cite">Hi
All,
<br>
<br>
<br>
<br>
<br>
</blockquote>
Ouch.<br>
<blockquote cite="mid:fhijbi$9c7$1@build.eclipse.org" type="cite"><br>
<br>
</blockquote>
That sounds like a Teneo thing...<br>
<br>
<br>
<br>
<br>
<br>
//--- JJH
<br>
<br>
<br>
<br>
<br>
<br>
<br>
//--- JJH
<br>
<br>
<br>
<br>
else{
<br>
<br>
<br>
//--- JJH
<br>
<br>
<br>
<br>
//--- JJH
<br>
<br>
<br>
<br>
//--- JJH
<br>
<br>
<br>
else
<br>
<br>
return null;
<br>
<br>
<br>
<br>
<br>
...psf you posted recently to build a patch against the 2.3 branch?
<br>
</blockquote>
like this:<br>
<small><br>
</small>
<blockquote><small> public EObject getEObject(URI uri, boolean
loadOnDemand)</small><br>
<small> {</small><br>
<small> Resource resource = getResource(uri.trimFragment(),
loadOnDemand);</small><br>
<small> if (resource != null)</small><br>
<small> return resource.getEObject(uri.fragment());</small><br>
<small> }</small><br>
<small> else</small><br>
<small> return null;</small><br>
</blockquote>
for Teneo that Martin would normally answer on the EMFT newgroup?<br>
<br>
<br>
<br>
Jason Henriksen
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------090006030203070002050108--
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414652 is a reply to message #414650] |
Thu, 15 November 2007 19:19   |
Hi Ed,
> org.eclipse.emf.ecore.util.EcoreUtil?
Yes, I've got my own patched version that I use for my project that adds
this method.
However, running my own patched version of things is not a fun and makes
my client a little nervous. I'd rather be running directly on your
releases and not have to manage my own special sauce if I can reasonably
avoid it.
> I assume you
The url's end up looking something like this:
hibernate://Consumer/12345 (pseudo code)
Teneo has protocol handlers that get the URL above and build a SQL query
out of it. I'm not fully clear on all the teneo aspects of this but
what I found from looking at the database is that if you clear the
fragment the query gets turned from
"Select * from Consumer where id=12345" // return 1 or 0 records.
into
"Select * from Consumer" // return 57 million records.
Or to put my own comments into the source:
//--- Load the entire resource (i.e. the whole table)
if (resource != null){
//--- Out of the resource, get the item I asked for.
// (But never get here because I ran out of memory last line)
else{
return null;
> uses.
In fact, that is what I'm doing now. But Teneo can't really be used
against very large databases if EMF behaves this way, which is a bummer.
I can publish this as something for people to download and use as a
patch, but setting a flag to control the behavior in ECoreUtil seemed
like the better plan. If you don't ask for the load suppression,
everything acts as it does today. But if you run into the problem, you
can just set the flag and be happy.
I hope that makes sense. If I'm mis-understanding the behavior of that
code, I'd love to be brought up to speed.
Jason
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414674 is a reply to message #414652] |
Fri, 16 November 2007 06:37   |
Jason,
Comments below.
> Hi Ed,
> adds this method.
That explains it.
> makes my client a little nervous. I'd rather be running directly on
> your releases and not have to manage my own special sauce if I can
> reasonably avoid it.
Yep, it would make me nervous. I'm not sure why you can't just
specialize your own derived ResourceSetImpl.
>> I assume you are using ID's because if you are using fragment paths,
>> it would normally just walk down the branch that's used for that path.
> query out of it. I'm not fully clear on all the teneo aspects of this
> but what I found from looking at the database is that if you clear the
> into
That would be quite a few!
I guess because the objects are all a huge list in resource.getContents().
And Java only lets you have about 1.5G max for the heap. It's not very
scalable. :-P
> else{
> return null;
>> everyone uses.
It's not the size of the database I suppose, but rather the height of
the tables in it. Does Hibernate address these kinds of issues?
> you can just set the flag and be happy.
I would imagine that most applications have complete control over what
resource set is used, so I'm still not sure why providing an alternative
resource set implementation wouldn't suffice.
>> I can't say I really understand what getting a the resource with the
> that code, I'd love to be brought up to speed.
