Home » Archived » Test and Performance Tools Platform (TPTP) » Datapool - TPTP 4.0.1 missing jar files
Datapool - TPTP 4.0.1 missing jar files [message #40308] Mon, 14 November 2005 10:28 Go to next message
In version 4.0.1 of TPTP (tptp.sdk-TPTP-4.0.1-200510031151.zip) and version
2.1.0 of EMF I could not find the datapool jar files specified in the help
documentation:
a..
[ECLIPSE_HOME]/plugins/org.eclipse.hyades.models.common_3.0. 0/common_model.jar
b..
[ECLIPSE_HOME]/plugins/org.eclipse.hyades.test.datapool_3.0. 0/datapool_api.jar
c.. [ECLIPSE_HOME]/plugins/org.eclipse.emf.ecore_2.0.0/runtime/e core.jar
d.. [ECLIPSE_HOME]/plugins/org.eclipse.emf.common_2.0.0/runtime/ common.jar
I have only been able to find the first two files in version 3.3.0 of hyades
(hyades.runtime_3.3.0_20050623_2150), and the EMF jar files in version
2.0.0.
Does this mean that the method for accessing a datapool has changed?
Or, should the jar files be included with version 4.0.1 of TPTP and 2.1.0 of
EMF? If this is the case then please can you either include the jars with
the installation zip files, or provide a link to them on the download pages.
Or even better make the addition of the files part of the update process.
David Murley
Re: Datapool - TPTP 4.0.1 missing jar files [message #40372 is a reply to message #40308] Mon, 14 November 2005 14:46 Go to previous messageGo to next message
Hi David,
Since 4.0 all the TPTP models code was merged into
plugins/org.eclipse.tptp.platform.models/tptp-models.jar, this JAR file
includes also the data pool API.
Please open a defect regarding the help documentation that specifies the
datapool jar file, it needs to be updated to reflect the real structure.
Marius
"David Murley" <david.murley@worldflow.net> wrote in message
news:dlaaf1$ha9$1@news.eclipse.org...
version
> documentation:
> a..
ar
> b..
ar
> d..
hyades
> 2.0.0.
of
pages.
> David Murley
Re: Datapool - TPTP 4.0.1 missing jar files [message #40402 is a reply to message #40372] Mon, 14 November 2005 16:16 Go to previous messageGo to next message
FYI: The outdated documentation was fixed in 4.1.
"Marius Slavescu" <slavescu@ca.ibm.com> wrote in message
news:dlapip$8t2$1@news.eclipse.org...
> Hi David,
> Regards,
> Marius
> version
help
> > documentation:
> > a..
> ar
> > b..
> ar
> > c..
> > d..
> hyades
> > 2.0.0.
2.1.0
> of
with
> pages.
process.
> > Thanks,
> > David Murley
Re: Datapool - TPTP 4.0.1 missing jar files [message #42211 is a reply to message #40402] Thu, 24 November 2005 04:23 Go to previous messageGo to next message
>> Hi David,
>> Regards,
>> Marius
>> version
> help
>> > documentation:
>> > a..
>> ar
>> > b..
>> ar
>> > c..
>> > d..
>> hyades
>> > 2.0.0.
> 2.1.0
>> of
> with
>> pages.
> process.
>> > Thanks,
>> > David Murley
FYI : The outdated documentation was NOT fixed even in 4.1.0
(I checked today 24 - 11 - 2005)
Re: Datapool - TPTP 4.0.1 missing jar files [message #42444 is a reply to message #42211] Thu, 24 November 2005 06:10 Go to previous messageGo to next message
For anyone else with the same problem, I found the following worked for me.
Jar Files for using datapools in TPTP 4.0.1:
[ECLIPSE_HOME]\plugins\org.eclipse.core.runtime_3.1.0.jar
[ECLIPSE_HOME]\plugins\org.eclipse.emf.common_2.1.0.jar
[ECLIPSE_HOME]\plugins\org.eclipse.emf.ecore_2.1.0.jar
[ECLIPSE_HOME]\plugins\org.eclipse.tptp.platform.models_4.0. 0\tptp-models.jar
Also the string for opening the datapool iterator should be:
" org.eclipse.hyades.datapool.iterator.DatapoolIteratorSequent ialPrivate "
Not as listed in the help documentation:
" org.eclipse.hyades.datapool.DatapoolIteratorSequentialPrivat e "
"Luiza " <Luiza@yahoo.com> wrote in message
news:cecaa4a7f3394be1240edc92dac35dd6$1@www.eclipse.org...
>>> Hi David,
>>> Regards,
>>> Marius
>>> version
>> help
>>> > documentation:
>>> > a..
