Model api generation generates an ecore model again ? [message #414429] |
Tue, 06 November 2007 10:39  |
I have got a weird behavior when generating the model API for one of my
EMF models (this model was originally created from annotated java code and
is copied in another project where the generation is really done, I don't
know if it is relevant).
Indeed, I got a new ecore model among my model element implementation
classes named "model.ecore". Weird isn't it ?
I tried to debug the model generation, and I found that the ecore file is
created by GenPackageGeneratorAdapter#generatePackageSerialization method.
In this method, the local variable targetPathName (at line 249) is set to
my implementation java package and the file is serialized on disk at line
338.
Does anyone have an idea of what it is happening there ?
Stephane.
Re: Model api generation generates an ecore model again ? [message #414430 is a reply to message #414429] |
Tue, 06 November 2007 10:57   |
Hi, Stephane,
It looks like your EPackage implementation is generated to initialize its
metadata from the .ecore file. Hence, this file is deployed into the Java
package.
This would be either because your GenModel has the option to "initialize by
loading" enabled, or because the code generator detected that your EPackage
has too many elements to generate the static initialization (owing to the
size of the initialization method being to large for javac to compile).
HTH,
Christian
Stephane wrote:
> 338.
> Stephane.
Re: Model api generation generates an ecore model again ? [message #414431 is a reply to message #414430] |
Tue, 06 November 2007 11:52  |
Hi, Christian,
You're quite right !
My GenModel has the option "initialize by loading" enabled and the
EPackage has many elements.
Stephane.
Christian W. Damus wrote:
> Hi, Stephane,
> package.
> HTH,
> Christian
> Stephane wrote:
>> Hi,
>> 338.
>> Stephane.
FUDForum. Page generated in 0.40199 seconds
