Home » Modeling » EMF » ILightweightLabelDecorator stops working after a while
ILightweightLabelDecorator stops working after a while [message #407646] Wed, 07 March 2007 22:24 Go to next message
Originally posted by: regent.larcheveque.space.gc.ca
I have a simple EMF model:
-Items
-Item (EClass)
-Status (EReference: StatusOK, StatusWarning, StatusError)
I use a TreeViewer with a decorator that decorates Item based on the
actual Item.getStatus(). When I edit the model, the decorator works
into initialy properly. But after some operations, copy/paste/delete
actions, the decorator stop refreshing. The StatusItemProvider.getText()
is working properly (I output the status value to debug). I digged a bit
into the AdapterFactoryContentProvider. I override
AdapterFactoryContentProvider.notifyChanged():
if (viewer != null && viewer.getControl() != null &&
!viewer.getControl().isDisposed())
// If the notification is an IViewerNotification, it specifies how
// ViewerRefresh should behave. Otherwise fall
// back to NotifyChangedToViewerRefresh, which determines how to
// refresh the viewer directly from the model notification.
if (notification instanceof IViewerNotification)
// if (viewerRefresh == null) <------ REMOVE THIS LINE
viewerRefresh = new ViewerRefresh(viewer);
// } <------ REMOVE THIS LINE
if
(viewerRefresh.addNotification((IViewerNotification)notifica tion))
viewer.getControl().getDisplay().asyncExec(viewerRefresh);
This seems to resolve the problem. I suspect that
viewerRefresh.addNotification() does not take into account the
ViewerNotification. Before further digging in ViewerRefresh() I would
like to have some tips and helps.
Re: ILightweightLabelDecorator stops working after a while [message #407650 is a reply to message #407646] Thu, 08 March 2007 04:52 Go to previous messageGo to next message
Regent,
This seems pretty vague. I'd need to be able to reproduce a problem to
comment on it with any kind of insight.
Regent L'Archeveque wrote:
> -Items
> -Item (EClass)
> StatusItemProvider.getText() is working properly (I output the status
> value to debug). I digged a bit into the
> if
> Thanks
Re: ILightweightLabelDecorator stops working after a while [message #407667 is a reply to message #407650] Fri, 09 March 2007 00:53 Go to previous messageGo to next message
I finally found the problem. I realized that some references did not
have the attribute "derived" set to true. Then copy / paste commands
copied these references and this caused the problem. Sharing the same
references among the copies did not raise proper viewer notification.
Ed Merks wrote:
> Regent,
>> Hi,
>> -Items
>> -Item (EClass)
>> if
>> Thanks
Re: ILightweightLabelDecorator stops working after a while [message #407688 is a reply to message #407646] Sat, 10 March 2007 14:20 Go to previous message
You should consider using registration and notification of
ILabelProviderListeners in your LabelDecorator implementation.
Methods for that are declared in interface
IBaseLabelProvider. That way, the LabelDecorator itself can cause
refreshing of the Viewer when decorations are to be refreshed...
Note that in Eclipse, label decorations are often used to display
information which is kind of "orthogonal" to the state of the
object that is displayed in a viewer, e.g., label decorations for
resources that are under version control. So, sometimes, the object
whose visualization is decorated "knows nothing about the reason
for the decoration". If that's the case in your application, you could
consider following the approach mentioned above.
Greetings,
Andreas
> -Items
> -Item (EClass)
> if
> Thanks
Previous Topic:ECORE API example
Next Topic:Preventing editor generation
Current Time: Thu Sep 18 01:04:54 EDT 2025
Powered by FUDForum. Page generated in 0.04616 seconds
