Plugin deployment problem on IBM JRE 1.4.2 [message #40282] |
Wed, 14 January 2009 04:10  |
i'm having an eclipse plugin that deploys perfectly on Eclipse 3.4 when it
runs on all JRE's except IBM JRE 1.4.2.
is it a known problem?
can someone suggest a direction of pointing this problem?
thx
itsik
Re: Plugin deployment problem on IBM JRE 1.4.2 [message #40380 is a reply to message #40319] |
Wed, 14 January 2009 07:38  |
Hello and thx for the reply.
Jacek Pospychala wrote:
> Hello Itsik,
> all plug-ins should work well on IBM JREs as well as on other JREs.
> Maybe your plug-in requires version 1.5?
no, it worked with JRE 1.4 too, specifically with Sun JRE 1.4.2.
> How do you know, that something has failed with the deploy? Do you see
> any error, or are there any messages in Error log view?
actually, i did not c any error in the log that is related to this case.
> Jacek
well, after i upgraded the JRE to SR12 the problem has mysteriously solved.
thx again
itsik
Re: Plugin deployment problem on IBM JRE 1.4.2 [message #588220 is a reply to message #40282] |
Wed, 14 January 2009 05:35  |
Hello Itsik,
Jacek
Itsik pisze:
> it runs on all JRE's except IBM JRE 1.4.2.
Re: Plugin deployment problem on IBM JRE 1.4.2 [message #588236 is a reply to message #40319] |
> Hello Itsik,
> Jacek
thx again
itsik
FUDForum. Page generated in 0.04132 seconds
