Home » Language IDEs » AspectJ » Eclipse 3.1M1 and JDK 1.5
Eclipse 3.1M1 and JDK 1.5 [message #40575] Sat, 11 September 2004 05:38 Go to next message
Originally posted by: eclipse.objectopia.org
I'm using Eclipse3.1M1 and started using generics. The eclipse java editor
does not like it when I declare generic types in an AspectJ project (but
this is fine for a Java project)
Presumably since AJDT overrids the default Java editor it has not been
updated for this new syntax yet ? Also, is it possible to not use the
aspectj editor for .java files and only use the aspectj editor for .aj files
Re: Eclipse 3.1M1 and JDK 1.5 [message #40607 is a reply to message #40575] Sat, 11 September 2004 12:47 Go to previous messageGo to next message
You can switch the editor for each file by right-clicking the file icon in
the package explorer.
Eric
Eric Bodden, ICQ: 12656220, http://www.bodden.de, PGP: BB465582
Arithmetische Kodierung - eine umfassende Einführung
http://bodden.de/studies/publications/pub_ac_de/
Re: Eclipse 3.1M1 and JDK 1.5 [message #41012 is a reply to message #40575] Wed, 29 September 2004 10:49 Go to previous messageGo to next message
files
You can change the default editor for a given file extension by clicking
'Window' > 'Preferences', expanding 'Workbench' and selecting 'File
Associations'. Then select the file type (e.g. "*.java") in the 'File
Types' box and change the default editor in the 'Associated Editors' section
below.
Sian January
AJDT fiddling with the Java Build path? [message #41665 is a reply to message #41012] Mon, 04 October 2004 05:10 Go to previous messageGo to next message
I have a strange observation:
apparently since I converted a former Java Project to an AspectJ
project I noticed that "something" is fiddling with the build path
(right click on project => Properties => Java Build Path) of that
project:
I repeatedly now observed that all project imports (second tab at the
right "Projects") get unchecked and instead I get corresponding new
entries on the "Libraries" tab pointing to <project>/build/classes.
Who/which component is changing this and why?
Michael
sorry - wrong thread [message #41728 is a reply to message #41665] Mon, 04 October 2004 05:28 Go to previous message
Apologies - by accident I made my new question appear as part of this
thread though it's completely unrelated. Please ignore!
Michael
Re: Eclipse 3.1M1 and JDK 1.5 [message #583067 is a reply to message #40575] Sat, 11 September 2004 12:47 Go to previous message
Eric
Re: Eclipse 3.1M1 and JDK 1.5 [message #583288 is a reply to message #40575] Wed, 29 September 2004 10:49 Go to previous message
files
below.
Sian January
AJDT fiddling with the Java Build path? [message #583570 is a reply to message #41012] Mon, 04 October 2004 05:10 Go to previous message
project:
Michael
sorry - wrong thread [message #583596 is a reply to message #41665] Mon, 04 October 2004 05:28 Go to previous message
Michael
Previous Topic:AJDT fiddling with the Java Build path?
Next Topic:Problem with AspectJ syntax: "no match for this type name"
Current Time: Fri Jul 18 21:47:29 EDT 2025
Powered by FUDForum. Page generated in 0.05735 seconds
