Home » Modeling » EMF » Building EMF
Building EMF [message #403403] Wed, 06 September 2006 12:50 Go to next message
Originally posted by: Cassy.hotmail.com
I want to build my own version of the EMF plugin and I failed :(
Here is what i've done :
- CO dev.eclipse.org CVS. I checkout Head/org.eclipse.emf/plugins in my
workspace.
- To build org.eclipse.importer.ecore and rose, I execute ant task of
org.eclipse.ant which created
org.eclipse.emf.ant/ant_tasks/emf.ant.tasks.jar.
- At this point, everything built without errors
- I Select "org.eclipse.emf" and click "Run AS > Eclipse Application"
- In the new eclipse, I looked in Help > Plugin Details. I see every plugins
installed, org.eclipse.emf.*
If I create a project using EMF (Loading an Ecore file and generating the
model from it). It seems that eclipse do not use my EMF plugin, I can't add
any org.eclipse.emf in the dependencies and then, every import of
"org.eclipse.emf.*" is failing .... Don't know what to do...
What am I doing wrong ?
Re: Building EMF [message #403404 is a reply to message #403403] Wed, 06 September 2006 13:02 Go to previous messageGo to next message
I tried to export the plugins and to install them in an Eclipse.
Result :
-> I can add the org.eclipse.emf.* plugins in dependencies. It works, no
prob.
-> BUT, in my files, every "import org.eclipse.emf....." failed :(
Error message : "The import org.Eclipse.emf cannot be resolved".
Hope it helps :(
"Cassy" <Cassy@hotmail.com> a
Re: Building EMF [message #403411 is a reply to message #403404] Thu, 07 September 2006 08:53 Go to previous message
--------------010802080901070704060002
Cassy,
It sounds like you probably didn't build the jars that are specified as
the classpath in the MANIFEST.MF. Our build process replaces these with
.. and then jars the whole plugin, but at development time, we run a
script to build the jars.
> Result :
> prob.
> Hope it helps :(
Previous Topic:EMap of EMaps
Next Topic:How to use more than one core file
Current Time: Wed Nov 05 10:51:44 EST 2025
Powered by FUDForum. Page generated in 0.03721 seconds
