| EMap of EMaps [message #403406] |
Wed, 06 September 2006 15:09  |
Originally posted by: andrew1.us.ibm.com
Ed - I found an example that you posted on how to create an EMap whose
values are EMaps - back last Nov 2005. One question - you define an
interface X which contains a map. Are the keyType and valueType values
optional in the declaration (see below) since you also specify a mapType
value. I thought one used either mapType or keyType/valueType. I have
the example and can play around with it, but wanted to know what's the
required info in declaring the top level map.
Thanks;
Andy R.
public interface X extends EObject
* Returns the value of the '<em><b>Map</b></em>' map.
* The key is of type {@link java.lang.String},
* and the value is of type list of {@link java.util.Map.Entry},
* <!-- begin-user-doc -->
* <p>
* If the meaning of the '<em>Map</em>' map isn't clear,
* there really should be more of a description here...
* </p>
* <!-- end-user-doc -->
* @return the value of the '<em>Map</em>' map.
* @see map.MapPackage#getX_Map()
* @model mapType="map.Y" keyType="java.lang.String"
valueType="java.util.Map.Entry"
* @generated
EMap getMap();
| Re: EMap of EMaps [message #403409 is a reply to message #403406] |
Thu, 07 September 2006 08:44  |
Andrew,
If the referenced mapType is already defined in the XyzPackage, then the
keyType and the valueType are redundant because they will also be
specified there.
> values optional in the declaration (see below) since you also specify
> a mapType value. I thought one used either mapType or
> keyType/valueType. I have the example and can play around with it,
> but wanted to know what's the required info in declaring the top level
> map.
> Thanks;
> Andy R.
> * <p>
> * </p>
> * @generated
> EMap getMap();
FUDForum. Page generated in 0.04469 seconds
