| Iterations [message #40986] |
Mon, 24 September 2007 00:40  |
I'm unsure how to convey "iterative activity." I run across two general
types of iterations in my modeling of development processes.
1. Piecemeal - Whereby each iteration is essentially
the same activity, repeated multiple
times.
2. Evolutionary - Whereby a component is realized in
over multiple iterations, be each
iteration is a different activity.
An piecemeal example is developing a persistence layer. The iterative
steps would be adding support for one query/table for one iteration, and
other queries/tables for other iterations. The activity of adding
support for different queries is very similar from one iteration to the
next.
An evolutionary example would be developing a transport layer. The
first iteration would be simply getting something that excepts a request
and logs it. There might not be any other code to invoke at this point.
But later iterations would add support for interpretations of various
messages and the invocations of downstream components. It's an
iterative process, but the steps are not identical for each iteration.
Does EPF provide a way to model these? I've been developing for a
while, but I'm new to process modeling.
- Paul
| Re: Iterations [message #41679 is a reply to message #41263] |
Sat, 29 September 2007 13:58  |
Thanks, Roman. I think this straightens me out.
Roman Smirak wrote:
> May this help
> http://en.wikipedia.org/wiki/Iterative_and_incremental_devel opment?
> I guess definitions may vary however my understanding was that the iterative
> rather means evolutionary whereas incremental means complete piece of
> functionality at the time.
> Note that there are certain reasons to deliver an increment in the iteration
> but that is probably another topic..
> Hope this helps,
> Roman
| Re: Iterations [message #583430 is a reply to message #40986] |
Mon, 24 September 2007 06:33  |
Isn't this incremental vs. iterative?
Roman
"Paul Glezen" <pglezen@us.ibm.com> wrote in message
news:fd7f3j$at9$1@build.eclipse.org...
> times.
> other queries/tables for other iterations. The activity of adding support
> for different queries is very similar from one iteration to the next.
> An evolutionary example would be developing a transport layer. The first
> iteration would be simply getting something that excepts a request and
> logs it. There might not be any other code to invoke at this point. But
> later iterations would add support for interpretations of various messages
> and the invocations of downstream components. It's an iterative process,
> Does EPF provide a way to model these? I've been developing for a while,
> - Paul
| Re: Iterations [message #583498 is a reply to message #41017] |
Tue, 25 September 2007 23:26  |
Perhaps. Which one is "incremental" and which one is "iterative"?
After reviewing the input fields available, I suspect we simply describe
what we mean in the "Main" section of the iteration panel itself.
> Roman
>> times.
>> over multiple iterations, but each
| Re: Iterations [message #583553 is a reply to message #41171] |
Thu, 27 September 2007 03:06  |
May this help
Hope this helps,
Roman
news:fdcjho$tkb$1@build.eclipse.org...
>> Roman
>>> times.
| Re: Iterations [message #583749 is a reply to message #41263] |
Roman Smirak wrote:
> May this help
> Hope this helps,
> Roman
FUDForum. Page generated in 0.05335 seconds
