Home » Eclipse Projects » DTP » problems with format SQL and code assist
problems with format SQL and code assist [message #40369] Thu, 03 January 2008 01:17 Go to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
I've installed DTP 1.5.1 from the update site. It mostly works. I setup
some db connections (to postgres using postgres 8.2 jdbc driver). I can
browse the DBs fine in the data source explorer, execute queries, view
the results, and use the sql editor.
However some features just don't seem to work, Format SQL doesn't appear
to do anything, and code assist, while offering suggestions for SQL
keywords like SELECT, doesn't seem to know anything about the tables and
columns in my db and won't autocomplete them (I got the impression it
should be able to based on some of the docs I've seen).
I've looked at the plugins manager, no DTP components are indicated as
having problems. I also tried dropping lpgjavaruntime.jar into my
classpath, with no effect on the problems above. And then tried using
the 1.6M4 release (since another comment mentioned that lpg came bundled
in that, and I thought maybe LPG had something to do with my probs).
Am I misunderstanding something or have I done something wrong in
installation?
Tom
(Eclipse 3.3.1 btw)
Re: problems with format SQL and code assist [message #40624 is a reply to message #40369] Wed, 16 January 2008 17:57 Go to previous message
Anybody got a hint?
Oh, something I forgot to mention is that the outline view doesn't work
either. I suspect it is all related.
Tom Walter wrote:
> installation?
> Thanks
> Tom
> (Eclipse 3.3.1 btw)
Re: problems with format SQL and code assist [message #589604 is a reply to message #40369] Wed, 16 January 2008 17:57 Go to previous message
Anybody got a hint?
Tom Walter wrote:
> installation?
> Thanks
> Tom
> (Eclipse 3.3.1 btw)
Previous Topic:datatools tooooo sloooooow.......
Next Topic:SQL Editor using ODA conx - 1 attachment
Current Time: Sat Jul 26 16:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.03300 seconds
