Home » Modeling » M2T (model-to-text transformation) » How to test an element specified in the input xml or not?
How to test an element specified in the input xml or not? [message #40917] Thu, 24 January 2008 05:45 Go to next message
Hi all,
What's the correct way to test whether an element specified in the input
xml or not if the input xml is associated with its own schema (use
xsi:noNamespaceSchemaLocation="test.xsd")? The code "<c:if
test="root/subelement">...</c:if>" seems doesn't work in this case and
throw java.lang.NullPointerException most of the time.
Another question is that, how to tell JET Transformation the path of the
schema? Currently, I have to copy the schema file to the path which holds
the input xml file.
Re: How to test an element specified in the input xml or not? [message #40980 is a reply to message #40917] Thu, 24 January 2008 11:15 Go to previous messageGo to next message
Chaohong:
Please submit a bugzilla for the NullPointerException. Attaching a stack
trace from the Error Log view will be most helpful. Here's the URL to submit
a bug:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org
But, I think there is a solution to your problem without me fixing a bug...
You have:
<c:if test="root/subelement">
</c:if>
Try one of the following:
1) Make your XPath expression absolute: /root/subelement
2) Start your XPath expressino with a known variable: $root/subelement
In either case, the expression should evaluate to 'true' if one or more
subelement instances are found.
Paul
"Chaohong" <hamlinxie@gmail.com> wrote in message
news:80963715da268e4f77c0aee616ebeba9$1@www.eclipse.org...
> Hi all,
> the input xml file.
Re: How to test an element specified in the input xml or not? [message #41105 is a reply to message #40980] Sun, 27 January 2008 11:03 Go to previous messageGo to next message
Hi Paul,
Sorry for this late response. I have been stuck by this problem now. I
tried your suggestions but that don't work for me. I'd like to make sure
whether it is my carelessness somewhere or it is a bug of JET before
submitting the bug.
I have to paste my test project and the stack trace at the end so that you
can understand my problem. Sorry for this long letter in advance.
I noticed that whenever I add "xsi:noNamespaceSchemaLocation="test.xsd""
in the sample.xml, the NullPointerException will reoccur easily. While the
<c:if test /> tag works fine if I remove that text out of the sample.xml.
BR,
Chaohong
stack trace
at
org.eclipse.jet.internal.xpath.ast.Axis$AttributeAxis.evalua te(Axis.java:119)
at org.eclipse.jet.internal.xpath.ast.Step.evalAsNodeSet(Step.j ava:77)
at
org.eclipse.jet.internal.xpath.ast.NodeSetExpr.evalAsObject( NodeSetExpr.java:44)
at
org.eclipse.jet.internal.xpath.XPathExpressionImpl.evaluate( XPathExpressionImpl.java:59)
at
org.eclipse.jet.XPathContextExtender.resolveAsObject(XPathCo ntextExtender.java:444)
at
org.eclipse.jet.XPathContextExtender.resolveAsString(XPathCo ntextExtender.java:141)
at org.eclipse.jet.internal.taglib.control.GetTag.doAction(GetT ag.java:53)
at
org.eclipse.jet.internal.runtime.SafeEmptyRuntimeTag$1.doRun (SafeEmptyRuntimeTag.java:49)
at
org.eclipse.jet.internal.runtime.SafeCustomRuntimeTag$TagSaf eRunnable.run(SafeCustomRuntimeTag.java:72)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at
org.eclipse.jet.internal.runtime.SafeEmptyRuntimeTag.doStart (SafeEmptyRuntimeTag.java:43)
at org.eclipse.jet.compiled._jet_dump1.generate(_jet_dump1.java :78)
at
org.eclipse.jet.transform.TransformContextExtender.execute(T ransformContextExtender.java:146)
at
org.eclipse.jet.transform.TransformContextExtender.execute(T ransformContextExtender.java:119)
at
org.eclipse.jet.internal.taglib.workspace.FileTag.doAction(F ileTag.java:101)
at
at
at
at org.eclipse.jet.compiled._jet_main.generate(_jet_main.java:4 1)
at
at
at org.eclipse.jet.JET2Platform$5.run(JET2Platform.java:458)
at
org.eclipse.jet.internal.runtime.JETBundleManager.run(JETBun dleManager.java:331)
at org.eclipse.jet.JET2Platform.runTransform(JET2Platform.java: 426)
at org.eclipse.jet.internal.launch.JETProcess.run(JETProcess.ja va:156)
at
org.eclipse.jet.internal.launch.JET2TransformationDelegate.l aunch(JET2TransformationDelegate.java:59)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
dump.jet
<?xml version="1.0" encoding="utf-8"?>
<c:if test="/datasource/raw" var="ds1">
Raw ds is <c:get select="$ds1/@uri"/>.
</c:if>
<c:if test="/datasource/aggregated" var="ds2">
<c:if test="$ds2/query" var="query">
Query language is <c:get select="$query/@language"/>.