>>> ar
>>> > b..
>>> ar
>>> > c..
>>> > d..
>>> hyades
>>> > 2.0.0.
>> 2.1.0
>>> of
>> with
>>> pages.
>> process.
>>> > Thanks,
>>> > David Murley
Re: Datapool - TPTP 4.0.1 missing jar files [message #42836 is a reply to message #42211] Thu, 24 November 2005 13:33 Go to previous message
This is a multipart message in MIME format.
--=_alternative 0065EEB6852570C3_=
Content-Type: text/plain; charset="US-ASCII"
David opened defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=116634
against the 4.0.1 version. 116634 is scheduled to be fixed in the proposed
4.0.2 stream.
Luiza, can you tell me which file that you're looking at in the 4.1.0
stream? The file that I thought that this stream was discussing was
deleted in 4.1.0 (org.eclipse.hyades.test.doc.user/tasks/taccessdp.htm).
1. Right-click on the "Accessing a datapool from a Hyades test" in
the Contents,
2. Select "Properties"
3. Copy and paste the Address(URL) and post it in this thread.
For those who want a sneak peek, here's the link to a new file in the
4.1.0 stream that explains how to work with datapools. The "Accessing a
datapool from a Hyades test" topic was deleted and completely rewritten as
a tutorial:
http://dev.eclipse.org/viewcvs/index.cgi/*checkout*/test/org .eclipse.hyades.test.doc.user/samples/saccessdp.htm?rev=1.5& amp;cvsroot=TPTP_Project
TPTP recognizes the importance of good documentation. We started an
initiative in TPTP 4.1 to put the documentation through some rigorous
testing. All documentation now goes through a "step through" once per
release after the UI is frozen; a person reads the topic and follows its
steps exactly to see if anything needs to be updated. That test is how we
realized that this topic needed to be updated. I'm not saying that the
docs are perfect - they're a work in progress just as the TPTP code is --
but we take reports of problems in the documentation seriously. Please
open bugzillas for defects that you find, enhancements for documentation
that you'd like to have, and continue to post your questions about
documentation on this newsgroup.
Thank you for reporting the problem.
--Ruth.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">David opened defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=116634
4.0.2 stream.</font>
<br>
<br><font size=2 face="sans-serif">Luiza, can you tell me which file that
you're looking at in the 4.1.0 stream? The file that I thought that this
stream was discussing was deleted in 4.1.0 (org.eclipse.hyades.test.doc.user/tasks/taccessdp.htm).
</font>
<br><font size=2 face="sans-serif">&nbsp; &nbsp; &nbsp; &nbsp; 1.
Right-click on the &quot;Accessing a datapool from a Hyades test&quot;
in the Contents, </font>
<br><font size=2 face="sans-serif">&nbsp; &nbsp; &nbsp; &nbsp; 2.
Select &quot;Properties&quot;</font>
<br><font size=2 face="sans-serif">&nbsp; &nbsp; &nbsp; &nbsp; 3.
Copy and paste the Address(URL) and post it in this thread.</font>
<br>
<br><font size=2 face="sans-serif">For those who want a sneak peek, here's
the link to a new file in the 4.1.0 stream that explains how to work with
datapools. The &quot;Accessing a datapool from a Hyades test&quot; topic
was deleted and completely rewritten as a tutorial: http://dev.eclipse.org/viewcvs/index.cgi/*checkout*/test/org .eclipse.hyades.test.doc.user/samples/saccessdp.htm?rev=1.5& amp;amp;cvsroot=TPTP_Project</font>
<br>
<br><font size=2 face="sans-serif">TPTP recognizes the importance of good
documentation. We started an initiative in TPTP 4.1 to put the documentation
through some rigorous testing. All documentation now goes through a &quot;step
through&quot; once per release after the UI is frozen; a person reads the
topic and follows its steps exactly to see if anything needs to be updated.
That test is how we realized that this topic needed to be updated. I'm
not saying that the docs are perfect - they're a work in progress just
as the TPTP code is -- but we take reports of problems in the documentation
seriously. Please open bugzillas for defects that you find, enhancements
for documentation that you'd like to have, and continue to post your questions
about documentation on this newsgroup. </font>
<br>
<br><font size=2 face="sans-serif">Thank you for reporting the problem.</font>
<br>
<br><font size=2 face="sans-serif">--Ruth.</font>
<br>
<br>
--=_alternative 0065EEB6852570C3_=--
Previous Topic:Max Datapool records
Next Topic:Filter in the Execution Time Analysis
Current Time: Sat Jul 26 11:02:03 EDT 2025
Powered by FUDForum. Page generated in 0.30055 seconds
