Home » Language IDEs » AspectJ » Eclipse 3.0.0 & task view
Eclipse 3.0.0 & task view [message #40130] Fri, 13 August 2004 09:53 Go to next message
Originally posted by: ad-rocha.uol.com.br
I've moved to Eclipse 3.0.0 (Build id: 200406251208) and i'm experiencing a
new problem...
When I click in a problem/warning listed in the task view I don't go to the
correspondig line/file. How to fix it?
Thanks!
Re: Eclipse 3.0.0 & task view [message #40168 is a reply to message #40130] Fri, 13 August 2004 10:38 Go to previous messageGo to next message
Could you possibly provide some more details - the version of AJDT you have
installed, the kinds of errors that are causing you problems (are they from
declare error/warning statements?) and what does happen when you double
click.
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #40229 is a reply to message #40168] Fri, 13 August 2004 13:17 Go to previous messageGo to next message
I'm working with Eclipse 3.0.0 and AJDT 1.1.12. The warnings are normal java
warnings (please see attached file) and when I double click nothing happens.
Is it a Eclipse 3.0.0 normal behavior? how can I change it?
"Sian Whiting" <swhiting@uk.ibm.com> escreveu na mensagem
news:cfijk2$ifq$1@eclipse.org...
> Hello,
have
from
> click.
> Sian
> "Andr
  • Attachment: ajdt.JPG
    (Size: 128.35KB, Downloaded 253 times)
Re: Eclipse 3.0.0 & task view [message #40243 is a reply to message #40168] Fri, 13 August 2004 16:18 Go to previous messageGo to next message
Another question is why the warning/error icon is not appering in the left
side of editor, indicating the erroneous line... (like in java perspective)
> Hello,
have
from
> click.
> Sian
> "Andr
Re: Eclipse 3.0.0 & task view [message #40252 is a reply to message #40229] Mon, 16 August 2004 06:04 Go to previous messageGo to next message
Thanks for the extra information. This problem has been encountered before
(see bug 70913 https://bugs.eclipse.org/bugs/show_bug.cgi?id=70913) although
we have been unable to track down its cause. The solution for the time
being is to delete your workspace and start again with a clean one. Could
you possibly let us know if you are running any other plug-ins alongside
AJDT to help us track this down?
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #40273 is a reply to message #40252] Mon, 16 August 2004 14:08 Go to previous messageGo to next message
Thanks Sian.
I'm using VE, GEF and EMF too.
Andr
Re: Eclipse 3.0.0 & task view [message #40302 is a reply to message #40273] Tue, 17 August 2004 09:54 Go to previous messageGo to next message
I'm afraid I'm still struggling to reproduce this problem. If possible
could you let me have a bit more information? E.g. How you created the
project, what happens to the problems view if you remove the AspectJ nature
and anything else that may be relevant.
Thanks for your help,
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #40333 is a reply to message #40302] Wed, 18 August 2004 10:00 Go to previous messageGo to next message
Sian,
I can send my project and workspace to you, if you want.
Andr
Re: Eclipse 3.0.0 & task view [message #40365 is a reply to message #40333] Wed, 18 August 2004 11:53 Go to previous messageGo to next message
Thanks, that would be great. It's sjanuary@uk.ibm.com.
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #40394 is a reply to message #40365] Thu, 19 August 2004 21:11 Go to previous message
Sian,
I've deleted the workspace and now everythig goes fine. I'll try to
reproduce the error to send to you the files...
Andre
"Sian January" <sjanuary@uk.ibm.com> escreveu na mensagem
news:cfvts2$di1$1@eclipse.org...
> Sian
> "Andr
Re: Eclipse 3.0.0 & task view [message #582751 is a reply to message #40130] Fri, 13 August 2004 10:38 Go to previous message
click.
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #582805 is a reply to message #40168] Fri, 13 August 2004 13:17 Go to previous message
> Hello,
have
from
> click.
> Sian
> "Andr
    (Size: 128.35KB, Downloaded 185 times)
Re: Eclipse 3.0.0 & task view [message #582820 is a reply to message #40168] Fri, 13 August 2004 16:18 Go to previous message
> Hello,
have
from
> click.
> Sian
> "Andr
Re: Eclipse 3.0.0 & task view [message #582836 is a reply to message #40229] Mon, 16 August 2004 06:04 Go to previous message
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #582852 is a reply to message #40252] Mon, 16 August 2004 14:08 Go to previous message
Thanks Sian.
Andr
Re: Eclipse 3.0.0 & task view [message #582865 is a reply to message #40273] Tue, 17 August 2004 09:54 Go to previous message
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #582884 is a reply to message #40302] Wed, 18 August 2004 10:00 Go to previous message
Sian,
Andr
Re: Eclipse 3.0.0 & task view [message #582897 is a reply to message #40333] Wed, 18 August 2004 11:53 Go to previous message
Sian
"Andr
Re: Eclipse 3.0.0 & task view [message #582920 is a reply to message #40365] Thu, 19 August 2004 21:11 Go to previous message
Sian,
Andre
> Sian
> "Andr
Previous Topic:AJDT 1.1.12 released for Eclipse 3.0
Next Topic:Advice information for classes in other projects
Current Time: Sat Jul 19 01:18:47 EDT 2025
Powered by FUDForum. Page generated in 0.06358 seconds
