| Re: when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403395 is a reply to message #403392] |
Wed, 06 September 2006 09:19   |
Hi, Ed,
I worked that out.
I direclty modified the .ecore file according to some .ecore file i created
before,
It seems that i need
<ecore:EPackage xmi:version="2.0" and
<eClassifiers xsi:type="ecore:EClass" name="ModelModelUI">
before adding this, i only have some EAttributes..
Thanks very much.
chen
"chen" <wangchen1981@gmail.com> wrote in message
news:edmhbo$7n2$1@utils.eclipse.org...
>I checked..but there is no clue for this...
> I actually only build a very simiple Ecore model with only one attibute,
> but still...
> I have attached my ecore file to this mail..could u help me check what's
> wrong with this?
> I wanna generate the .genmodel from this ...
> Thanks in advance..
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:edmghl$2bv$2@utils.eclipse.org...
>> Chen,
>> Check the error log view. There must be some clues as to what's gone
>> wrong.
>> chen wrote:
>>> the .ecore file is generated through EclipseUML, but when i try to
>>> import
>>> the .ecore file, it always failed.
>>> (The "finish" button always is always disabled.)
>>> any reason for this?
>>> Thanks
| Re: when try to generate .genmodel from .ecore file, the ecore could not be loaded [message #403396 is a reply to message #403392] |
Wed, 06 September 2006 09:21  |
--------------040503030403050900050209
Chen,
The resource doesn't contain an EPackage so it's being treated like an
empty file. An EClass in isolation is not meaningful. It must be
nested in an EPackage.
> I actually only build a very simiple Ecore model with only one attibute, but
> still...
> wrong with this?
> Thanks in advance..
>> Chen,
>> wrong.
>> chen wrote:
>>> the .ecore file is generated through EclipseUML, but when i try to import
>>> Thanks
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Chen,<br>
<br>
nested in an EPackage.<br>
<br>
<br>
chen wrote:
<blockquote cite="midedmhbo$7n2$1@utils.eclipse.org" type="cite">
<pre wrap="">I checked..but there is no clue for this...
still...
wrong with this?
Thanks in advance..
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:edmghl$2bv$2@utils.eclipse.org">news:edmghl$2bv$2@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Chen,
wrong.
chen wrote:
</pre>
<pre wrap="">the .ecore file is generated through EclipseUML, but when i try to import
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040503030403050900050209--
FUDForum. Page generated in 0.03179 seconds