It does, but it also seems to me that JPA/JDO/Hibernate would all suffer
from these same fundamental problems so I'm curious how they deal with
it. Do they somehow produce a query that returns a much smaller set of
the objects you're actually likely to use? I'll add the EMFT newsgroup
to the reply so Martin is more likely to see this and comment.
> Jason
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414694 is a reply to message #414674] |
Fri, 16 November 2007 09:17   |
Hi Jason,
I think I am confused....
Can you describe what how the system gets from the url:
hibernate://Consumer/12345 to the query and also for this one:
hibernate://Consumer to the query?
As far as I know the urifragment should be something like this:
Consumer|id=12345
gr. Martin
Ed Merks wrote:
> Jason,
> Comments below.
>> Hi Ed,
>> adds this method.
> That explains it.
>> into
> scalable. :-P
>> else{
>> return null;
>>> everyone uses.
>> Thanks,
>> Jason
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414715 is a reply to message #414694] |
Mon, 19 November 2007 17:24   |
Hi Guys,
I'm slowly going back through my notes and figuring out why I did some
of this stuff. (I've been heads down for months and so I'm finally
coming up for air and post-mortems)
So the uri fragmen Martin gave was like this:
Consumer|id=12345
or in generic terms:
<object-type>|<primary-key-column>=<primary-key-id>
The problem with this is that my tables are legacy and do not have a
consistent primary key column. Also, my client did not allow me to make
the primary key column visible in the URI in case they decide to change
the name of that column later. (Changing that column strikes me as a
singularly bad but they're paying the bill so what they say goes)
The URI Style they wanted is
hibernate://#<object-type>.<primary-key-id>
This is enough information because I runtime I can inspect the object
type and determine which column is the primary-key-column
To do this I ended up making a couple of changes. Specifically I made a
URIMapper that would create a URI for a given Database object and when I
came across a URI of that type I could turn it back into a query.
Here's my code:
public URI getURIFor(EObject input)
HbDataStore dataStore = HbHelper.INSTANCE.getDataStore(
this.defaultDataStoreName );
//--- get the type name for the URI
String typeName = dataStore.getEntityNameStrategy().
toEntityName(input.eClass());
//--- figure out the field and value for the id
PersistentClass pc = dataStore.getPersistentClass( typeName );
Property p = pc.getIdentifierProperty();
String value = p.getGetter(input.getClass()).get(input).toString();
//--- return the abbreviated URI
URI result = URI.createURI("hibernate://#"+typeName+"."+value);
return result;
//--- Map my abbreviated URI into a more standard API for Teneo
public URI mapURI(URI input) {
HbHelper.INSTANCE.getDataStore(defaultDataStoreName );
String frag = input.fragment();
if(frag!=null){
String[] parts = frag.split("\\.");
if(parts.length==3){
return input;
if(parts.length==2){
PersistentClass pc = dataStore.getPersistentClass(parts[0]);
Column c = (Column)p.getPersistentClass().
getIdentifier().getColumnIterator().next();
// important use this for rehydrating the query SQL
String name = c.getCanonicalName();
URI result = input.trimFragment().
appendFragment(parts[0]+"."+name+"."+parts[1]);
return result;
else{
return input;
return input;
Does that make any sense? I then use the methods when I serialize and
de-serialize the objects so that the URI's look right. The problem for
me seemed to be that the URIs ran afoul of the trimFragment() code.
If you guys have a better solution to how I could get this kind of
effect without running into the fragment URI problem I'd love to hear
your thoughts. In the mean time I'm going to try building a separate
ResourceSetImpl as Ed suggested and see if I can get this to work more
cleanly that way.
The client wants to move away from these abbreviated URLs into REST
urls, but we need to stay in the 2.3 EMF branch. This code will get
re-implemented and I'd like to solve the problem cleanly and in a way
that minimizes me hack around with you guys' code.
Thanks for any thoughts,
Jason
PS: My client is successfully using EMF and Teneo to manage their large
consumer database and are very happy with the results and performance.
They're happy enough to expand this technique to other projects and
start slowly deploying it enterprise wide. The company Directors are
mentioning EMF and Teneo in very positive tones. Thanks guys!
Martin Taal wrote:
> Hi Jason,
> Consumer|id=12345
> gr. Martin
> Ed Merks wrote:
>> Jason,
>> Comments below.
>>> Hi Ed,
>>> adds this method.
>> That explains it.
>>> this but what I found from looking at the database is that if you
>>> clear the fragment the query gets turned from
>>> into
>> very scalable. :-P
>>> else{
>>> return null;
>>>> everyone uses.
