Home » Archived » XML Schema Definition (XSD) » schema loading problems
schema loading problems [message #40905] |
Sun, 11 April 2004 18:13  |
Originally posted by: user.domain.invalid
i have downloaded the new emf, emf-xsd-sdo-SDK-I200404080727, and the
new eclipse sdk, eclipse-SDK-I20040407-linux-gtk. the new emf and the
older emf, emf-xsd-sdo-SDK-I200403250631, both run fine with m8,
eclipse-SDK-I20040326-linux-gtk (the first two configurations below).
neither the new emf nor the older emf allow me to load the same xsd
files (no details available, just the red x) when run with the new
eclipse, eclipse-SDK-I20040407-linux-gtk, (the second two
thank you
norwood sisson
cd $HOME/m8
unzip -q eclipse-SDK-I20040326-linux-gtk
unzip -q emf-xsd-sdo-SDK-I200403250631 -d eclipse
unzip -q GEF-SDK-I20040401 -d eclipse
unzip -q GEF-examples-I20040401 -d eclipse
cd eclipse
pwd
../eclipse -vm /home/nerd/j2sdk1.4.2_04/bin/java -vmargs -mx256m -ms128m
-Djava.endorsed.dirs=plugins/org.apache.xerces_4.0.13
cd $HOME/m8
unzip -q emf-xsd-sdo-SDK-I200404080727 -d eclipse
unzip -q GEF-SDK-I20040408 -d eclipse
unzip -q GEF-examples-I20040408 -d eclipse
cd eclipse
pwd
cd $HOME/m8
unzip -q eclipse-SDK-I20040407-linux-gtk
cd eclipse
pwd
cd $HOME/m8
cd eclipse
pwd
Re: schema loading problems [message #41032 is a reply to message #40905] |
Mon, 12 April 2004 07:09   |
We've only tested against M8. Does it work for that latest Eclipse
Window's integration driver, but not with the one for Linux? Have you
checked the workspace/.metadata/.log for clues?
> thank you
> norwood sisson
> cd $HOME/m8
> cd eclipse
> pwd
> cd $HOME/m8
> cd eclipse
> pwd
> cd $HOME/m8
> cd eclipse
> pwd
> cd $HOME/m8
> cd eclipse
> pwd
Re: schema loading problems [message #41063 is a reply to message #41032] |
Mon, 12 April 2004 11:31   |
--------------020505090403070800030603
Content-Type: text/plain; charset=us-ascii; format=flowed
i have no information about the windows configurations.
attached are the two log files for the two following linux configurations.
thank you
norwood sisson
Ed Merks wrote:
>>cd $HOME/m8
>>cd eclipse
>>pwd
>>cd $HOME/m8
>>cd eclipse
>>pwd
name="log1"
Content-Disposition: inline;
filename="log1"
!SESSION Apr 12, 2004 08:19:27.286 ---------------------------------------------
java.version=1.4.2_04
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.emf.codegen.ecore.ui 2 0 Apr 12, 2004 08:19:27.287
!MESSAGE
!STACK 0
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard$20.execute(EMFProjectWizard.java:1614)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:91)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1559)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:105)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 756)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard$XMLSchemaModelPage.refreshXMLSchemaModel(EMFProject Wizard.java:1687)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard$15.widgetSelected(EMFProjectWizard.java:1427)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:939)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1953)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1726)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:670 )
at org.eclipse.jface.window.Window.open(Window.java:650)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:109)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:550)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:502)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:435)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1561)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1532)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:257)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:140)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:279)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:241)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
at org.apache.crimson.tree.ElementNode2.getAttributeNodeNS(Elem entNode2.java:432)
at org.apache.crimson.tree.ElementNode2.hasAttributeNS(ElementN ode2.java:388)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.java:1752)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClass(XSDEcore Builder.java:589)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClassifier(XSD EcoreBuilder.java:318)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.getEClassifier(XSDEcor eBuilder.java:270)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.getEStructuralFeature( XSDEcoreBuilder.java:1490)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:1592)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:1542)
... 44 more
name="log2"
filename="log2"
!SESSION Apr 12, 2004 08:22:41.593 ---------------------------------------------
!ENTRY org.eclipse.emf.codegen.ecore.ui 2 0 Apr 12, 2004 08:22:41.594
!MESSAGE
!STACK 0
at org.eclipse.xsd.ecore.XSDEcoreBuilder.getEcoreAttribute(XSDE coreBuilder.java:1772)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClass(XSDEcore Builder.java:600)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClassifier(XSD EcoreBuilder.java:329)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.getEClassifier(XSDEcor eBuilder.java:281)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.getEStructuralFeature( XSDEcoreBuilder.java:1510)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:1612)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:1562)
... 44 more
--------------020505090403070800030603--
Re: schema loading problems [message #41095 is a reply to message #41063] |
Mon, 12 April 2004 13:27   |
This is the stack trace that the Crimsom DOM implementation produces I know there was talk about removing the org.apache.xerces plugin. Perhaps it's
gone in that driver. You'll need to specify a non-buggy DOM implementation to make this work.
