Home » Modeling » EMF » XML (Structured) Text editor synchronized with EMF view
XML (Structured) Text editor synchronized with EMF view [message #414478] |
Thu, 08 November 2007 10:38  |
Originally posted by: mcostes.hotmail.com
Hi to all,
First excuse my bad English ;-)
I'm using Eclipse 3.2 with EMF 2.2 and I'm developing an XML editor plugin.
From XSD schema, I have generated the Ecore model and from genmodel the
model code, edit code and editor code.
The createPages() method of editor class creates a page for the EMF tree
viewer (named viewerPane).
I've added to the editor a StructuredTextEditor by adding this snippet
code in createPages() method of editor class:
try {
StructuredTextEditor xmlSource = new StructuredTextEditor();
int index = addPage(xmlSource, getEditorInput());
setPageText(index, xmlSource.getTitle());
} catch (PartInitException pie) {}
I would like the XML Source to be synchronized with the EMF tree.
Actually when a modification occurs on EMF tree, XML view is also
updated with this modification ... but on the contrary a modification on
XML source doesn't occur on EMF tree.
Is there a simple way for implement this?
I've heard about SSE, EMF2DOM adapters ... but I've not found any sample
or snippet code for doing that.
Thanks a lot for your help
Marie
Re: XML (Structured) Text editor synchronized with EMF view [message #414485 is a reply to message #414478] |
Thu, 08 November 2007 12:44   |
Marie,
Comments below.
Marie C wrote:
> Hi to all,
As long as you'll excuse my exclusive use of English.
> plugin.
> the model code, edit code and editor code.
> tree viewer (named viewerPane).
> try {
> on XML source doesn't occur on EMF tree.
> sample or snippet code for doing that.
It's a pretty tricky problem that I wish we had a good reusable solution
for already. All I can suggest that would be fairly easy would be kind
of brute force solutions. Using XMLResource.save(Document document,
Map<?, ?> options, DOMHandler handler) with a handler you could convert
a model to a SSE DOM maintaining a mapping from the EObject to the DOM.
When the model changes, you could repeat that process. If the DOM
changes, you could unload the EMF resource and use void load(Node
node, Map<?, ?> options). It's very crude but that's the best I can
suggest. I imagine one could do some very nice fine grained integration
to support an EMF2DOM adapter automatically given the extended metadata
annotations on the model, but I can't point you at any source code for
that. It would make a great EMFT component...
> Marie
Re: XML (Structured) Text editor synchronized with EMF view [message #414539 is a reply to message #414485] |
Mon, 12 November 2007 06:13   |
Thanks a lot Ed for your answer.
I understand your explanation.
However, how modify the editing domain resource ?
For example, with the following code, resource is never modified.
// xmlSource is StructuredTextEditor
IDocument doc =
xmlSource.getDocumentProvider().getDocument(getEditorInput() );
XMLResource initialResource =
(XMLResource)editingDomain.getResourceSet().getResources().g et(0);
initialResource.load(new ByteArrayInputStream(doc.get().getBytes()), null);
// display the content of the resource in sysout
initialResource.save(System.out, Collections.EMPTY_MAP);
Thanks for your help
Marie
Ed Merks a écrit :
> Marie,
> Comments below.
> Marie C wrote:
>> Hi to all,
>> plugin.
>> try { StructuredTextEditor xmlSource = new
>> StructuredTextEditor(); int index = addPage(xmlSource,
>> getEditorInput());
>> Marie
Re: XML (Structured) Text editor synchronized with EMF view [message #414540 is a reply to message #414539] |
Mon, 12 November 2007 07:17   |
--------------060401070503040402090408
Marie,
I suggested using this load method to load directly from the DOM that is
supported by SSE:
* Loads the resource from the DOM node, either an Element or
Document, using the specified options.
* <p>
* This method assumes that no namespace fixup needs to be done.
* To process comments and CDATA section nodes, please set
XMLResource.OPTION_USE_LEXICAL_HANDLER option to Boolean.TRUE.
* </p>
* @param node DOM Element or Document node.
* @param options the load options.
* @see #save(Document, Map, DOMHandler)
* @since 2.1.0
void load(Node node, Map<?, ?> options) throws IOException;
You can look at the source code for the XSD model's sample XSDEditor to
see a very crude way in which we sync up the source and the resource.
You can see that whenever a command is executed on the model,
handleStructuredModelChange is called to update the document with the
new serialized version. You'd want to use to serialize directly to the
SSE DOM.
* Create a DOM tree representing contents of this resource.
* @param document an empty {@link org.w3c.dom.Document} to use or
null. If no document is specified, the
* new {@link org.w3c.dom.Document} will be created using JAXP API.
* @param options the "save" options
* @param handler the {@link org.eclipse.emf.ecore.xmi.DOMHandler}
to record mappings or null.
