Home » Eclipse Projects » Mylyn » gantt view for mylyn tasks!(?)
gantt view for mylyn tasks!(?) [message #39899] Thu, 27 December 2007 18:26 Go to next message
I have just published a very simple plugin that allows the visualization
of mylyn tasks in a gantt view (http://xpmp.de/jaretcalendar.html). It
currently only displays local tasks straight forward (without any
projection of working time). It is possible to drag the tasks for
scheduling or to set the estimated time by sizing. The gantt view
supports some milestone markers to visualize deadlines.
The plugin is not really focussed on mylyn. More general it displays a
regular calendar that will also be shown in the gantt view. It currently
features a simple local calendar and a google calendar integration.
I am currently using mylyn for organizing my tasks locally (private use)
and can not use mylyn in my day-to-day work with the team (which makes
me sad ...).
That said I have two questions which I would like to hear your opinions
and comments on:
a) Does this make any sense for heavy mylyn users? I guess when
repository tasks are supported (which I will check with a test
repository I have to setup ... maybe I'll get that straight in early
2008) one person can do the (micro) scheduling for others.
b) Isn't scheduling on small tasks a bit "too much"?
There are some other, technical issues I came across:
- the events fired on the ITaskListChangeListener are strange (or I
simply don't understand the concept). For supporting multiple task views
it would be great if the tasks itself would be observables.
- updating a task and notifying the tasklist seems to be quite slow
(well, when dragging a task this makes a lot of updates ...)
I would appreciate your comments (and maybe suggestions).
Peter
Re: gantt view for mylyn tasks!(?) [message #39958 is a reply to message #39899] Fri, 28 December 2007 00:25 Go to previous messageGo to next message
Peter,
That is really neat stuff. Though I wonder why you used views instead
of editors? There is a lot stuff to show and editors in Eclipse
workbench generally have more screen real estate available. Also, if
editors would be backed up by a data provider it may make it easier to
share planned tasks with other team members. I.e. using planning tools
such as XPlanner or planning metadata from Bugzilla or JIRA or even
file-based provider that would allow to simply send files around.
As for ITaskListChangeListener API design, is usually better to ask
that in the mylyn-integrators mailing list. See
http://dev.eclipse.org/mailman/listinfo/mylyn-integrators
Anyways, the listener API is actually very simple. The
ITaskListChangeListener.containersChanged(Set<TaskContainerDelta >
containers) method is receiving collection of containers that been
changed. Note that individual tasks are also containers, i.e. they are
subclasses of the AbstractTaskContainer. So you can filter individual
tasks by checking instanceof AbstractTask; categories -
AbstractTaskCategory and queries - AbstractRepositoryQuery. See class
hierarchy (F4) of AbstractTaskContainer for all container types. You can
also look at the other implementors of containersChanged() method
(Ctrl-T or Ctrl-Shift-H to open the Hierarchy view).
I am not sure about task list update slowness, but you can try to
minimize number of notifications/updates and only notify on the drop
event. If that doesn't help it would be a good idea to submit a bug
report with some more details about how you are doing notification.
Maybe even create small code snippet or plugin that would demonstrate issue.
BTW, there is more advanced Gant chart widget for SWT:
http://www.eclipse.org/nebula/widgets/ganttchart/ganttchart. php
There is also example snippet showing a week calendar with tasks:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.neb ula/org.eclipse.swt.nebula.snippets/src/org/eclipse/swt/nebu la/snippets/compositetable/DayEditorSnippet0.java?root=Techn ology_Project&view=co
regards,
Eugene
> visualization of mylyn tasks in a gantt view
> (http://xpmp.de/jaretcalendar.html). It currently only displays local
> tasks straight forward (without any projection of working time). It is
> possible to drag the tasks for scheduling or to set the estimated time
> by sizing. The gantt view supports some milestone markers to visualize
> deadlines.
> currently features a simple local calendar and a google calendar
> integration.
> use) and can not use mylyn in my day-to-day work with the team (which
> makes me sad ...).
> opinions and comments on:
> views it would be great if the tasks itself would be observables.
> Peter
Re: gantt view for mylyn tasks!(?) [message #39990 is a reply to message #39958] Fri, 28 December 2007 06:31 Go to previous messageGo to next message
Hi Eugene,
Well, you are right about the screen real estate. I use views because
the data displayed is collected from several sources and there is no
single element being edited (or that can be passed around). Using a view
you can simply open the view. AFAIK you can not simply open an editor
without an editable element.
Thx. I figured most of that out. I am a bit confused by the single
events and when they are fired. I'll check that and go for the
mailinglist if I don't get it ...
> issue.
You're right. There is no point in updating while dragging.
Well. Since I am the author of the timebars I know the widget. It's
nice. But I won't say it is "more advanced" ...
Never saw that. Just tested -> I don't think that this a good approach
for day editing ...
regards
Peter
> regards,
> Eugene
>> deadlines.
>> integration.
>> makes me sad ...).
