| getName() returns null too [message #40362] |
Sat, 03 April 2004 12:24  |
Originally posted by: stibrany.tenax.sk
Hello.
Another "returns null" question :-)
When I call getName() method of XSDElementDeclaration, it gives me null,
although getQName() returns correct answer. How can I get element name
without "...:" prefix?
Thank you.
-Peter Stibrany
| Re: getName() returns null too [message #40597 is a reply to message #40511] |
Mon, 05 April 2004 15:40  |
Ed Merks wrote:
> Peter,
> An XSDElementDeclaration is used to represent either the actual "abstract"
> element declaration or an element declaration reference, in which case all
> the properties are null and the getResolveElementDeclaration is needed to
> navigate to the actual declaration with all the properties, like name, that
> you want to examine. Again, depending on how you traverse the model, you
> can avoid seeing element declaration references if you aren't interested in
> seeing them.
Thank you for answer. I think I am starting to understand this "abstract"
versus "concrete" thing. When I am reading XML Schema specs, they are
mostly talking about "abstract" view of schema, and that is what I really
want. I will more carefully look at XSD methods and double-check before I
post my questions here.
-Peter Stibrany
| Re: getName() returns null too [message #585093 is a reply to message #40362] |
Mon, 05 April 2004 06:38  |
Peter,
seeing them.
Peter Stibrany wrote:
> Hello.
> Thank you.
> -Peter Stibrany
| Re: getName() returns null too [message #585162 is a reply to message #40511] |
Ed Merks wrote:
> Peter,
> seeing them.
-Peter Stibrany
FUDForum. Page generated in 2.57906 seconds
