Home » Eclipse Projects » Subversive » Usability question regarding Sharing Project
Usability question regarding Sharing Project [message #40414] Sun, 18 January 2009 08:46 Go to next message
Originally posted by: tina.young.nospam.hotmail.com
I have a simple question about the usability of share projects in subversive
(I'm a newbi so please bare with me)
Our projects consists of different layers. So we have structured our
repository
with folders that corresponds to the layers. So our trunk looks like
trunk
|-- Client
| -- Src
| -- Test
|-- Commons
| -- Src
| -- Test
|-- Server
|-- Src
| -- Test
So typically we want to add Eclipse projects the under the directories Src
and Test in respective layer
(e.g. directory)
The only mode where you actually can navigate to these directories is using
'Simple Mode'
(but simple mode does not store the actual project directory so that can not
be used).
So currently we select 'Advanced Mode' and 'Use specified Name' and manully
enter
trunk/Client/Src/<Project name>
We also need to select the radio button 'Use Single Project Layout' and
uncheck the
'Use Subversion recommended layout ......'
Are we doing something too complicated to get this working or is this they
way to do it ?
T Young
Re: Usability question regarding Sharing Project [message #40474 is a reply to message #40414] Wed, 21 January 2009 06:48 Go to previous message
Hello Tina,
I could advice you here to use Simple Mode.
> using 'Simple Mode'
> not be used).
Url field in Simple Mode points to destination folder in repository and in
this case all your project content (not including project directory)! will
be commited. So you need manually to specify project directory in the end of
Url.
For instance, if you need to share 'foo-project' in
http://repos/trunk/Client/Src you can specify url:
http://repos/trunk/Client/Src/foo-project
> subversive
> repository
> trunk
> |-- Client
> | -- Src
> | -- Test
> |-- Commons
> | -- Src
> | -- Test
> |-- Server
> |-- Src
> | -- Test
> (e.g. directory)
> using 'Simple Mode'
> not be used).
> manully enter
> uncheck the
> way to do it ?
> Regards
> T Young
Previous Topic:Compare with latest from repository --> EmptyStackException
Next Topic:Removing an external checked out folder from my project. How?
Current Time: Sat Sep 27 04:29:02 EDT 2025
Powered by FUDForum. Page generated in 0.04695 seconds