* If no DOMHandler is passed, the default DOMHandler will be created.
* @return the {@link org.w3c.dom.Document}. In the case the
document is specified as a parameter,
* the returned document is the same as the one specified,
otherwise the newly created document is returned.
* @since 2.1.0
Document save(Document document, Map<?, ?> options, DOMHandler
handler);
In createSourcePage you'll see we hook up a listener to the document so
when it changes, handleDocumentChange is called to update the document.
In your case, you'd call the above load method again.
> IDocument doc =
> null);
> Marie
> Ed Merks a
Re: XML (Structured) Text editor synchronized with EMF view [message #414712 is a reply to message #414540] |
Mon, 19 November 2007 08:10   |
Many thanks Ed !!
It works for me.
protected void handleStructuredModelChange() {
try {
// get resource
XMLResource resource =
// save it in DOM
Document xmlDom = resource.save(null, Collections.EMPTY_MAP, null);
// load it
resource.load(xmlDom, Collections.EMPTY_MAP);
} catch (Exception e) {}
protected void handleDocumentChange() {
try {
IDocument document =
xmlEditor.getDocumentProvider().getDocument(xmlEditor.getEdi torInput());
// get resource
XMLResource xmlResource =
// unload resource
if (xmlResource.isLoaded()) {
xmlResource.unload();
// construct new DOM
DocumentBuilderFactory factory = DocumentBuilderFactory.newInstance();
DocumentBuilder builder = factory.newDocumentBuilder();
Document newDom = builder.parse(new InputSource(new
StringReader(document.get())));
// load resource
xmlResource.load(newDom, Collections.EMPTY_MAP);
Marie
Ed Merks a écrit :
> Marie,
> supported by SSE:
> * <p>
> * </p>
> * @since 2.1.0
> SSE DOM.
> * @since 2.1.0
> handler);
>> IDocument doc =
>> null);
>> Marie
>> Ed Merks a écrit :
>>> Marie,
>>> Comments below.
>>> Marie C wrote:
>>>> Hi to all,
>>>> plugin.
>>>> snippet code in createPages() method of editor class:
>>>> getEditorInput());
>>>> modification on XML source doesn't occur on EMF tree.
>>> solution for already. All I can suggest that would be fairly easy
>>> would be kind of brute force solutions. Using
>>> XMLResource.save(Document document, Map<?, ?> options, DOMHandler
>>> handler) with a handler you could convert a model to a SSE DOM
>>> maintaining a mapping from the EObject to the DOM. When the model
>>> changes, you could repeat that process. If the DOM changes, you
>>> could unload the EMF resource and use void load(Node node, Map<?,
>>> ?> options). It's very crude but that's the best I can suggest. I
>>> imagine one could do some very nice fine grained integration to
>>> for that. It would make a great EMFT component...
>>>> Marie
Re: XML (Structured) Text editor synchronized with EMF view [message #414826 is a reply to message #414713] |
Fri, 23 November 2007 06:07   |
Thanks Ed for your suggestion.
However, I’ve another problem in the doSave() method when I’m trying to
unload resource. A SWTException (Invalid thread access) occurs.
This is my snippet code :
for (Iterator i =
editingDomain.getResourceSet().getResources().iterator(); i.hasNext(); ) {
XMLResource resource = (XMLResource)i.next();
if ((first || !resource.getContents().isEmpty() ||
isPersisted(resource)) && !editingDomain.isReadOnly(resource)) {
try {
// unload resource
if (resource.isLoaded()) {
resource.unload();
savedResources.add(resource);
resource.load(new InputSource(new
StringReader(getXmlDocument().get())), Collections.EMPTY_MAP);
resource.save(Collections.EMPTY_MAP);
catch (Exception exception) {
resourceToDiagnosticMap.put(resource,
analyzeResourceProblems(resource, exception));
first = false;
Is it normal ?
Marie
Ed Merks a écrit :
> Marie,
> If you has a String rather than a DOM to start with, this would perform
> significantly better:
> resource.load(new InputSource(new StringReader(document.get())),
> Marie C wrote:
>> Many thanks Ed !!
>> It works for me.
>> try {
>> // get resource
>> // save it in DOM
>> // load it
>> try {
>> // get resource
>> // unload resource
>> // load resource
>> Marie
>> Ed Merks a écrit :
>>> Marie,
>>> is supported by SSE:
>>> * <p>
>>> * </p>
>>> * @since 2.1.0
>>> to see a very crude way in which we sync up the source and the
>>> resource. You can see that whenever a command is executed on the
>>> model, handleStructuredModelChange is called to update the document
>>> with the new serialized version. You'd want to use to serialize
>>> directly to the SSE DOM.
>>> API.
>>> created.
