Home » Eclipse Projects » Mylyn » Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector
Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #40634] Thu, 10 January 2008 05:25 Go to next message
Hi all,
Since my Mylyn 2.2 update I have a recurrent error pop-up:
The 'org.eclipse.mylyn.java.hyperlink.detector.stack' extension from
plug-in 'org.eclipse.mylyn.java.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
failed to load the hyperlink detector.
Plug-in org.eclipse.mylyn.java.ui was unable to load class
org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDe tector.
An error occurred while automatically activating bundle
org.eclipse.mylyn.java.ui (799).
The mylyn update was made today by the automatic eclipse install/update
feature.
I paste the log file of the workspace below, hoping this can help to
figure out what's missing.
And thanks to everyone making Mylyn such a great tool. I think it
improved the way to work for many of us.
Francois
!MESSAGE Plug-in org.eclipse.mylyn.java.ui was unable to load class
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at
... continuing OSGI classes
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionRea der.readHyperlinkDetector(TasksUiExtensionReader.java:296)
at
org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionRea der.initStartupExtensions(TasksUiExtensionReader.java:183)
at org.eclipse.mylyn.tasks.ui.TasksUiPlugin.start(TasksUiPlugin .java:433)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
... many more
Caused by: org.osgi.framework.BundleException: The activator
org.eclipse.mylyn.internal.java.ui.JavaUiBridgePlugin for bundle
org.eclipse.mylyn.java.ui is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 85 more
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/mylyn/internal/context/ui/AbstractContextUiPlugi n
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
... more OSGI loader classes
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #40696 is a reply to message #40634] Thu, 10 January 2008 21:01 Go to previous messageGo to next message
Originally posted by: rob.elves.eclipse.org
There was a dependency issue that could lead to this miss-configuration,
especially when using the "Search for updates..." vs "Search for new
features..." option. This has been resolved on the following bug report:
214301: [update] could not load tasklist hyperlink detector extension
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214301
To get your installation back in order, select Help (menu) > Software
Updates > Find and Install..., select the "Search for new features to
install" option, choose the Mylyn update site, and from the available
updates ensure you select the "Mylyn Focused UI" feature.
-Rob
Francois Cottet wrote:
> Hi all,
> feature.
> Best regards,
> Francois
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> ... many more
> at
> at
> at
> at
> at
> at
> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #40727 is a reply to message #40634] Thu, 10 January 2008 21:04 Go to previous messageGo to next message
I manually removed the subversive plugin and reinstall it from scratch
and the issue is gone.
I guess that the latest update for subversive is not working without
manually removing the files (the version numbers went backwards from 1.1
to 0.7 due to eclipse versioning requirement)
Francois
> Hi all,
> feature.
> Best regards,
> Francois
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> ... many more
> at
> at
> at
> at
> at
> at
> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #40850 is a reply to message #40696] Thu, 10 January 2008 22:48 Go to previous message
Thanks Rob.
Yes it seems to be the real reason underneath this error since i had
exactly the same scenario (doing a simple update rather than installing
a new mylyn version).
As indicated in a previsou message, reinstalling subversive and its
mylyn component fixed it as well (by installing the correct "Mylyn
Focused UI" feature).
Francois
> Regards,
> -Rob
>> Hi all,
>> point failed to load the hyperlink detector.
>> install/update feature.
>> Best regards,
>> Francois
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... many more
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #586804 is a reply to message #40634] Thu, 10 January 2008 21:01 Go to previous message
-Rob
> Hi all,
> feature.
> Best regards,
> Francois
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> ... many more
> at
> at
> at
> at
> at
> at
> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #586812 is a reply to message #40634] Thu, 10 January 2008 21:04 Go to previous message
Francois
> Hi all,
> feature.
> Best regards,
> Francois
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> ... many more
> at
> at
> at
> at
> at
> at
> ... 85 more
Re: Unable to load class org.eclipse.mylyn.internal.java.ui.JavaStackTraceHyperlinkDetector [message #586876 is a reply to message #40696] Thu, 10 January 2008 22:48 Go to previous message
Thanks Rob.
Francois
> Regards,
> -Rob
>> Hi all,
>> Best regards,
>> Francois
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... many more
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 85 more
Previous Topic:Access restriction: The type Browser is not accessible due to restriction on required library
Next Topic:Detecting a mid-air collision with Bugzilla
Current Time: Sat Jul 26 15:21:45 EDT 2025
Powered by FUDForum. Page generated in 0.06415 seconds
