Home » Archived » XML Schema Definition (XSD) » traversing hierarchy of particles
traversing hierarchy of particles [message #41379] Wed, 14 April 2004 09:04 Go to next message
Originally posted by: hoe.zurich.ibm.com
Is there a way to obtain the "transitive closure" around XSDParticles
that extend/restrict each other? What I have in mind is asking e.g. a
group particle for all its sub-particles (local and "inherited" ones)
all at once.
Christian
Re: traversing hierarchy of particles [message #41410 is a reply to message #41379] Wed, 14 April 2004 11:09 Go to previous messageGo to next message
Christian,
Particles don't extend or restrict each other, so I'm a little confused.
XSDModelGroup.getParticles() will give you all the "sub-particles"
regardless of where they come from. Are you looking for something in
addition to this?
> all at once.
> Christian
Re: traversing hierarchy of particles [message #41439 is a reply to message #41410] Wed, 14 April 2004 12:05 Go to previous messageGo to next message
Sorry for being unclear. I was refering to (complex) types that
extend/restrict each other, and that use those particles indirectly.
> addition to this?
Thx, this may already be enough. What I have in mind is a situation
where a complex type references an XSDModelGroup (via XSDParticle with
XSDContentTypeCategory.ELEMENT_ONLY_LITERAL, say). If the base type also
has its XSDModelGroup, the two XSDCompositor's may be different, as far
as the XSD data structures are concerned: one CHOICE_LITERAL, the other
ALL_LITERAL, I guess. Is this sort of thing detected/resolved, when I
call XSDModelGroup.getParticles() to get a "flat" list including
"sub-particles", or do I have to do sg. special myself (XML Schema Part
1, section 3.9.6 says more on cases that may occur).
Hope it's a bit clearer now & I'll do some more tests locally,
Christian
Re: traversing hierarchy of particles [message #41468 is a reply to message #41439] Wed, 14 April 2004 12:42 Go to previous message
Christian,
The particle structure resolves all the references so that you can walk the
"virtual" particle tree exactly as it is defined in the schema spec. Just make
sure you call the methods that say they represent an "infoset property" rather
than the ones that are "concrete", i.e., XSDModelGroup.getParticles() verses
XSDModelGroup.getContents().
> > addition to this?
> Christian
Re: traversing hierarchy of particles [message #585586 is a reply to message #41379] Wed, 14 April 2004 11:09 Go to previous message
Christian,
addition to this?
> all at once.
> Christian
Re: traversing hierarchy of particles [message #585608 is a reply to message #41410] Wed, 14 April 2004 12:05 Go to previous message
> addition to this?
Christian
Re: traversing hierarchy of particles [message #585627 is a reply to message #41439] Wed, 14 April 2004 12:42 Go to previous message
Christian,
> > addition to this?
> Christian
Previous Topic:traversing hierarchy of particles
Next Topic:Problem with transferring a type definition between two schemas
Current Time: Fri Jul 25 20:32:06 EDT 2025
Powered by FUDForum. Page generated in 0.04623 seconds