>>> * @since 2.1.0
>>> handler);
>>> so when it changes, handleDocumentChange is called to update the
>>> document. In your case, you'd call the above load method again.
>>>> IDocument doc =
>>>> null);
>>>> Marie
>>>> Ed Merks a écrit :
>>>>> Marie,
>>>>> Comments below.
>>>>> Marie C wrote:
>>>>>> Hi to all,
>>>>>> editor plugin.
>>>>>> genmodel the model code, edit code and editor code.
>>>>>> EMF tree viewer (named viewerPane).
>>>>>> getEditorInput());
>>>>> metadata annotations on the model, but I can't point you at any
>>>>> source code for that. It would make a great EMFT component...
>>>>>> Marie
Re: XML (Structured) Text editor synchronized with EMF view [message #414827 is a reply to message #414826] |
Fri, 23 November 2007 07:12   |
Marie,
I don't see anything directly in this code that accesses SWT widgets.
But you do need to keep in mind that you can only access widgets on the
GUI thread. This type of approach can be used to ensure that something
being processed on a background thread that needs to access the SWT does
it using the proper thread:
getSite().getShell().getDisplay().asyncExec
(new Runnable()
public void run()
// Do something on the GUI thread.
> to unload resource. A SWTException (Invalid thread access) occurs.
> for (Iterator i =
> try {
> // unload resource
> resource.unload();
> first = false;
> Is it normal ?
> Marie
> Ed Merks a écrit :
>> Marie,
>> perform significantly better:
>> Marie C wrote:
>>> Many thanks Ed !!
>>> It works for me.
>>> try { // get resource
>>> // save it in DOM
>>> // load it
>>> try {
>>> // get resource
>>> // unload resource
>>> // load resource
>>> Marie
>>> Ed Merks a écrit :
>>>> Marie,
>>>> that is supported by SSE:
>>>> * <p>
>>>> * </p>
>>>> * @since 2.1.0
>>>> XSDEditor to see a very crude way in which we sync up the source
>>>> and the resource. You can see that whenever a command is executed
>>>> on the model, handleStructuredModelChange is called to update the
>>>> document with the new serialized version. You'd want to use to
>>>> serialize directly to the SSE DOM.
>>>> use or
>>>> JAXP API.
>>>> created.
>>>> * @since 2.1.0
>>>> handler);
>>>> document so when it changes, handleDocumentChange is called to
>>>> update the document. In your case, you'd call the above load
>>>> method again.
>>>>> IDocument doc =
>>>>> Marie
>>>>> Ed Merks a écrit :
>>>>>> Marie,
>>>>>> Comments below.
>>>>>> Marie C wrote:
>>>>>>> Hi to all,
>>>>>>> editor plugin.
>>>>>>> getEditorInput());
>>>>>>> tree. Actually when a modification occurs on EMF tree, XML view
>>>>>>> is also updated with this modification ... but on the contrary a
>>>>>>> any sample or snippet code for doing that.
>>>>>> easy would be kind of brute force solutions. Using
>>>>>> load(Node node, Map<?, ?> options). It's very crude but that's
>>>>>> the best I can suggest. I imagine one could do some very nice
>>>>>> fine grained integration to support an EMF2DOM adapter
>>>>>> automatically given the extended metadata annotations on the
>>>>>> model, but I can't point you at any source code for that. It
>>>>>>> Marie
Re: XML (Structured) Text editor synchronized with EMF view [message #968703 is a reply to message #414485] |
Fri, 02 November 2012 13:30   |
Sorry to hijack this thread, but...
I've been working on just such a thing. A few classes, a little ExtendedMetaData magic and a generic solution that bridges the gap between EMF and SSE. Is such a thing still needed? Is EMF2DOM still the way to go when it comes to adding source pages to editors working on EMF models?
It's still a work in progress and needs to be cleaned up, but the beginnings can be found here: https://github.com/rcernich/tools/tree/text_editing/eclipse/plugins/org.switchyard.tools.ui.editor/src/org/switchyard/tools/ui/editor/dom
Best,
Rob
Re: XML (Structured) Text editor synchronized with EMF view [message #969348 is a reply to message #968703] |
Sat, 03 November 2012 02:03  |
Rob,
Certainly if anyone wishes to have a source view of their serialized
model, I can't think of a better approach than using SSE, with its
specialized XML support, as the basis for such a source view. Could you
please open an EMF bugzilla enhancement request with links and an
explicit statement of your intent to donate the code under EPL and a
statement about the origin of the code, i.e., who hold the copyrights to
all the code. Of course including license and copyright information in
each source file (as we do for all Eclipse source) is the best way to
track that...
> on EMF models?
> Best,
> Rob
Current Time: Tue Jul 22 21:24:07 EDT 2025
Powered by FUDForum. Page generated in 0.06252 seconds
