Home » Eclipse Projects » DTP » Define a data source with external parameters
| Re: Define a data source with external parameters [message #40054 is a reply to message #38352] |
Wed, 19 December 2007 11:52   |
Originally posted by: brianf.sybase.com
Hi Antoine...
This seems like an interesting use case. Can you provide more details about
it?
So you'd have a file or something in the project properties that would
define the connection information for a database connection, and then would
like a custom connection profile to see those properties and add a
connection profile to the data source explorer?
This might be tricky, but I can see one possibility would be to have a way
to map a file or set of properties to an exported connection profile file
(which is just XML) and that would allow you to then import that export
profile into the DSE so it shows up.
The only issue I see is that the connection profile cache is
workspace-relative, not project-relative. But there may be ways around this
by creating some sort of project-relative profile repository that would read
the data from the project properties and handle it.
Can you provide more details so we have more information to work with?
Perhaps specifics about what the properties would look like in the project
and the expected behavior?
Thanks in advance. Sorry for the delay in getting back to you.
--Fitz
Brian Fitzpatrick (aka "Fitz")
Sr. Software Engineer/DTP Committer
Sybase, Inc.
"Antoine Toulme" <atoulme@intalio.com> wrote in message
news:fgrunq$k97$1@build.eclipse.org...
> Hi,,
> no answer so far, should I raise an enhancement request ?
> Antoine
> Antoine Toulme wrote:
>> Hi all,
>> we would like to use DTP in our product, and define a datasource using
>> parameters defined elsewhere in the project properties. This datasource
>> would then appear by default when opening the data explorer view.
>> Is this feasible ?
>> Thanks,
>> Antoine
> Intalio, the Open Source BPMS Company
> <a href="http://www.intalio.com">http://www.intalio.com</a>
> <a href="http://bpms.intalio.com">Community website</a>
| Re: Define a data source with external parameters [message #40146 is a reply to message #40054] |
Thu, 20 December 2007 08:12   |
Originally posted by: atoulme.intalio.com
Hi Brian,
I had lost track of this issue and didn't open a Bugzilla entry for it.
I think the settings could be saved on a preference store per project.
Let's continue this discussion on Bugzilla, it will be a bit easier to
track down :).
Thanks for replying!
Antoine
Brian Fitzpatrick wrote:
> Hi Antoine...
> it?
> --Fitz
> Sybase, Inc.
>> Hi,,
>> Thanks,
>> Antoine
>>> Hi all,
>>> Is this feasible ?
>>> Thanks,
>>> Antoine
| Re: Define a data source with external parameters [message #40177 is a reply to message #40054] |
Thu, 20 December 2007 08:17   |
Please follow this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213584
Antoine
> Hi Antoine...
> it?
> --Fitz
> Sybase, Inc.
>> Hi,,
>> Thanks,
>> Antoine
>>> Hi all,
>>> Is this feasible ?
>>> Thanks,
>>> Antoine
| Re: Define a data source with external parameters [message #40198 is a reply to message #40177] |
Thu, 20 December 2007 10:07  |
Okey dokey. I've gone ahead and added some comments to your BZ entry to get
the ball rolling. :)
news:fkdq16$jd5$2@build.eclipse.org...
> Regards,
> Antoine
>> Hi Antoine...
>> about it?
>> would like a custom connection profile to see those properties and add a
>> way to map a file or set of properties to an exported connection profile
>> file (which is just XML) and that would allow you to then import that
>> export profile into the DSE so it shows up.
>> this by creating some sort of project-relative profile repository that
>> would read the data from the project properties and handle it.
>> project and the expected behavior?
>> --Fitz
>> Sybase, Inc.
>>> Hi,,
>>> Thanks,
>>> Antoine
>>>> Hi all,
>>>> Is this feasible ?
>>>> Thanks,
>>>> Antoine
| Re: Define a data source with external parameters [message #589415 is a reply to message #38352] |
Hi Antoine...
it?
--Fitz
Sybase, Inc.
> Hi,,
> Antoine
>> Hi all,
>> Is this feasible ?
>> Thanks,
>> Antoine
| Re: Define a data source with external parameters [message #589444 is a reply to message #40054] |
Hi Brian,
track down :).
Antoine
> Hi Antoine...
> it?
> --Fitz
> Sybase, Inc.
>> Hi,,
>> Thanks,
>> Antoine
>>> Hi all,
>>> Is this feasible ?
>>> Thanks,
>>> Antoine
| Re: Define a data source with external parameters [message #589454 is a reply to message #40054] |
Antoine
> Hi Antoine...
> it?
> --Fitz
> Sybase, Inc.
>> Hi,,
>> Thanks,
>> Antoine
>>> Hi all,
>>> Is this feasible ?
>>> Thanks,
>>> Antoine
| Re: Define a data source with external parameters [message #589461 is a reply to message #40177] |
> Regards,
> Antoine
>> Hi Antoine...
>> about it?
>> --Fitz
>> Sybase, Inc.
>>> Hi,,
>>> Thanks,
>>> Antoine
>>>> Hi all,
>>>> Is this feasible ?
>>>> Thanks,
>>>> Antoine
Current Time: Mon Nov 17 10:08:28 EST 2025
Powered by FUDForum. Page generated in 0.04830 seconds
