Home » Modeling » EMF » How to use more than one core file
| How to use more than one core file [message #403385] |
Tue, 05 September 2006 13:29  |
Assume 2 ecore files A.ecore and B.ecore each of them in a different EMF
plugin project where B.ecore loads A.ecore as a resource. In this case,
A.genmodel only contains A.ecore while B.genmodel contains both A.ecore
and B.ecore. Consequently, trying to generate code by B.ecore insists on
generating both A and B models where A has to be redundantly created again
in the plugin B.
Imagine you have some classes in plugin A and you want to subclass these
classes in plugins B and C. How is it possible to do this with EMF
avoiding the problem above?
| Re: How to use more than one core file [message #403405 is a reply to message #403387] |
Wed, 06 September 2006 13:20   |
Ed,
Thanks, that does the job. However, I end up with 2 different editors now.
How is it possible to set B in a way that the sub-classes it generates
appear in the A editor? Would the approach be consistant with GMF editors?
Ed Merks wrote:
> Ali,
> When creating the GenModel for B, in the final dialog, you should browse
> for the GenModel for A and reuse the GenPackage for A.ecore rather than
> creating yet another new GenPackage for it in the GenModel for B.
> Ali wrote:
>> Hi,
>> EMF plugin project where B.ecore loads A.ecore as a resource. In this
>> case, A.genmodel only contains A.ecore while B.genmodel contains both
>> A.ecore and B.ecore. Consequently, trying to generate code by B.ecore
>> insists on generating both A and B models where A has to be
>> redundantly created again in the plugin B.
>> these classes in plugins B and C. How is it possible to do this with
>> EMF avoiding the problem above?
| Re: How to use more than one core file [message #403410 is a reply to message #403405] |
Thu, 07 September 2006 08:51   |
Ali,
This is a short coming covered by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=109472. There was a
recent newsgroup thread "dynamically extend EMF model" on this topic...
Ali wrote:
> Ed,
> now. How is it possible to set B in a way that the sub-classes it
> generates appear in the A editor? Would the approach be consistant
> with GMF editors?
> Ed Merks wrote:
>> Ali,
>> browse for the GenModel for A and reuse the GenPackage for A.ecore
>> rather than creating yet another new GenPackage for it in the
>> GenModel for B.
>> Ali wrote:
>>> Hi,
>>> this case, A.genmodel only contains A.ecore while B.genmodel
>>> contains both A.ecore and B.ecore. Consequently, trying to generate
>>> code by B.ecore insists on generating both A and B models where A
>>> has to be redundantly created again in the plugin B.
| Re: How to use more than one core file [message #403413 is a reply to message #403410] |
Thu, 07 September 2006 08:57   |
Ed,
The link does not work. All I want is when users develop their own plugins
involving sub-classes of the already existing classes, the sub-classes
appear in the original editor. The impression that I got from eclipse
plugin structure was that this feature should be already available in emf.
Ed Merks wrote:
> Ali,
> Ali wrote:
>> Ed,
>> with GMF editors?
>> Ed Merks wrote:
>>> Ali,
>>> GenModel for B.
>>> Ali wrote:
>>>> Hi,
| Re: How to use more than one core file [message #403415 is a reply to message #403413] |
Thu, 07 September 2006 09:11   |
--------------000409090804020400050402
Ali,
The link must just not work for you. Perhaps this list of all the
bugzillas will work for you:
https://bugs.eclipse.org/bugs/buglist.cgi?product=EMF,XSD&am p;bug_status=NEW&bug_status=ASSIGNED&bug_status=REOP ENED&order=bugs.bug_status,bugs.target_milestone,bugs.bu g_id&query_format=advanced
< https://bugs.eclipse.org/bugs/buglist.cgi?product=EMF,XSD&am p;bug_status=NEW&bug_status=ASSIGNED&bug_status=REOP ENED&order=bugs.bug_status,bugs.target_milestone,bugs.bu g_id&query_format=advanced>
Right now, derived classes introduced by a separate plugin will not be
known to a generated editor that knew only about the base class at the
time it was generated. Did you look at the other thread?