> thank you
> norwood sisson
> Ed Merks wrote:
> > Hi,
> >>cd $HOME/m8
> >>cd eclipse
> >>pwd
> >>cd $HOME/m8
> >>cd eclipse
> >>pwd
> !MESSAGE
> !STACK 0
> ... 44 more
> !MESSAGE
> !STACK 0
> ... 44 more
Re: schema loading problems [message #41286 is a reply to message #41255] |
Tue, 13 April 2004 13:57  |
Norwood,
Your point is well taken. I'm often very stretched for time and am too impatient to specify background that may or may not be needed. I do try to respond quickly
so that follow up questions will get a quick reply.
> Ed
> emf-xsd does load schemas when i have downloaded xerces from apache.org
> as in the following configuration.
> it would also be easier for me and other dummies if you would be more
> explicit in your explanations. phrases like "You'll need to specify a
> non-buggy DOM implementation", "some other good implementation of JAXP",
> and "Frank,
> The file example you show looks like an XMI serialization of an instance
> that should be serialized as XML. Following the tutorial steps, a file
> like this is produced:" would be more meaningful if you stated something
> like "xerces from apache.org" and if you named the tutorial you are
> referencing.
> thank you
> norwood sisson
> cd $HOME/m8a
> unzip -q Xerces-J-bin.2.6.2 -d eclipse/plugins
> cd eclipse
> -Djava.endorsed.dirs=plugins/xerces-2_6_2
> Ed Merks wrote:
> > Is there an org.apache.xerces plugin in the Eclipse driver that you have? There's been talk of removing it, so maybe that's happened now, in which case the
> > workaround won't work because there's no directory where it's pointing. You just need to point at a directory with the jars that are in the Xerces plugin,
> > or some other good implementation of JAXP.
Re: schema loading problems [message #585386 is a reply to message #40905] |
> thank you
> norwood sisson
> cd $HOME/m8
> cd eclipse
> pwd
> cd $HOME/m8
> cd eclipse
> pwd
> cd $HOME/m8
> cd eclipse
> pwd
> cd $HOME/m8
> cd eclipse
> pwd
Re: schema loading problems [message #585403 is a reply to message #41032] |
thank you
norwood sisson
Ed Merks wrote:
>>cd $HOME/m8
>>cd eclipse
>>pwd
>>cd $HOME/m8
>>cd eclipse
>>pwd
name="log1"
filename="log1"
!MESSAGE
!STACK 0
... 44 more
name="log2"
filename="log2"
!MESSAGE
!STACK 0
... 44 more
Re: schema loading problems [message #585421 is a reply to message #41063] |
> thank you
> norwood sisson
> Ed Merks wrote:
> > Hi,
> >>cd $HOME/m8
> >>cd eclipse
> >>pwd
> >>cd $HOME/m8
> >>cd eclipse
> >>pwd
> !MESSAGE
> !STACK 0
> ... 44 more
> !MESSAGE
> !STACK 0
> ... 44 more
Re: schema loading problems [message #585435 is a reply to message #41095] |
Mon, 12 April 2004 15:03  |
if -Djava.endorsed.dirs=plugins/org.apache.xerces_4.0.13
does not specify a non-buggy DOM implementation, what will?
thank you
norwood sisson
>>thank you
>>norwood sisson
>>Ed Merks wrote:
>>>Hi,
>>>>cd $HOME/m8
>>>>cd eclipse
>>>>pwd
>>>>cd $HOME/m8
>>>>cd eclipse
>>>>pwd
Re: schema loading problems [message #585448 is a reply to message #41126] |
Mon, 12 April 2004 15:15  |
> thank you
> norwood sisson
> >>thank you
> >>norwood sisson
> >>Ed Merks wrote:
> >>>Hi,
> >>>>cd $HOME/m8
> >>>>cd eclipse
> >>>>pwd
> >>>>cd $HOME/m8
> >>>>cd eclipse
> >>>>pwd
Re: schema loading problems [message #585505 is a reply to message #41157] |
Tue, 13 April 2004 12:26  |
Ed
and "Frank,
referencing.
thank you
norwood sisson
cd $HOME/m8a
cd eclipse
Re: schema loading problems [message #585520 is a reply to message #41255] |
Norwood,
> Ed
> and "Frank,
> referencing.
> thank you
> norwood sisson
> cd $HOME/m8a
> cd eclipse
Current Time: Thu Jul 24 21:23:36 EDT 2025
Powered by FUDForum. Page generated in 0.08011 seconds