>> Peter
Re: gantt view for mylyn tasks!(?) [message #40020 is a reply to message #39990] Fri, 28 December 2007 07:34 Go to previous messageGo to next message
> view you can simply open the view. AFAIK you can not simply open an
> editor without an editable element.
That is not true. You can open editor with IEditorInput that don't
have any resource underneath. Though you'll need your own action to
trigger that.
I wasn't comparing the API, but was referring strictly to the visual
appearance.
regards,
Eugene
Re: gantt view for mylyn tasks!(?) [message #41161 is a reply to message #39899] Fri, 11 January 2008 19:46 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
That's very interesting stuff Peter! I agree that this kind of
functionality is useful, because I use similar functionality form
Tasktop on a regular basis. But the Tasktop is a commercial plug-in and
other users could be interested in trying your free one. To encourage
usage I suggest that you add it to the Mylyn Extensions listing:
http://wiki.eclipse.org/Mylyn_Extensions
If you continue developing this, it could be worthwhile to discuss how
we can improve the API for calendaring tools in Mylyn, and to get your
contributions if you're interested. The best place for such a
discussion would be the mylyn-integrators mailing list or a new bug
report that you could file along the line of "improve API for
calendaring tools".
Mik
Peter Kliem wrote:
> me sad ...).
> and comments on:
> Peter
Re: gantt view for mylyn tasks!(?) [message #41282 is a reply to message #41161] Mon, 14 January 2008 17:40 Go to previous messageGo to next message
Hi Mik,
right, it should be in the wiki (done). I'm a bit short of time due to
my day to day job, but I'll try getting this usable with remote
repositories.
As for the API: I'll think about improvements (and go for the mailing
list). I think a basic question is if the mylyn core should care about
projecting to working time etc. This might be off topic for the core.
Reasoning about observable pattern for tasks (or an improved
TaskListListener) or a more elaborated task interface might be possible
-- but: I think nearly everything is possible with the current interfaces.
Peter
> calendaring tools".
> Cheers,
> Mik
> Peter Kliem wrote:
>> Hi,
>> deadlines.
>> integration.
>> makes me sad ...).
>> Peter
Re: gantt view for mylyn tasks!(?) [message #41762 is a reply to message #41282] Fri, 25 January 2008 11:20 Go to previous message
Originally posted by: gnl.ballroomdancemusic.info
Peter Kliem wrote:
> Hi Mik,
> repositories.
Maybe take a look at the Eclipsetimeline plugin?
> Cheers,
> Peter
>> and other users could be interested in trying your free one. To
>> encourage usage I suggest that you add it to the Mylyn Extensions
>> listing:
>> calendaring tools".
>> Cheers,
>> Mik
>> Peter Kliem wrote:
>>> Hi,
>>> is possible to drag the tasks for scheduling or to set the estimated
>>> time by sizing. The gantt view supports some milestone markers to
>>> a regular calendar that will also be shown in the gantt view. It
>>> integration.
>>> makes me sad ...).
>>> Peter
Re: gantt view for mylyn tasks!(?) [message #586418 is a reply to message #39899] Fri, 28 December 2007 00:25 Go to previous message
Peter,
regards,
Eugene
> deadlines.
> integration.
> makes me sad ...).
> Peter
Re: gantt view for mylyn tasks!(?) [message #586431 is a reply to message #39958] Fri, 28 December 2007 06:31 Go to previous message
Hi Eugene,
> issue.
for day editing ...
regards
Peter
> regards,
> Eugene
>> deadlines.
>> integration.
>> makes me sad ...).
>> Peter
Re: gantt view for mylyn tasks!(?) [message #586440 is a reply to message #39990] Fri, 28 December 2007 07:34 Go to previous message
trigger that.
appearance.
regards,
Eugene
Re: gantt view for mylyn tasks!(?) [message #587009 is a reply to message #39899] Fri, 11 January 2008 19:46 Go to previous message
calendaring tools".
Mik
Peter Kliem wrote:
> me sad ...).
> and comments on:
> Peter
Re: gantt view for mylyn tasks!(?) [message #587048 is a reply to message #41161] Mon, 14 January 2008 17:40 Go to previous message
Hi Mik,
repositories.
Peter
> calendaring tools".
> Cheers,
> Mik
> Peter Kliem wrote:
>> Hi,
>> deadlines.
>> integration.
>> makes me sad ...).
>> Peter
Re: gantt view for mylyn tasks!(?) [message #587193 is a reply to message #41282] Fri, 25 January 2008 11:20 Go to previous message
Peter Kliem wrote:
> Hi Mik,
> repositories.
> Cheers,
> Peter
>> listing:
>> calendaring tools".
>> Cheers,
>> Mik
>> Peter Kliem wrote:
>>> Hi,
>>> integration.
>>> makes me sad ...).
>>> Peter
Previous Topic:Mylyn update to 2.2 Incomplete? - org.eclipse.mylyn_feature (2.2.0)
Next Topic:JIRA improvements
Current Time: Fri Sep 26 22:18:33 EDT 2025
Powered by FUDForum. Page generated in 0.29876 seconds