</c:if>
</c:if>
sample.xml
<datasource name="AggregatedCalendar"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<aggregated>
<query language="mysql">
<![CDATA[
SELECT Calendar.TestEvent AS Event
FROM MyCalendar AS Calendar;
</query>
</aggregated>
</datasource>
test.xsd
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:sdi="http://www.motorola.com/sdi" elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xs:element name="datasource">
<xs:complexType>
<xs:sequence>
<xs:choice>
<xs:element name="raw">
<xs:complexType>
<xs:attribute name="uri" use="required">
</xs:attribute>
<xs:attribute name="type">
</xs:attribute>
</xs:complexType>
</xs:element>
<xs:element name="aggregated">
<xs:complexType>
<xs:sequence>
<xs:element name="query">
<xs:complexType>
<xs:simpleContent>
<xs:extension base="xs:anySimpleType">
<xs:attribute name="language" use="required">
</xs:attribute>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:choice>
</xs:sequence>
<xs:attribute name="name" use="required">
</xs:attribute>
</xs:complexType>
</xs:element>
</xs:schema>
Paul Elder wrote:
> Chaohong:
> a bug:
> You have:
> </c:if>
> Paul
Re: How to test an element specified in the input xml or not? [message #41137 is a reply to message #41105] Sun, 27 January 2008 11:07 Go to previous messageGo to next message
BTW, the main.jet isn't attached for it is just created by JET by default.
Thanks.
BR,
Chaohong
Re: How to test an element specified in the input xml or not? [message #41228 is a reply to message #41137] Thu, 31 January 2008 11:36 Go to previous messageGo to next message
Chaohong:
Can you attach the schema, the test document, and XPath expression that is
failing? I have not been able to reproduce from the information you have
provided.
Paul
news:ccdc0b731c6ae21508b2809a304a336a$1@www.eclipse.org...
> Thanks.
> BR,
> Chaohong
Re: How to test an element specified in the input xml or not? [message #41257 is a reply to message #41228] Thu, 31 January 2008 21:41 Go to previous messageGo to next message
Hi Paul,
For your convenient, here is the attached. Please create an "EMFT JET
Transformation Project", paste the following content into corresponding
files and then run the transformation. The NullPointerException should
catch you there. Or, you can fetch the test project from here
(https://bugs.eclipse.org/bugs/attachment.cgi?id=88492).
I found a bug submitted
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=217057) reporting such an
issue. Could you have a look as well? Thanks a lot.
stack trace
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
dump.jet
</c:if>
</c:if>
</c:if>
sample.xml
<aggregated>
<![CDATA[
</query>
</aggregated>
</datasource>
test.xsd
<xs:complexType>
<xs:sequence>
<xs:choice>
<xs:complexType>
</xs:attribute>
</xs:attribute>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
<xs:complexType>
<xs:simpleContent>
</xs:attribute>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:choice>
</xs:sequence>
</xs:attribute>
</xs:complexType>
</xs:element>
</xs:schema>
B.R.
Chaohong
Paul Elder wrote:
> Chaohong:
> provided.
> Paul
Re: How to test an element specified in the input xml or not? [message #41288 is a reply to message #41257] Tue, 05 February 2008 14:08 Go to previous messageGo to next message
Thanks fro the information.
FYI. I have committed a change that at least resolves the NPE.
Bug, the underlying problem is you have the following code:
</c:if>
The fix corrects a problem where /datasource/raw was evaluating to 'true',
and setting $ds1 to null, thus causing the follow-on problem in c:get (which
has also been fixed).
The fix will be included in this weeks maintenance build.
Paul
news:9a9e3e691d2bddeea0176df04115e32d$1@www.eclipse.org...
> Hi Paul,
> stack trace
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> dump.jet
> </c:if>
> </c:if>
> </c:if>
> sample.xml
> <aggregated>
> <![CDATA[
> </query>
> </aggregated>
> </datasource>
> test.xsd
> <xs:complexType>
> <xs:sequence>
> <xs:choice>
> <xs:complexType>
> </xs:attribute>
> </xs:attribute>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> <xs:complexType>
> <xs:simpleContent>
> </xs:attribute>
> </xs:extension>
> </xs:simpleContent>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:choice>
> </xs:sequence>
> </xs:attribute>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> B.R.
> Chaohong
> Paul Elder wrote:
>> Chaohong:
>> is failing? I have not been able to reproduce from the information you
>> have provided.
>> Paul
Re: How to test an element specified in the input xml or not? [message #42010 is a reply to message #41288] Mon, 18 February 2008 07:34 Go to previous message
Hi Paul,
Thanks so much for your efforts and sorry for the late response for I just
came back from our new year vacation.
I tried the new version and it does fix the NullPointerException. But I
find that the content between "<![CDATA[" and "]]>" can not be shown by
<c:dump/> if we specified the "xsi:noNamespaceSchemaLocation" attribute.
Do you have any idea for that?
I'll do further test later and keep you posted later.
B.R.
Chaohong
> </c:if>
> Paul
Previous Topic:Setting string to a variable
Next Topic:model instance retrieval with ref to schema?
Current Time: Sat Jul 26 20:28:39 EDT 2025
Powered by FUDForum. Page generated in 0.04522 seconds