>> alternative resource set implementation wouldn't suffice.
>> suffer from these same fundamental problems so I'm curious how they
>> deal with it. Do they somehow produce a query that returns a much
>> smaller set of the objects you're actually likely to use? I'll add
>> the EMFT newsgroup to the reply so Martin is more likely to see this
>> and comment.
>>> Thanks,
>>> Jason
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414718 is a reply to message #414715] |
Mon, 19 November 2007 19:12   |
Jason,
Commetns below.
> Hi Guys,
> Consumer|id=12345
> make the primary key column visible in the URI in case they decide to
> change the name of that column later. (Changing that column strikes
> me as a singularly bad but they're paying the bill so what they say goes)
You can specialize a resource's getURIFragment and getEObject methods to
produce an consume any form of fragment you desire. I suppose there
might be limitation placed by the fact it's in a data base though...
> a URIMapper that would create a URI for a given Database object and
> when I came across a URI of that type I could turn it back into a query.
I would expect changes localized to the above to methods in a derived
ResourceImpl. URIMappings are for redirecting the non-fragment part of
the URIs.
> Here's my code:
> return result;
> if(frag!=null){
> return input;
> return result;
> else{
> return input;
> return input;
> for me seemed to be that the URIs ran afoul of the trimFragment() code.
I think if you'd done it in the resource you'd have run into less problems.
> cleanly that way.
> Jason
> large consumer database and are very happy with the results and
> performance. They're happy enough to expand this technique to other
> projects and start slowly deploying it enterprise wide. The company
> Directors are mentioning EMF and Teneo in very positive tones. Thanks
> guys!
Hopefully by specializing the resource set's fragmentless-URI lookup and
the resource's fragment lookup you can get a solution that fits better
and still has the same characteristics that you seek.
> Martin Taal wrote:
>> Hi Jason,
>> Consumer|id=12345
>> gr. Martin
>> Ed Merks wrote:
>>> Jason,
>>> Comments below.
>>>> Hi Ed,
>>>>> that org.eclipse.emf.ecore.util.EcoreUtil?
>>>> adds this method.
>>> That explains it.
>>>> on your releases and not have to manage my own special sauce if I
>>>> can reasonably avoid it.
>>>>> paths, it would normally just walk down the branch that's used for
>>>>> that path.
>>>> into
>>> very scalable. :-P
>>>> else{
>>>> return null;
>>>>> derived ResourceSetImpl without changing the base implementation
>>>>> that everyone uses.
>>>> used against very large databases if EMF behaves this way, which is
>>>> a bummer.
>>> of the tables in it. Does Hibernate address these kinds of issues?
>>>> seemed like the better plan. If you don't ask for the load
>>>> suppression, everything acts as it does today. But if you run into
>>>> the problem, you can just set the flag and be happy.
>>> what resource set is used, so I'm still not sure why providing an
>>>>> question for Teneo that Martin would normally answer on the EMFT
>>>>> newgroup?
>>> and comment.
>>>> Thanks,
>>>> Jason
Re: EMF load resource behavior when the resource is a Database via Teneo [message #414722 is a reply to message #414718] |
Tue, 20 November 2007 04:10  |
Hi Jason,
As Ed suggests I would override the HibernateResource and the getEObjectById/getURIFragment methods.
This seems also easier to me.
gr. Martin
Ed Merks wrote:
> Jason,
> Commetns below.
>> Hi Guys,
>> Consumer|id=12345
> the URIs.
>> Here's my code:
>> return result;
>> if(frag!=null){
>> return input;
>> return result;
>> else{
>> return input;
>> return input;
>> cleanly that way.
>> Jason
>> guys!
>> Martin Taal wrote:
>>> Hi Jason,
>>> Consumer|id=12345
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Jason,
>>>> Comments below.
>>>>> Hi Ed,
>>>>> adds this method.
>>>> That explains it.
>>>>>> that path.
>>>>> into
>>>> very scalable. :-P
>>>>> else{
>>>>> return null;
>>>>>> that everyone uses.
>>>>> a bummer.
>>>>>> newgroup?
>>>> and comment.
>>>>> Thanks,
>>>>> Jason
The Netherlands
Current Time: Fri Jul 18 15:48:08 EDT 2025
Powered by FUDForum. Page generated in 0.30039 seconds
