Home » Modeling » EMF » TableViewer drag and drop problem
TableViewer drag and drop problem [message #411446] |
Wed, 25 July 2007 21:57  |
My ecore model has an EClass "Item", and it contains a self reference
"subItems" (0..*, containment). now I need to display top level items with
a jface tableviewer, also I want the rows can be dragged so that users can
change their order. I added code as following:
int dndOperations = DND.DROP_COPY | DND.DROP_MOVE | DND.DROP_LINK;
Transfer[] transfers = new Transfer[] { LocalTransfer.getInstance() };
tbv.addDragSupport(dndOperations, transfers, new ViewerDragAdapter(tbv));
tbv.addDropSupport(dndOperations, transfers, new
EditingDomainViewerDropAdapter(editingDomain, tbv));
The problem is when I drop an row onto the other row, the drag source item
disappears because it becomes a sub item of the target item, instead of
moving down under the target item. I can't delete "subItems" reference
because I need it elsewhere.
Any suggestion?
Hao
Re: TableViewer drag and drop problem [message #411450 is a reply to message #411446] |
Thu, 26 July 2007 07:52   |
Hao,
You could customize the"Item" item provider used specifically for the
table viewer to not return the subItems feature when getChildFeature is
called.
Hao Zhang wrote:
> with a jface tableviewer, also I want the rows can be dragged so that
> users can change their order. I added code as following:
> item disappears because it becomes a sub item of the target item,
> instead of moving down under the target item. I can't delete
> "subItems" reference because I need it elsewhere.
> Any suggestion?
> Regards,
> Hao
Re: TableViewer drag and drop problem [message #411495 is a reply to message #411450] |
Thu, 26 July 2007 23:44   |
Ed,
I did so but still the same problem, I debugged and found
"costItemItemProvider = new CostItemItemProvider(this)" is called but its
getChildrenFeatures() method is never called which made me once wonder
whether this is the proper way (I'm quite sure my getChildrenFeatures()
method did override):
class TheItemProviderAdapterFactory extends
ModelerItemProviderAdapterFactory {
public Adapter createCostItemAdapter() {
if (costItemItemProvider == null) {
costItemItemProvider = new CostItemItemProvider(this) {
public Collection<? extends EStructuralFeature>
getChildrenFeatures(Object object) {
return Collections.EMPTY_LIST;
public String getColumnText(Object object, int columnIndex) {
public Object getColumnImage(Object object, int columnIndex) {
return costItemItemProvider;
in above codes, "CostItem" is what I mentioned "Item".
Ed Merks wrote:
> Hao,
> called.
> Hao Zhang wrote:
>> Hi,
>> Any suggestion?
>> Regards,
>> Hao
Re: TableViewer drag and drop problem [message #411509 is a reply to message #411495] |
Fri, 27 July 2007 07:59  |
--------------000302090402030106030507
Hao,
I'm pretty sure that as a result of *this *attempt to create an
AddCommand in the drag and drop command
protected boolean prepareDropMoveOn()
if (isCrossDomain())
dragCommand = IdentityCommand.INSTANCE;
dropCommand = UnexecutableCommand.INSTANCE;
else
dropCommand = *AddCommand*.create(domain, owner, null,
collection);
this method of ItemProviderAdapter is called and that if the
*getChildFeature *method returns a result, the drag and drop command
will try to add to that feature, so try setting a breakpoint in there to
see why the framework is able to create an add command....
protected Command factorAddCommand(EditingDomain domain,
CommandParameter commandParameter)
if (commandParameter.getCollection() == null ||
commandParameter.getCollection().isEmpty())
return UnexecutableCommand.INSTANCE;
final EObject eObject = commandParameter.getEOwner();
final List<Object> list = new
ArrayList<Object>(commandParameter.getCollection());
int index = commandParameter.getIndex();
CompoundCommand addCommand = new
CompoundCommand(CompoundCommand.MERGE_COMMAND_ALL);
while (!list.isEmpty())
Iterator<Object> children = list.listIterator();
final Object firstChild = children.next();
*EStructuralFeature childFeature = getChildFeature(eObject,
firstChild);**
if (childFeature == null)
break;
So try setting a breakpoint to see why it's finding a child feature.
Hao Zhang wrote:
> Ed, I did so but still the same problem, I debugged and found
> its getChildrenFeatures() method is never called which made me once
> wonder whether this is the proper way (I'm quite sure my
> getChildrenFeatures() method did override):
> @Override
> @Override
> @Override
> columnIndex) {
> @Override
> columnIndex) {
> Ed Merks wrote:
>> Hao,
>> the table viewer to not return the subItems feature when
>> getChildFeature is called.
>> Hao Zhang wrote:
>>> Hi,
>>> reference "subItems" (0..*, containment). now I need to display top
>>> level items with a jface tableviewer, also I want the rows can be
>>> dragged so that users can change their order. I added code as
>>> following:
>>> source item disappears because it becomes a sub item of the target
>>> item, instead of moving down under the target item. I can't delete
>>> Any suggestion?
>>> Regards,
>>> Hao
<html>
<head>
http-equiv="Content-Type">
</head>
Hao,<br>
<br>
Current Time: Sun Sep 14 05:47:46 EDT 2025
Powered by FUDForum. Page generated in 0.03283 seconds
