Home » Archived » Test and Performance Tools Platform (TPTP) » Populate Log Navigator runtime
Populate Log Navigator runtime [message #40738] |
Tue, 15 November 2005 22:29  |
I'd like to add events to the Log Navigator without having to import a
log file, is there any API that I can use (or easy to modify?) to
achieve this? (I want to reuse the Log View in my plugin)
thanks
musachy
Re: Populate Log Navigator runtime [message #41140 is a reply to message #41047] |
Thu, 17 November 2005 09:59   |
Hi Paul,
With the latest development build 200511170100 of 4.1, when I click New
under Attach - Java Process, nothing happens, and this exception is
being logged:
java.lang.NoClassDefFoundError:
org/eclipse/tptp/platform/agentcontroller/internal/impl/Agen tControllerFactoryImpl
at
org.eclipse.hyades.trace.ui.internal.launcher.ProfileHostTab .setDefaults(ProfileHostTab.java:110)
at
org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.set Defaults(AbstractLaunchConfigurationTabGroup.java:74)
at
org.eclipse.debug.internal.ui.launchConfigurations.CreateLau nchConfigurationAction.performAction(CreateLaunchConfigurati onAction.java:73)
at
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction$1.run(AbstractLaunchConfigurationAc tion.java:103)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction.run(AbstractLaunchConfigurationActi on.java:106)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$ButtonActionNew.run(LaunchConfigurationsDi alog.java:1461)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$1.widgetSelected(LaunchConfigurationsDialo g.java:1430)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:439)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:35 6)
at
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:360)
at
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:302)
at
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
by the way this doesn't happen with the latest stable build. Is this
just me or this a bug?
thanks
musachy
Paul Slauenwhite wrote:
> Hi Musachy,
> The IAC is included with TPTP v4.1 (see org.eclipse.hyades.execution)
> and runs on-demand. For more information, see:
> Help >> Help Contents >> Working with the Agent Controller >> Profiling with
> a local deployment >> Integrated Agent Controller
> I have also opened an enhancement to include a Logging Agent sample in a
> future release of TPTP (see
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=116727).
> Paul
> "Musachy Barroso" <musachy@gmail.com> wrote in message
> news:dlge5l$hqs$1@news.eclipse.org...
>>This rocks! The only thing I need now is the IAC so I don't depend on
>>RAC. Is the IAC ready to use, at least in CVS?
>>thanks
>>musachy
>>>Hi Musachy,
>>> The easiest way load the log model which the Log View displays would
> be
>>>to write Common Base Events serialized as XML to a named Logging Agent
> using
>>>the org.eclipse.hyades.logging.core.LoggingAgent class in the
>>>org.eclipse.hyades.logging.core plugin. Using with the Agent Controller
> or
>>>Integrated Agent Controller configured (see Help >> Help Contents >>
> Working
>>>with the Agent Controller), attach to the named Logging Agent:
>>>1) Enable logging in the Profiling and Logging preferences (Window >
>>>Preferences... > Profiling and Logging > Enable logging > OK).
>>>2) Attach to the named Logging Agent in the Profiling and Logging
>>>Perspective (Run > Profile... > Attach - Java Process > New > Agents >
>>><named Logging Agent> OK > Profile).
>>> For more information, see the sample code and configuration in the
>>>http://www.eclipse.org/tptp/ >> Documentation >> EclipseWorld 2005 >>
> Using
>>>and Extending the Test and Performance Tools Platform >> source >>
>>>Demo_Agents >> eclipseworld.tutorial.demo.agents.DemoLoggingAgent and
>>>eclipseworld.tutorial.demo.agents.DemoStatisticalAgent.
>>>Paul
>>>news:dle92k$fai$1@news.eclipse.org...
>>>>Hi,
>>>>thanks
>>>>musachy
Re: Populate Log Navigator runtime [message #41170 is a reply to message #41140] |
Thu, 17 November 2005 11:37   |
I wonder if this is related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116214.
Make sure that you have logging enabled under the preference page:
Window > Preferences > Profiling and Logging > Check the 'Enable logging'
option.
If you can consistently reproduce this problem, then I would recommend
re-opening the defect with additional comments.
news:dli5t0$b2$1@news.eclipse.org...
> Hi Paul,
> being logged:
ryImpl
> at
> at
> at
Action.performAction(CreateLaunchConfigurationAction.java:73 )
> at
onAction$1.run(AbstractLaunchConfigurationAction.java:103)
> at
onAction.run(AbstractLaunchConfigurationAction.java:106)
> at
g$ButtonActionNew.run(LaunchConfigurationsDialog.java:1461)
> at
g$1.widgetSelected(LaunchConfigurationsDialog.java:1430)
> at
> at
> at
UITools.java:360)
> at
UITools.java:302)
> at
on.java:80)
> at
> at
tem.java:488)
> at
tionItem.java:400)
> at
> thanks
> musachy
> > Hi Musachy,
with
in a
> > Paul
> >>thanks
> >>musachy
> >>>Hi Musachy,
would
> > be
> > using
Controller
> > or
> > Working
> > Using
> >>>Paul
> >>>>Hi,
a
> >>>>thanks
> >>>>musachy
Re: Populate Log Navigator runtime [message #41232 is a reply to message #41170] |
Thu, 17 November 2005 15:33  |
Logging is enabled. I copied the stacktrace as a comment on the bug.
> option.
>>Hi Paul,
>>being logged:
> ryImpl
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
> UITools.java:360)
>>at
> UITools.java:302)
>>at
> on.java:80)
>>at
>>at
> tem.java:488)
>>at
> tionItem.java:400)
>>at
>>thanks
>>musachy
>>>Hi Musachy,
> with
> in a
>>>Paul
>>>>thanks
>>>>musachy
>>>>>Hi Musachy,
> would
>>>be
>>>using
> Controller
>>>or
>>>Working
>>>Using
>>>>>Paul
>>>>>>Hi,
> a
>>>>>>thanks
>>>>>>musachy
Current Time: Wed Jul 23 03:11:19 EDT 2025
Powered by FUDForum. Page generated in 0.15314 seconds