Ali wrote:
> Ed,
> plugins involving sub-classes of the already existing classes, the
> sub-classes appear in the original editor. The impression that I got
> from eclipse plugin structure was that this feature should be already
> available in emf.
> Ed Merks wrote:
>> Ali,
>> Ali wrote:
>>> Ed,
>>> editors now. How is it possible to set B in a way that the
>>> sub-classes it generates appear in the A editor? Would the approach
>>> Ed Merks wrote:
>>>> Ali,
>>>> GenModel for B.
>>>> Ali wrote:
>>>>> Hi,
>>>>> different EMF plugin project where B.ecore loads A.ecore as a
>>>>> resource. In this case, A.genmodel only contains A.ecore while
>>>>> B.genmodel contains both A.ecore and B.ecore. Consequently, trying
>>>>> to generate code by B.ecore insists on generating both A and B
>>>>> models where A has to be redundantly created again in the plugin B.
>>>>> with EMF avoiding the problem above?
<html>
<head>
http-equiv="Content-Type">
</head>
Ali,<br>
<br>
| Re: How to use more than one core file [message #403416 is a reply to message #403415] |
Thu, 07 September 2006 09:26   |
Ed,
Thanks a lot. I am going to try the approach in the other thread. Is
this going to be part of EMF soon?
Ed Merks wrote:
> Ali,
> Ali wrote:
>> Ed,
>> available in emf.
>> Ed Merks wrote:
>>> Ali,
>>> Ali wrote:
>>>> Ed,
>>>> Ed Merks wrote:
>>>>> Ali,
>>>>> GenModel for B.
>>>>> Ali wrote:
>>>>>> Hi,
| Re: How to use more than one core file [message #403417 is a reply to message #403416] |
Thu, 07 September 2006 09:28   |
And one more thing, is that approach going to work with GMF, or do I
need to customise GMF as well?
Ali wrote:
> Ed,
> Ed Merks wrote:
>> Ali,
>> Ali wrote:
>>> Ed,
>>> available in emf.
>>> Ed Merks wrote:
>>>> Ali,
>>>> Ali wrote:
>>>>> Ed,
>>>>> Ed Merks wrote:
>>>>>> Ali,
>>>>>> GenModel for B.
>>>>>> Ali wrote:
>>>>>>> Hi,
>>>>>>> trying to generate code by B.ecore insists on generating both A
>>>>>>> and B models where A has to be redundantly created again in the
>>>>>>> plugin B.
>>>>>>> subclass these classes in plugins B and C. How is it possible to
>>>>>>> do this with EMF avoiding the problem above?
| Re: How to use more than one core file [message #403418 is a reply to message #403417] |
Thu, 07 September 2006 09:44  |
Ali,
We'll try to get this resolved in the 3.0 (current) release cycle. I'm
not sure if GMF reuses the create child commands...
> Ali wrote:
>> Ed,
>> Ed Merks wrote:
>>> Ali,
>>> be known to a generated editor that knew only about the base class
>>> at the time it was generated. Did you look at the other thread?
>>> Ali wrote:
>>>> Ed,
>>>> got from eclipse plugin structure was that this feature should be
>>>> Ed Merks wrote:
>>>>> Ali,
>>>>> topic...
>>>>> Ali wrote:
>>>>>> Ed,
>>>>>> Ed Merks wrote:
>>>>>>> Ali,
>>>>>>> should browse for the GenModel for A and reuse the GenPackage
>>>>>>> for A.ecore rather than creating yet another new GenPackage for
>>>>>>> Ali wrote:
>>>>>>>> Hi,
>>>>>>>> plugin B.
>>>>>>>> to do this with EMF avoiding the problem above?
Current Time: Wed Nov 05 09:33:17 EST 2025
Powered by FUDForum. Page generated in 0.05743 seconds
