disabled mylyn features [message #39806] |
Mon, 24 December 2007 08:50  |
Hi everyone,
I'm having the situation whenever I start eclipse with -clean all the
features of the mylyn package have been disabled. I then have to enable
them manually, which actually works but still it's quite annoying.
Does anybody know where that behaviour stems from, because I've observed
this with a few other plugins as well.
Thanks for any help
bye M;chi
Re: disabled mylyn features [message #40225 is a reply to message #40201] |
Mon, 31 December 2007 17:46  |
David Carver wrote:
>> Just in case anybody is interested in the solution. Eclipse can't load
>> jarred features, which happened when I just unzipped the plugin package
>> into my extension location.
> Yep. They need to have the features jarred for correct download when
> not going through an update site. This requires a different setting
> on the feature packaging when exporting the feature in PDE.
By the way, guys, why unzipping this stuff manually instead of using
Eclipse Update Manager? Note that you can install from both remote and
local update site. If I am not mistaken, the latter can be pointed to an
archive downloaded from the Mylyn web site.
regards,
Eugene
Re: disabled mylyn features [message #586410 is a reply to message #39806] |
Thu, 27 December 2007 20:18  |
We have not encountered behavior of this sort before and and will need
more information to figure out what's going on. It would be best to
file a bug and include all of the features that you have installed, and
the precise Eclipse version. It sounds like there is something in the
dependency chain that's either failing or missing, so it would also be
helpful if you attached your <worskspace>/.metadata/.log file, ideally
containing only the entries after the first restart with -clean.
Mik
M;chi wrote:
> Hi everyone,
> Thanks for any help
> bye M;chi
Re: disabled mylyn features [message #586468 is a reply to message #39928] |
Mon, 31 December 2007 08:55  |
> Mik
> M;chi wrote:
>> Hi everyone,
>> Thanks for any help
>> bye M;chi
Re: disabled mylyn features [message #586519 is a reply to message #40113] |
Mon, 31 December 2007 17:42  |
not going through an update site. This requires a different setting on
Re: disabled mylyn features [message #586527 is a reply to message #40201] |
regards,
Eugene
FUDForum. Page generated in 0.06049 seconds
