Home » Archived » BIRT » JVM Terminated. Exit code=1
JVM Terminated. Exit code=1 [message #39007] Mon, 23 May 2005 04:09 Go to next message
I cannot preview my report and have to end process the 'javaw.exe' and
then my BIRT will close automatically close and got this error
C:\Windows\system32\javaw.exe
so on so forth..............
pls help..
wins
Re: JVM Terminated. Exit code=1 [message #41024 is a reply to message #39007] Tue, 24 May 2005 21:48 Go to previous messageGo to next message
Hi, WINS,
Can you provide more information about your environment and what you did?
Did you ever succeed previewing a simple report?
Stanley Wang
BIRT Engine
JVM Terminated. Exit code = 1 [message #41055 is a reply to message #41024] Tue, 24 May 2005 22:31 Go to previous messageGo to next message
Hi Stanley,
Just found out that I had some syntax error in my java script that hides 1
of my columns.
This is java script that causes the error 'JVM Terminated. Exit code = 1'
if (condition) {
true;
{ false;
BTW, I'm using win xp, mysql 4.1, tomcat 4.1.31, j2sdk1.4.2 and BIRT m3...
Wins
Re: JVM Terminated. Exit code = 1 [message #41086 is a reply to message #41055] Tue, 24 May 2005 22:42 Go to previous message
I suggest that if the java script has a syntax error BIRT must give a
warning message after clicking the OK button..just like exactly how the
'Query' works when creating a data set...
Thanks again,
Wins
Previous Topic:Hyperlink support
Next Topic:Note to BIRT script developers
Current Time: Fri Oct 31 10:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.27056 seconds
