Home » Modeling » EMF » dangling '/' after remove.
dangling '/' after remove. [message #405564] Mon, 27 November 2006 12:52 Go to next message
Originally posted by: kellypu.ie.ibm.com
Hi all,
I get the following exception thrown when I try to load a resource :
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value
'com.ibm.mtools.repository.repository.impl.ModelSetContentsI mpl @1dc81dc8'
is not legal.
(file:/C:/development/runtime-build2311/.metadata/.plugins/c om.ibm.mtools.repository/_ecST0HsUEdunDsMuGFmZ1g-FB4DDB9C-F2 B9-79DF-9F56-54F6EF8F9D61.scp,
3, 122)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2393)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2378)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2525)
It happens when I try to load a resource after performing a delete and
save operation. Here is the contents of the model before and after
the save :
before the delete command is performed.
<mrd:ModelSetContents xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<artifact xsi:type="mrd:ViewModel" name="ScopeModel"
view="//@artifact.1"/>
<artifact xsi:type="mrd:View" name="NewScope" local="true"/>
</mrd:ModelSetContents>
This is the contents of the model after the delete command is performed
(Note the dangling '/')
<artifact xsi:type="mrd:ViewModel" name="ScopeModel" view="/"/>
Because of the view="/", i get an IllegalValueException thrown.
I have a feeling it might be a containment issue, but I can't be sure.
I tried stepping through ResourceImpl.getURIFragment but nothing is
looking too obvious.
Any help appreciated,
Paul
Re: dangling '/' after remove. [message #405571 is a reply to message #405564] Mon, 27 November 2006 17:16 Go to previous messageGo to next message
Paul,
In EMF 2.2, dangling IDREFs are not properly detected which as been
fixed by https://bugs.eclipse.org/bugs/show_bug.cgi?id=153577. But the
changes were quite extensive and didn't seem suitable for the 2.2
maintenance stream. That bugzilla explains a work around...
Paul Kelly wrote:
> Hi all,
> is not legal.
> 3, 122)
> at
> at
> at
> the save :
> xmlns:xmi="http://www.omg.org/XMI"
> performed (Note the dangling '/')
> Cheers,
> Paul
Re: dangling '/' after remove. [message #405577 is a reply to message #405564] Tue, 28 November 2006 04:02 Go to previous messageGo to next message
Originally posted by: spider_a.freenet.am
hi, whay do you delete View at all..? Did you try same thing with View="", i think you just can keep it empty, and in this way it should works.
regards,
Re: dangling '/' after remove. [message #405585 is a reply to message #405571] Tue, 28 November 2006 11:16 Go to previous message
Hi all,
Workaround in bugzilla did the trick.
Thanks again,
Paul
Ed Merks wrote:
> Paul,
> Paul Kelly wrote:
>> Hi all,
>> is not legal.
>> 3, 122)
>> at
>> at
>> at
>> the save :
>> <?xml version="1.0" encoding="UTF-8"?>
>> Cheers,
>> Paul
Previous Topic:XML binding: tabs replaced with spaces?
Next Topic:Metamodel mapping with ecore2ecore
Current Time: Thu Sep 18 09:02:47 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
