Home » Modeling » EMF » Problem with Generics, inheritance and ecore validation
Problem with Generics, inheritance and ecore validation [message #414497] |
Fri, 09 November 2007 09:25  |
Hello @ all !
I'm experiencing a trouble with EMF (ecore) validation about generics,
inheritance and upper bound. I think it's a lack (or bug ?) of the EMF
validator, but I'm not sure... Ready for the challenge ? Go ! :)
I'm making a simple application based on RCP/GEF/EMF that will be used to
make plannings. I made a simple model *framework* - that currently works -
with these classes (in EMF style) :
[] Planning<task extends Task, pp extends People<task>> -> Class
=>() task extends Task -> Generics : Type Parameter
() Task
=>() res extends People<task> -> Generics : Type Parameter
() People<task>
(<>) task
-> listPeople : pp -> Reference
(:) pp
[] People<task extends Task> -> Class
() Task
-> listTasks : task -> Reference
(:) task
[] Task -> Class
-> people : People<? extends Task> -> Reference
(:) People<? extends Task>
(<>) ? extends Task
*Here is the problem* : I try to extend the framework by providing
specialized classes :
[] MySpecificTask -> Class
(|) Task -> Generic super type
[] MySpecificPeople<MySpecificTask> -> Class
(|) People<MySpecificTask> -> Generic super type
(<>) MySpecificTask
[] Program<MySpecificTask, MySpecificPeople> -> Class
(|) Planning<MySpecificTask, MySpecificPeople> -> Generic super type
(<>) MySpecificTask
(<>) MySpecificPeople
My error is when I try to validate this ecore model, I get a "problem
encountered during validation" : *The generic type 'MySpecificPeople' is
not a valid substitution for type parameter 'pp extends People<Task>'*,
error thrown on the "Program" declaration in the ecore. However, this
declaration should be correct, as I created it "from scratch" correctly (I
mean with no compile error). *Is there a way to make it valid from the
validator point of view ?*
I found a workaround (which is to add a type parameter to the
MySpecificPeople class), but I think this solution is quite ugly and less
easy to use... :(
So, please, can anyone (ideally an EMF team member ?) tell me if this is
an EMF validator bug, or if a way exists to make my dream come true ?
Thanks at all people that read this post until the end, and I promise a
candy to all people that answers me *with the solution* :)
Benett
Re: Problem with Generics, inheritance and ecore validation [message #414498 is a reply to message #414497] |
Fri, 09 November 2007 09:39   |
Benett,
I'd have a much easier time if you could attach the Ecore model itself
or if you could send it to me at merks at ca dot ibm dot com.
Benett wrote:
> Hello @ all !
> to make plannings. I made a simple model *framework* - that currently
> works - with these classes (in EMF style) :
> () Task
> () People<task>
> (<>) task
> (:) pp
> () Task
> (:) task
> [] Task -> Class
> (<>) ? extends Task
> (<>) MySpecificTask
> (<>) MySpecificTask
> is not a valid substitution for type parameter 'pp extends
> People<Task>'*, error thrown on the "Program" declaration in the
> ecore. However, this declaration should be correct, as I created it
> "from scratch" correctly (I mean with no compile error). *Is there a
> way to make it valid from the validator point of view ?*
> less easy to use... :(
> is an EMF validator bug, or if a way exists to make my dream come true ?
> a candy to all people that answers me *with the solution* :)
> Benett
Re: Problem with Generics, inheritance and ecore validation [message #414523 is a reply to message #414509] |
Sat, 10 November 2007 09:55   |
Benett,
The code that is supposed to validate whether A<X> is bound for B<Y>,
which is the case if B extends A and X == Y, was confused because you
actually had C extends B<Y>, and in that case it should be checking that
the Y from B<Y> is equal to X and was instead upset that C had not
argument at all. I have a patch I'll commit for EMF 2.3.2 and 2.4 once
waiting for you to open a bugzilla...
Ed Merks wrote:
> Benett,
> It appears to be a bug, so I'll need to do some digging in the complex
> code that enforces the constraints for this...
> Benett wrote:
>> Hello,
>> thanks for your quick reply ! In response to your post, I sent you a
>> mail containing the "problematic" ecore (in both ecore and zip
>> format). Did you receive it ?
>> You can either post a response in my mailbox or in the newsgroup. In
>> the first case, I will post (if relevant) the answer to the newsgroup
>> to make the community aware of our work...
Re: Problem with Generics, inheritance and ecore validation [message #414528 is a reply to message #414523] |
Sat, 10 November 2007 17:42  |
Ed,
Thank you for having solved the problem before I added a new entry in
bugzilla :)
The bugzilla added is the number 209420.
Thanks once again for having spent time on this problem !
Benett
Ed Merks wrote:
> Benett,
> Ed Merks wrote:
>> Benett,
>> Benett wrote:
>>> Hello,
Current Time: Thu Jul 17 20:10:03 EDT 2025
Powered by FUDForum. Page generated in 2.44501 seconds
