Home » Modeling » EMF » Persist command stack: PersistentCommandStack / AdapterFactoryMappingDomain
Persist command stack: PersistentCommandStack / AdapterFactoryMappingDomain [message #414467] Thu, 08 November 2007 07:05 Go to next message
Originally posted by: tobiasbuhr.gmx.de
Hi group,
when searching for a way to persist the (Basic)CommandStack, I found the
class org.eclipse.emf.mapping.command.PersistentCommandStack in the
org.eclipse.emf.mapping plugin.
Unfortunately, I neither find any documentiation nor a sample for it's
usage.
Can somebody help me out?
Furthermore I think, for it's invokation one needs to use the
AdapterFactoryMappingDomain instead of the common
AdapterFactoryEditingDomain - but how do I provide the neccessary
mappingDomainAdapterFactory for it's creation?
Thanks for your time,
Tobias
Re: Persist command stack: PersistentCommandStack / AdapterFactoryMappingDomain [message #414470 is a reply to message #414467] Thu, 08 November 2007 07:47 Go to previous messageGo to next message
Tobias,
Yes, this was specialized for use with the mapping framework were folks
wanted to use the actions they took as a script to be applied to another
instance.
The basic idea is that the AdapterFactoryEditingDomain specializes
createCommand so that it can record in the command stack the mapping
from the created command to the command parameter that created it.
Thus, when the command is actually executed, the data for how it was
created is available and can be recorded. You could reuse that type of
design.
A different and perhaps better alternative is to use a ChangeRecorder to
build a ChangeDescription which is a model object you can serialize like
any other EMF model object. There's even a ChangeCommand that uses a
ChangeRecord to allow arbitrary model changes to be applied (i.e.,
changes that don't use commands and don't know about them), and still
have the action be undoable.
Tobias Buhr wrote:
> Hi group,
> usage.
> Tobias
Re: Persist command stack: PersistentCommandStack / AdapterFactoryMappingDomain [message #414473 is a reply to message #414470] Thu, 08 November 2007 09:30 Go to previous messageGo to next message
Thanks for your reply, Ed!
Hmm, org.eclipse.emf.ecore.change looks good. Although I did not try it
out, I am not sure, if it would be the best solution for me (at least
out-of-the-box).
The point is, that I have a model, in which many many elements are
implicit (->recalculated after editing in the non-implicit part, not
user editable, but not volatile for performance reasons).
Thus, I suppose, the change recorder would be messed up pretty much.
Perhaps, I could customize it with some kind of filter - what do you think?
Best regards, Tobias
Re: Persist command stack: PersistentCommandStack / AdapterFactoryMappingDomain [message #414476 is a reply to message #414473] Thu, 08 November 2007 09:52 Go to previous messageGo to next message
--------------050305070201090308000004
Tobias,
Features that are computed from the values of other features should be
marked as isDerived true. The change recorder won't record changes to
derived features with the assumption that changes to the non-derived
features will be sufficient. I'm not sure if in your case undoing only
the changes to the non-derived (non-computed) features will result in
the derived ones being recomputed to the correct undone state as well...
> out-of-the-box).
<html>
<head>
http-equiv="Content-Type">
</head>
Tobias,<br>
<br>
Re: Persist command stack: PersistentCommandStack / AdapterFactoryMappingDomain [message #414481 is a reply to message #414476] Thu, 08 November 2007 12:30 Go to previous message
Thanks again Ed, you paved me the way!
That is great - exactly what I need.
Well, that's a drawback, I have to trigger the calculation of the
derived features after I perform a FeatureChange.apply(AndReverse). But
I can live with it.
Guten Abend (GMT+1), Tobias
Previous Topic:ChangeRecorder - ?
Next Topic:Re: Ecore2proprietaryModel which M2T language to use?
Current Time: Fri Jul 18 23:06:09 EDT 2025
Powered by FUDForum. Page generated in 0.04206 seconds
